Forum Index > Historical Arms Talk > New bow finds from Denmark: Reply to topic
Niels Just Rasmussen
Spotlight topics: 15
PostPosted: Sat 16 May, 2015 10:15 am    Post subject: New bow finds from Denmark:         Reply with quote
In 2012 in Horsens Fjord (Hjarnø), Jutland, Denmark, underwater archaeologists located a settlement from the Late Mesolithic (~4700 BC - Older/Middle Ertebølle).
Among the finds was a 1,6 meter tall bow made of ash (!).
The bow in situ.
Source: http://www.horsensmuseum.dk/~/media/Instituti...&w=450
Here is a bigger picture of the bow "on land":
Source: https://marinmoesmus.files.wordpress.com/2011/12/2011-12-14-13-51-44.jpg
Other special finds were three ornamented paddles and the skull of a dog.
Picture of one of the paddles in the water:
Source: http://www.horsensmuseum.dk/~/media/Instituti...ashx?w=450
Picture of one of the paddles:
Conservation of the paddle:
Source: https://www.youtube.com/watch?v=l2IoaxSNL1s
Axe:
Source: http://videnskab.dk/sites/all/files/imagecach...are2_0.jpg
Dog skull:
Source: http://www.horsensmuseum.dk/~/media/Instituti...ashx?la=da
Stephen Curtin
Likes: 110 pages
Reading list: 18 books
PostPosted: Sat 16 May, 2015 10:27 am    Post subject:         Reply with quote
Thanks for sharing Niels.
Éirinn go Brách
Matthew Bunker
PostPosted: Sat 16 May, 2015 10:29 am    Post subject:         Reply with quote
The bow looks very similar to a 'waisted' bronze age bow found at Meare Heath, Somerset.
http://digitaldigging.net/the-meare-heath-bow-reconstruction/
PostPosted: Sat 16 May, 2015 10:43 am    Post subject:         Reply with quote
At Rødbyhavn, Lolland, Denmark, archaeologists work intensively to salvage as much as possible before the bridge/tunnel to Germany is build. They have found a bow fragment and a well preserved arrow (oct/nov 2013) from around 2800-2600 BC (Neolithic).
Bow fragment in situ. It has been ritually pushed into the mud and so everything above the mud has disappeared.
Source: http://www.aabne-samlinger.dk/femernforbindel.../bueoffer/
Bigger picture of the bow fragment: [Sadly no mention of what kind of wood]
Source: http://www.tveast.dk/sites/www.tv2east.dk/fil...13-bue.jpg
Out of 4 arrow finds the following were the best (86 cm!):
Source: http://www.aabne-samlinger.dk/femernforbindel...ammel-pil/
Sadly while digging they cut of the tip (which they couldn't find).
The arrow has grooves coloured black and showed traces of plant-fibers to fasten the guiding feathers. They speculate that the black colour could be birch-tar. The arrow looks like the other types of arrows found in Denmark and they are all “tværpile", meaning a flint arrowhead with a broad edge.
Tværpil flint arrowhead example:
Source: http://www.museum-sonderjylland.dk/BILLEDERNE...g4-004.jpg
NB: This is not a find from Rødbyhavn, but I just give it as an example.
In april 2015 they might have found the missing tip (though it could be from another arrow):
Big image. Source: http://www.tveast.dk/sites/www.tv2east.dk/fil...ter2-2.jpg
Some of the flint and and the fastening material for it is still on the arrow!
Source: http://www.tveast.dk/artikler/finder-knaekket-pil-fra-stenalderen
Since this new find is 10 cm, if it is the missing front part it will give a 96cm arrow all-in-all (without feathers).
Last edited by Niels Just Rasmussen on Sat 16 May, 2015 10:52 am; edited 2 times in total
PostPosted: Sat 16 May, 2015 10:51 am    Post subject:         Reply with quote
Among Mesolithic bow finds in Denmark you have at least now the following:
Holmegårds Mose, Zealand.
Maglemosegård, Zealand.
Tybrind Vig, Vest Funen.
Ronæs Skov, Vest Funen.
Ringkloster, East Jutland.
Horsens Fjord, East Jutland.
I'll try to get more info up here on this thread.
PostPosted: Sat 16 May, 2015 11:00 am    Post subject:         Reply with quote
In dating the Meare Heath bow is from the same age period as the Rødbyhavn bow fragment (not the mesolithic ones).
This article gives it a date of 2690 BC +/- 120 years, so more neolithic than bronze age.
Source: http://www1.somerset.gov.uk/archives/hes/down...pter_4.pdf
Since I'm no bow expert I don't know the exact differences between mesolithic and neolithic bows. It could very well be different since it is ethnically entirely different populations in Denmark. The mesolithic hunter-fishers were ousted by the neolithic farming people (Funnelbeaker Culture) migrating in from the south (by Germany, but originally from Anatolia) ending the Mesolithic Ertebølle Culture around 4000-3900 BC and then actually from 2800 BC the early neolithic people were ousted themselves by incoming likely Indo-european speaking people (Corded Ware Culture) from Germany (but originally from Ukraine), bringing on the late neolithic.
