Forum Index > Off-topic Talk > Testing John Lundemo made DS sword Reply to topic
Lancelot Chan
PostPosted: Tue 28 Oct, 2014 4:58 am    Post subject: Testing John Lundemo made DS sword         Quote
http://youtu.be/VJZ_pfA2bGA
Got the sword yesterday. Polished the edge further and gave it a test today. It surprised me and exceeded my expectation.
Profile PM Website
Hector A.
PostPosted: Tue 28 Oct, 2014 6:52 am    Post subject:         Quote
Cuts very smooth, how did you sharpen it, at an angle or flat?
Lancelot Chan
PostPosted: Tue 28 Oct, 2014 7:10 am    Post subject:         Quote
At an angle, following the original edge's final angle. I used DMT coarse, then moved to DMT fine, then extra fine, and then a very high grit out-of-production natural translucent arkansas stone. Then I de-burr the edge with steeling technique with a hex key. That's how I did it.
Profile PM Website
PostPosted: Tue 28 Oct, 2014 6:08 pm    Post subject: Re: Testing John Lundemo made DS sword         Quote
Yes that does seem to cut rather well: Good technique probably helps but you seemed pleased and maybe a bit surprised by how little effort it took and how it would cut things in half even when the cutting medium was just siting there offering very limited resistance for the edge to work with.
Hector A.
PostPosted: Tue 28 Oct, 2014 7:47 pm    Post subject:         Quote
Yes i know which one, that's 2000 grit ( Arkansas S.), i'm always interested in all matter of techniques to improve sharpening, could you describe this Hex Key technique?
I use hard plastique or soft wood to deburr after my 2k grit belt and just before stropping.
Do you even strop bro? ( do you even lift joke :P)
Ian Hutchison
PostPosted: Tue 28 Oct, 2014 7:48 pm    Post subject:         Quote
Very nice, that looks like a very good cutting blade.
Lancelot Chan
PostPosted: Tue 28 Oct, 2014 10:49 pm    Post subject: Re: Testing John Lundemo made DS sword         Quote
Yup, I used to cut with good swords, but this one surpassed them. :) I was awed by how little resistance felt when doing those more difficult cuts. Some of the cuts, the last two, had never succeeded before with my other sword. So wow!
This sword is also my first sword to ever exceed 60 HRC.
Profile PM Website
Lancelot Chan
PostPosted: Tue 28 Oct, 2014 10:57 pm    Post subject:         Quote
I don't strop after steeling.
http://www.chadwrites.com/steeling-your-knife-2/
I just use a hex key for allen nut, and selectively used the corners for a more forceful push, or the flat surface for a gentle push, to help push the burr back online. During the motion, the weak burr will get removed and the rest of the edge will be online very good.
Profile PM Website
Lancelot Chan
PostPosted: Tue 28 Oct, 2014 10:58 pm    Post subject:         Quote
Yup. I'll do more cutting test with it. Some leg cutting hopefully.
Profile PM Website
Lancelot Chan
PostPosted: Wed 29 Oct, 2014 2:25 am    Post subject:         Quote
http://youtu.be/YjDPaKWECno
Testing more difficult cuts with the sword.
Profile PM Website
Ian Hutchison
PostPosted: Thu 30 Oct, 2014 6:00 pm    Post subject:         Quote
Very nice, those cuts were clean through which can be difficult with an unsupported target.
Can you take some pictures of the sword and post them here?
Lancelot Chan
PostPosted: Thu 30 Oct, 2014 10:24 pm    Post subject:         Quote
Here you are. The top one was my Tinker-made DS. The bottom one was the John Lundemo-made DS. The darkening of the bronze fittings do fade away and left an antique bronze appearance along time. Very cool.
 Attachment: 57.98 KB
 Attachment: 31.78 KB
Profile PM Website
