Forum Index > Historical Arms Talk > Coat of plates the st Maurice way - wipDIY Project Reply to topic
Håvard Kongsrud
Reading list: 3 books
PostPosted: Tue 04 Jul, 2017 12:49 pm    Post subject: Coat of plates the st Maurice way - wip         Quote
Following a discussion in the XIII century armour-group on Facebook and on the Armour Archive and Cite d'Antan's recent series of pictures of the Magdeburg-st Mauritius, i decided to incorporate Mart's theories (from Len Parker) in my CoP project. In short, the lines on the CoP of the st Maurice statue in Magdeburg as well as the st Maurice image in Lögumkloster church are interpreted as a separate textile piece tailoring the shouder and neck area avoiding unsightly bumps on the front and back of arm holes so often seen on reconstructions.
Layout of pattern for the st maurice CoP
After most sewing is done, the theory seem to be working just fine.
[ed: Placed images in attachment due to photobucket-trouble]
 Attachment: 571.31 KB
Layout of pattern for the st maurice cop [ Download ]
 Attachment: 337.75 KB
After most sewing is done, the theory seem to be working just fine. [ Download ]
Ben Joy
PostPosted: Tue 04 Jul, 2017 3:01 pm    Post subject:         Quote
Interesting. It's looking good. Do you think this could set a new standard on how recreation coats of plates are made? Some sort of "missing link"?
"Men take only their needs into consideration, never their abilities." -Napoleon Bonaparte
PostPosted: Tue 04 Jul, 2017 10:38 pm    Post subject:         Quote
These are sometimes called "armoured surcoats". They were the precursor to the coat of plates.
Håvard Kongsrud
PostPosted: Wed 05 Jul, 2017 1:38 am    Post subject:         Quote
Thanks, I am sort of hoping to inspire someone more qualified than me to try out variations of this pattern, yes. I wouldn't call it a "missing link" though, because that evokes a evolutionistic paradigm that I don't find productive in this context.
Thanks, Dan. The typologisation of segmented torso armour is in deed a lengthy and interesting subject. I favour the norse term plata ("plates") myself. Thordeman and Blair do call the Magdeburg st Mauritius' garment a (variation of the) "reinforced surcoat". However, apart from its flaps, its construction is in most respects similar to the later CoP's. If a distinction is to be made, I consider it marginally more meaningful to reserve the term "armoured surcoat" for what we see on the ca 1289-90 Wienhausen sleeping guard and the Danish early 14th century st Maurice and st George images Lögumkloster chruch. Let's call this kind with full skirt type A.
We could go on calling the kind with flaps type B. Besides the ca 1250 Magdeburg st Mauritius, it is represented by the ca 1260-80 Konstanz sleeping guards and the Swedish 1323 Södra Rada Valerianus.
Type C without the flaps would interestingly enough be represented by another image from Lögumkloster, the ca 1300 massacre of the innocents-bad guy on the altar frontal, sligthly earlier than the other images. The type is more pronounced on the ca 1270 bad Jena dude. Neither of the images are referred by Thordeman,
Interestingly, all types would fit with Thordeman's type II or III with vertical plates, and making a chronological distinction between them seem speculative. Therefore, contrary to Blairs chronology, I would consider these more like variations of a theme rather than an evolusionistic development, woulden't you agree?
Randall Moffett
PostPosted: Wed 05 Jul, 2017 5:03 am    Post subject:         Quote
Well done! It looks very good. Do you have an inside shot of this?
Thanks,
Stephen Curtin
Likes: 110 pages
Reading list: 18 books
PostPosted: Wed 05 Jul, 2017 12:28 pm    Post subject:         Quote
Looking good so far Håvard. Well done.
Éirinn go Brách
Profile PM E-mail
Håvard Kongsrud
PostPosted: Wed 05 Jul, 2017 1:34 pm    Post subject:         Quote
Thank you guys. No inside shots yet, I'm afraid. The plates are just fastened with split pins for now. But here's the layout. Guess which Visby CoP-number it is based on.
I went for 1,2 mm (ca 18 gauge) mild steel as that was avaliable, but unable to harden the steel, I suspect I might regret it after the first spear trust my way. With 1 kg textile, the whole thing should come out at 5 kg (11 pounds). As rust protection I went for blackening the steel like you wold an iron pan. After dishing out the curve with a rubber hammer on a shaped stump, the barbecue commenced. Some test carbonization resulted in the kichen stove becoming out of bounds for the project.
Linseed oil carbonized just fine at ca 250 degrees celsius (that's 482 degrees Fahrenheit for you old schoolers), turning from transparent to sticky brown to blank, hard black in 20-30 min. It took two turns and a rubbing as I did not take the "thin layer of oil" seriously enough.
Last edited by Håvard Kongsrud on Tue 18 Jul, 2017 11:11 am; edited 1 time in total
Kai Lawson
PostPosted: Thu 06 Jul, 2017 7:35 am    Post subject:         Quote
This looks like it's really taking shape. I like the color too. I was wondering about the thoracic side plates, and their relation to the abdominal plates. If there is sufficient overlap of the lower plates over the upper set, there is no need for rivets on the bottom edge of the upper plates; however, if the lower edge of the plates were to share a rivet with the top edge of the abdominal plates, the upper and lower sections would function more as a whole, especially given the lack of flexibility in the vertical abdominal plate arrangement. I haven't see details of the Visby reports--does anyone know if here were holes low down on the upper plates? Does this make for an awkward garment?