So it is likely these three ethnically totally different peoples would have had quite different bow traditions [unless they all three stayed very conservative with a common ancestor model]
But I would love to be enlightened.
Pieter B.
Reading list: 10 books
PostPosted: Sat 16 May, 2015 12:51 pm    Post subject:         Reply with quote
Was the flatbow in use during any part of the medieval period in Europe?
PostPosted: Sun 17 May, 2015 5:07 am    Post subject:         Reply with quote
So here is some info about the Mesolithic bows:
This article on academia.edu by Jan H. Sachers.
"Mesolithic bows from Denmark and Northern Europe".
Source: https://www.academia.edu/11765815/Mesolithic_Bows_from_Denmark_and_Northern_Europe
Neither the Horsens Fjord or the Rødbyhavn finds are discussed in this article.
As all the Danish bows mentioned in this article is made of Elm (+ 3 german and 1 dutch example made of yew all from the neolithic), it is quite surprising that the the recently found bow in Horsens Fjord is made of Ash.
Most of these bows seems to continue the basic Holmegård flatbow design from 6500 BC. Most impressive is the late mesolithic Ertebølle bow from Maglemosegård, Vedbæk around ~194 cm long (that is certainly what you would call a longbow!).
It quite possible that hunters in Northern Europe continued building hunting bows like these far up in time, but beside the Iron Age Nydam bows and the early viking age bow from Hedeby I'm not aware of bronze age or medieval archaeological bow finds filling out these gaps.
Since the Welsh apparently too made bows of elm and it quite likely that the "welsh longbow" were perhaps a "Holmegård tradition", whereas the English longbow was made a yew (as the neolithic german/dutch finds).
Last edited by Niels Just Rasmussen on Sun 17 May, 2015 5:38 am; edited 1 time in total
PostPosted: Sun 17 May, 2015 5:35 am    Post subject:         Reply with quote
A further special find from the mesolithic is the Møllegabet II miniature bow (settlement from 5250-4800 BC).
It is made from red cornel (!) and was only 86 cm long (preserved today is 83 cm). Another almost identical bow (preserved to 75 cm) has been find in Ageröd in Scania.
Also from Møllegabet you have an elm-bow fragment - 34,6 cm preserved of a “horned longbow“.
They are described on page 89-90 with drawings in this publication:
Jørgen Skaarup & Ole Grøn (2004)
Møllegabet II. A submerged mesolithic settlement in southern Denmark
Source: https://www.academia.edu/5700957/M%C3%B8llegabet_II._A_submerged_Mesolithic_settlement_in_southern_Denmark
Henrik Zoltan Toth
PostPosted: Mon 18 May, 2015 1:49 am    Post subject:         Reply with quote
Thank you for sharing them, Nils!
Pieter, that's from the old Hungary. At that period (15 th. Cent.) mostly composits were used, but the artist surely got his inspiration from somewhere (Germany, Czech kingdom, Poland?).
http://biblia.hu/a_biblia_a_magyar_kepzomuves...ig/217.jpg
Shahril Dzulkifli
PostPosted: Thu 21 May, 2015 5:35 am    Post subject: New bow finds from Denmark         Reply with quote
I should say that this Danish bow is a rare archaeological find. I've ever heard of weapons like swords found underwater but rarely, bows.
- Marcus Aurelius
Last edited by Shahril Dzulkifli on Fri 22 May, 2015 5:02 am; edited 1 time in total
PostPosted: Thu 21 May, 2015 9:54 am    Post subject: Re: New bow finds from Denmark         Reply with quote
Shahril Dzulkifli wrote:
I should say that this Danish bow is a rare archaeological find. I've ever heard of weapons like swords found underwater but not bows.
Yeah, but it is possible to find a lot more. Apparently Danish archaeologist have registered 3.000 stone age settlements, that are today under water just waiting for marine archaeology [the assessment is around 30.000 in all].
So there is work for several of hundred of years for the 5 museums that have specialized underwater archaeology sections: Viking Ship Museum (Roskilde - responsible east of Storebælt) is the far biggest of the 5.
The other four takes care of diggings west of Storebælt:
Second biggest marine archaeology group is "Øhavsmuseet" (Svendborg).
These two museums takes developer-funded projects.
Then the three minor underwater archaeology groups are Nordjyllands Kystmuseum (Frederikshavn), that is specialized in early modern wrecks; "Moesgård Museum" (Århus) are responsible for the survey of stone age sites and "Strandningsmuseet S. George" (Thorsminde) are responsible for stone age finds and historical wrecks.
So we can expect a handful of underwater digs pr. year, so it wouldn't surprise me if we will see some more finds in the near future.
