Forum Index > Historical Arms Talk > Bascinet visor fastening and adjustment. Reply to topic
Michael Sheridan
PostPosted: Mon 17 Apr, 2017 5:55 pm    Post subject: Bascinet visor fastening and adjustment.         Reply with quote
Hey everyone. I'm new to the forum. I'm working on a 14th century build and recently acquired a pig faced bascinet. The helmet came with carriage bolts and nuts for the visor fastener and unlined. The visor is extremely loose and won't stay up. even when I tighten it down a lot it looses after opening a few times and still doesn't stay up. I bought some bottom head or aircraft rivets but don't think i can get enough leverage on the inside of the helmet to pien them over. Just wondering if anyone had and hints or advice on what to do. I tried searching the topic and hope that in posting this in the correct place.
Thank you!
Mike
Reading list: 7 books
PostPosted: Tue 18 Apr, 2017 10:52 am    Post subject:         Reply with quote
Unfortunately this is a very common issue with modern reproductions. Antique examples show how medieval armourers often dealt with this problem by placing the visor's pivots at slightly different heights from each other, so the visor runs a little twisted/crooked when raised and the tension and friction from this play a major part in keeping the visor up.
Michael Sheridan
PostPosted: Tue 18 Apr, 2017 11:03 am    Post subject:         Reply with quote
Thank you for the reply. Yeah I read someplace about doing that. Worst case I'll do that. I'm just trying to figure out how I can mushroom over the rivets on the inside. Very hard because there isn't much room to piece them over. They're 1/4 steel dome or round rivets.
Mark Moore
PostPosted: Wed 19 Apr, 2017 5:06 am    Post subject:         Reply with quote
You could install a spring-pin on the inside of the helm. This would pop out under the visor whenever you raise it. Happy .....McM
Kel Rekuta
PostPosted: Sun 23 Apr, 2017 2:34 pm    Post subject:         Reply with quote
Its always easier to peen a rivet on the outside of a helmet. Support the work over a pipe or bar chucked up in a vise or heavily clamped to a table.
Put the rivet head inside with the shank exposed outside the shell. Put an over-large washer over the rivet and carefully peen the shank down. The washer will protect against wayward hammer strokes marring the helmet shell or visor arm. Gently file away any peen marks for a smooth finish.
Mark Moore
PostPosted: Mon 24 Apr, 2017 8:21 am    Post subject:         Reply with quote
This is true, but over time the rivet and/or washer will wear down and loosen, requiring re-peening. A locking mechanism of some type, once installed, is basically hassle-free. Happy ....McM