"And they crossed swords."
Håvard Kongsrud
PostPosted: Thu 06 Jul, 2017 8:16 am    Post subject:         Quote
Nope. None of the type II, III or IV had holes low at the thorax plates. Only in one (no 1) of the type I CoPs (with horisontal abdominal plates) one of the thorax plates shared rivets with the upper abdominal plate, and in a second (no 4) there were rivets low on the thorax plates. See Thordeman, Armour from the battle of Wisby.
[ed: corrected typo)
Last edited by Håvard Kongsrud on Wed 12 Jul, 2017 11:18 am; edited 1 time in total
Len Parker
PostPosted: Sat 08 Jul, 2017 3:51 am    Post subject:         Quote
Looking good Håvard. It's nice to have a theory and then have someone make it happen.
I hope this works!
Mart Shearer
PostPosted: Wed 12 Jul, 2017 9:14 am    Post subject:         Quote
I look forward to seeing the plates when worn, to see if the inverted-V tailoring over the chest does, in fact, improve the fit.
Ben Joy
PostPosted: Sun 16 Jul, 2017 9:29 am    Post subject:         Quote
Sorry, I wasn't trying to say it in a sort of "evolutionistic paradigm" sense of the concept. I was referring more to a "missing link" as far as a crafting method that bridges a gap between what we have been doing for recreations and how it was actually "supposed" to be done.
Think of it like having a cooking recipe, but it's missing an ingredient to make it just right. Everyone else has been making it without the ingredient, but you've figured out the ingredient and are now making the recipe properly. Granted I'm not just saying "you" as in you exclusively, but as everyone who has posed this theory that you're now trying to execute.
That makes two of us. Very curious to see how the concept turns out. If it improves the fit, this would probably fall within the purview of "I want to have one of these made."
Håvard Kongsrud
PostPosted: Tue 18 Jul, 2017 11:39 am    Post subject:         Quote
Still some time left before the "missing link" is finished I'm afraid, but at least the last rivets have arrived and are prepared.
In the meantime a word on riveting. Many torials advise punching holes through the canvas. This reduces the strength significantly where you need it the most. In stead, the historical way to do it, shown on lacing holes, is to work a large awl, fid or knitting pin through the canvas, compressing the weave around the rivet. This way the textile around the rivet becomes the strongest in stead of the weakest part. I went for large diameter rivets for the same reason.
I needed some solid and historical laces to fasten the back flap to the torso beneath the plates, and decided to weave them myself using tablets and rather thick silk thread. (For ease of work I made myself a quite unhistorical combined schuttel and weaving sword, but let's keep that a secret, shall we?) For a first, it went relatively fast, and it is quite realistic to get a full set of laces finished for you full plate guys out there.
Håvard Kongsrud
PostPosted: Tue 01 Aug, 2017 8:58 am    Post subject:         Quote
Soo. First test with all plates in place. The narrow curvature of the lower front plates gives the upper plates quite a large instep. I should've had some curvature in the vertical plane as well as the horisontal plane with the front plates, like we see in Magdeburg-st. Maurits,
What do you think of the fit around the arm opening? Shall we say this supports the theory of the lines and tayloring discussed above? (I do believe this would work just as well with the upside down V set lower in the front.)
PostPosted: Tue 01 Aug, 2017 2:22 pm    Post subject:         Quote
How much flexibility is there across the chest? If there isn't any then there may be issues using some weapons. The solution would be to make the arm holes bigger to reduce the coverage across the chest.
Håvard Kongsrud
PostPosted: Tue 01 Aug, 2017 2:39 pm    Post subject:         Quote
I was a bit worried aboat that, but it seems like I left sufficient space and I'm able to swing my arms around with no hindrance. I do feel the plates when my elbows cross, but the chest part compress enough to leave space for more than suficient movement.
PostPosted: Tue 01 Aug, 2017 3:14 pm    Post subject:         Quote
Good to know. I like your hand-woven laces. Little touches like that make the difference between a good result and an outstanding one. Looking forward to seeing it finished.
Mart Shearer
PostPosted: Wed 02 Aug, 2017 4:18 pm    Post subject:         Quote
I don't see any sign of puckering in the front of the arm, so I would say the tailoring experiment is a success. I must say I am most impressed by the way your seams at the intersection of the side panels to the body look very much like the Magdeburg Maurice. Are you using flat-felled seams?
Håvard Kongsrud
PostPosted: Thu 03 Aug, 2017 1:17 pm    Post subject:         Quote
Thanks, Dan, appreciated.
Thanks, Mart. No, not with the lateral panel going all the way under the vertical one. The vertical panel got double hem seams before I sewed it onto the lateral panel with back stitches and a second row of tunnel stitches on each side. With the cut and thickness of the backing and cover fabricks, the visual impression is more or less given.
M. Eversberg II
PostPosted: Fri 04 Aug, 2017 7:08 am    Post subject:         Quote
This is a very good project! I have long wanted to do a set like this but have not yet had the capital to do so. What did you use to cut your plates out?
M.
This space for rent or lease.
Profile PM AIM YIM MSN ICQ
