Forum Index > Off-topic Talk > What gauge steel wire is best for flat ring riveted mail? Reply to topic
Thomas R-W
PostPosted: Sun 13 Dec, 2015 7:36 am    Post subject: What gauge steel wire is best for flat ring riveted mail?         Quote
I've been looking into buying steel wire to make my own rings for a riveted mail shirt but I'm not sure what gauge would be best to make the flattened rings the most historically accurate thickness. Also could anyone point me to cheap rivets for it? It would be highly appreciated.
~Thorill
Mart Shearer
PostPosted: Sun 13 Dec, 2015 8:06 am    Post subject:         Quote
Historically accurate thickness varies between approximately 20 g (c. 0.5mm) and 12g (c. 3.3mm). What is "best" depends on the criteria you use. Ring diameter and historical timeframe might be factors to consider as well. Historically, rivets are made from wire or slit sheet.
Thomas R-W
PostPosted: Sun 13 Dec, 2015 9:39 am    Post subject:         Quote
I'm trying to make something that would be close to viking age, possibly a little later but around there. And for rivets would it work just to snip bits of the wire I'm using to make the rings and put that through a hole as a rivet or should I buy rivets separate do you think?
~Thorill
Julio Junco
PostPosted: Sun 13 Dec, 2015 10:46 am    Post subject:         Quote
You can use wire with 1.3 mm diameter. It is easier to handle and easy to pierce.
If your mail will be Viking Ages perhaps would be better round section rings . The rivet can be round wire but smaller, 0.6 mm in diameter or slightly larger, not more than 0.8 mm.
If you want wedge rivet, you can use metal strips 0.6 mm thick and cut wedges about 3 mm long. But for Viking Ages, better round rivet.
Regards
Julio
Thomas R-W
PostPosted: Sun 13 Dec, 2015 10:58 am    Post subject:         Quote
I like the flat ring look a bit better, that's the only reason I'm going with that but I thank you for your information. So 16 gauge for the rings and about 20-22 gauge for the rivets would be best you say? Also if you could answer me one more thing. Is an internal diameter of 6mm or 8mm best for this type of mail?
~Thorill
Julio Junco
PostPosted: Sun 13 Dec, 2015 11:55 am    Post subject:         Quote
I know it only in mm but I think is ok.
You can roll the wire in a 7 mm mandrel and when you do the overlap the ring go smaller than 7 mm innternal diameter. Nice and more dense but more work. And the Viking Ages mails can be bigger than 8 mm.
I put photos with 7 mm ID and 8 mm ID so you can see how it looks. The wire look the same 1'3 or 1'5 mm, only more resistent withh thick wire.
Julio
 Attachment: 325.31 KB
 Attachment: 179.07 KB
Mart Shearer
PostPosted: Sun 13 Dec, 2015 2:13 pm    Post subject:         Quote
This chart may be of use.
http://www.vikingsonline.org.uk/resources/authenticity/chainmail/
You really should avoid flattened rings based on that evidence, as well as wedge rivets which don't appear until c.1300, acoording to our best current information.
Thomas R-W
PostPosted: Sun 13 Dec, 2015 4:38 pm    Post subject:         Quote
Mart Shearer wrote:
You really should avoid flattened rings based on that evidence.
You bring a fair point, but I do have a question on the terminology of the site. What does it mean by "lapped & riveted".
~Thorill
Mart Shearer
PostPosted: Sun 13 Dec, 2015 6:35 pm    Post subject:         Quote
The overlapping ends of the wire coil are riveted together. See Vegard Vike's article.
http://www.erikds.com/pdf/tmrs_pdf_11.pdf
 Attachment: 18.43 KB
Vegard Vike
Thomas R-W
PostPosted: Sun 13 Dec, 2015 7:11 pm    Post subject:         Quote
Ah alright that was a pretty stupid question now that I think about it. Would you have any suggestions as to how I can effectively flatten only the area I want to rivet? Since the rings are so small it's much harder to only flatten one area. Thanks for all your help and in advance for any more you may give me.
~Thorill
PostPosted: Sun 13 Dec, 2015 7:41 pm    Post subject:         Quote
With some practice you can do it with a ball-pein hammer.
Thomas R-W
PostPosted: Sun 13 Dec, 2015 7:53 pm    Post subject:         Quote
Would a 2 pound sledge work?
~Thorill
PostPosted: Sun 13 Dec, 2015 11:11 pm    Post subject:         Quote
Not really. It might work on really large links but that is about all.
Thomas R-W
PostPosted: Sun 13 Dec, 2015 11:21 pm    Post subject:         Quote
So I'll just need a bit smaller hammer?
~Thorill
PostPosted: Mon 14 Dec, 2015 3:45 am    Post subject:         Quote
Ball pein
Thomas R-W
PostPosted: Mon 14 Dec, 2015 5:13 am    Post subject:         Quote
Alright what is it about ball-peen hammers that makes them the best tool for this?
~Thorill
Julio Junco
PostPosted: Mon 14 Dec, 2015 11:10 am    Post subject:         Quote
If I use ball peen hammer for this, I destroy a lot of rings. Maybe I´m not skilled
I use metal rod ( was made by Pekka Passanen from Finland) and a good hammer.
I cut the rings, make the overlap and then small blow with the hammer and the steel rod so I flatten the overlap area only. Look the photos.
Very useful information in maille/info" target="_blank">https://groups.yahoo.com/neo/groups/rivetedmaille/info
Regards
Julio
 Attachment: 6.49 KB
 Attachment: 20.97 KB
 Attachment: 23.54 KB
PostPosted: Mon 14 Dec, 2015 12:41 pm    Post subject:         Quote
Yes you will destroy a lot of rings untill you get used to the technique. If you don't practice with the hammer and instead use a fancy tool then how can you expect to get skilled?
Julio Junco
PostPosted: Mon 14 Dec, 2015 1:19 pm    Post subject:         Quote
A small steel bar is fancy tool? Amazing.You only need a little steel bar, not "fancy tool"
It´s cheap, easy and fast.
You need to make right the overlap and ring softening, like if you use the ball peen hammer . But it works better. Of course I used other methods before :)
Julio
