Forum Index > Historical Arms Talk > WIP - XVIIIb longswordDIY Project Reply to topic
Lukas MG
PostPosted: Sun 20 Apr, 2014 7:10 am    Post subject: WIP - XVIIIb longsword         Quote
Hey guys
I usually post WIP pics and stuff over at Don Fogg's forum but with all the amazing DIY work being shown on this forum, I thought this might interest some people here, too. I've always found the DIY projects here very helpful so maybe someone will find this useful as well.
Because I'm busy with med school and spend most time at university, I rarely have to time to work on my projects so don't expect the sword to be done anytime soon... the last one took me a full year including the scabbard (here's a link: http://www.bladesmithsforum.com/index.php?showtopic=23889)
Anyway, here we go. I only do stock removal on long blades (don't have a pass-through forge, just a wood-burning oven that luckily gets plenty hot enough for forging and heat treating small blades and axe heads). Long blades like this I send to a heat treater.
This is the blade after rough grinding with the angle grinder:
I started with 8mm stock and set the distal taper so that the finished blade would sport a convex distal taper to about 4mm before the tip. Overall length is around 133 cm btw, with the blade being about 100cm long. Classic 3:1 blade to handle proportions.
A couple hours at the belt sander (I found a 40$ one from ebay clamped into the vice works very nicely) and some draw filing at the tip later, I got this:
This is my set up for sanding btw (excuse the blurry photo, the light isn't too good in my workshop and nor is my camera)
I'm hoping to be able to continue working on the blade next week. I still have some small amounts of grinding to do, then it'll be onto hand sanding, my favorite part ;) That should keep me busy till summer :lol:
I appreciate all comments! Thanks for looking...
Profile PM Website
Peter Johnsson
PostPosted: Sun 20 Apr, 2014 11:50 am    Post subject:         Quote
This looks promising.
Profile PM Website
Lukas MG
PostPosted: Sun 20 Apr, 2014 11:23 pm    Post subject:         Quote
Thanks :) I can't wait to get back to working on it!
Profile PM Website
Julien M
PostPosted: Mon 21 Apr, 2014 12:22 am    Post subject:         Quote
Hi Lukas,
You did an awesome job with your type XVIII last time, I remember it well thinking - damn, I need to try a full stock removal blade one of these days. I believe I've also seen a tactical falchion of sorts some time ago you'd made using stock removal - equally well done.
You are off to a great start it seems. Are you attempting a shallow fuller at the base? Are you going to rough cut with the angle grinder and dremel the final shape?
Will stay tuned (and as far as having little time and stretching projects for a year I just completed a DIY project that took me 4 so you are fast for my standards :) )
Lukas MG
PostPosted: Mon 21 Apr, 2014 1:06 am    Post subject:         Quote
Thanks!
Indeed, stock removal is a great way to make a blade. I like forge work but am not too unhappy that I have to grind long blades. It takes an equal amount of skill, just a bit different. In the end it also makes things a bit easier because there's no such danger of a blade not surviving the quench because of faulty normalizing circles, etc.
There won't be a fuller at the base but a flat section, giving the blade a hexagonal shape there. I've seen that on the famous longsword in Munich and quite like it but I won't go for such a long hexagonal section (it's almost the first third), just a few inches. I had planned for a bit longer than it seems to turn out but I underestimated the material I had to grind away with the belt sander to get rid of the angle grinder marks. Live and learn ;) At least I don't think it'll hurt the aesthetics much, just a bit different.
Profile PM Website
Peter Johnsson
PostPosted: Mon 21 Apr, 2014 1:47 am    Post subject:         Quote
Your choice to have a narrow flat midrib over a short length of the blade is a good one.
You can easily make this section longer by draw filing or sanding with emery paper on a hard block.
Since this kind of narrow flat is so narrow, you do not have to remove much material at all to make it longer.
In fact, you may find it easiest to save this adjustment to after heat treat, saving this to last few steps after the main bevels are well established and the edges just about sharp.
Then you can reestablish the narrow flat midrib with a sanding block.
Profile PM Website
Lukas MG
PostPosted: Mon 21 Apr, 2014 2:16 am    Post subject:         Quote
That's good advise, thanks. The blade is still a bit too thick over almost the entire length so it's shouldn't be a problem to lengthen (and widen) the flat section a bit. Doing some of that after heat treat is a good idea.
The problem I currently struggling with is how thick I want to have the blade in the upper half. Right now it's still 5.5mm where the CoP will fall. I originally planned to take it down to 4mm but am now considering leaving it thicker. I went through what data I have on originals and it seems 5mm isn't unusual for this type of sword. What do you think?
Profile PM Website
Lukas MG
PostPosted: Thu 24 Apr, 2014 7:31 am    Post subject:         Quote
So, progress! Finished grinding, now onto hand sanding.
Profile PM Website
Peter Johnsson
PostPosted: Fri 25 Apr, 2014 9:17 am    Post subject:         Quote
Don´t make it to thin. Leave it as it is!
You will want this blade to be fairly thick.
If necessary you can thin it down after heat treat.
Profile PM Website
Ian Hutchison
PostPosted: Fri 25 Apr, 2014 10:42 am    Post subject:         Quote
Lukas,
Even unfinished this blade looks incredibly lively. I think it will be a good one!
Lukas MG
PostPosted: Fri 25 Apr, 2014 1:29 pm    Post subject:         Quote
Thanks. Yes, that's what I figured, I left the blade as it was and am now almost done with hand sanding. I'll soon send it to the heat treater. Then I'll be playing the waiting game. At least partially, got the fittings to work on after all.
@Ian: Thanks. I sure hope so, it already feels quite alive in hand ;)
Profile PM Website
Julien M
PostPosted: Fri 25 Apr, 2014 1:39 pm    Post subject:         Quote
Very clean work!
Couple of questions:
How long does the heat treatment compagny take to do the job?
What happens if the blade warps? Do they know how to fix, straighten etc?
Why sanding by hand prior to sending to heat treatment?
J
Oh and last one: How did you put your process together? There are some nice and detailled tutorials on SBG by BBonzai and another one by Tinker. Just wondering if you started there.
Lukas MG
PostPosted: Fri 25 Apr, 2014 10:59 pm    Post subject:         Quote
Well, it's not a heat treat company but a knife- and swordsmith here in Germany (one of only a few and the only one offering that service). How long it takes depends on when he has enough blades to make heating up the salt baths worth it. I talked to him yesterday and he told me 1-2 months. I wouldn't bet on it though. Patience is your friend ;)
He straightens the blades if they warp but I can also do it myself, done it a couple times. Really only need a vice and a torch. And good nerves :D Of course it's best done right after or in between tempering cycles.
Hand sanding is for me the best way to get the bevels truly flat. My belt sander does a decent job but there are always a few rough spots. Depending on the blade, I can get it about 90% done before heat treat, salt baths are pretty great as there's very little or no decarb I need to grind off. Edges can be almost sharp (though that leaves little room for error and I prefer going a bit thicker, usually 1mm).
My process has developed over the last few years and only now do I think I have got to a point where everything pretty much fits. It was mostly trial and error but I asked plenty of questions in Don Fogg's forum and SBG to take a shortcut ;) . BB's tutorial had a few nice pointers as well.
Profile PM Website
Lukas MG
PostPosted: Sat 26 Apr, 2014 12:55 pm    Post subject:         Quote
So, I finished hand sanding and the blade is now ready for the heat treater. I just talked to him on the phone and he said it'll be 1-2 months until he can get to it, so from now on, progress will be slow.
I had a bit of trouble picking the right guard. First I decided on downturned quillons and had the guard already forged out when I realized I wasn‘t happy with the design. I spend some time not being able to make up my mind when I remembered that I had a guard that used to be on a VA Kriegsschwert in my spare part collection. I picked it up and immediately knew it work wonderfully with some modifications. I reground the facetts to get rid of waviness (there was lots of it... also a very sloppy guard inlet and way oversized tang hole, both I'll fix by filling with weld). Then the side rings were made from 3mm steel.
Next step is welding on the side rings, then I'll go over everything with sandpaper and file to get things perfectly shaped.
Since the blade is close to final shape and I know the guard weight, I can now calculate the pommel weight. I do that by taping the guard in its future place and adding metal weights to the tang end where the pommel will sit until I like the feel and harmonics like pivot points and percussion nodes fall into place. This one needs a pommel weight of about 300g. Now comes the hard part, figuring out how big of a pear shaped pommel I need to get the needed weight. Gah, I hate math ;)
Profile PM Website
Dean F. Marino
PostPosted: Sat 26 Apr, 2014 1:32 pm    Post subject:         Quote
Lukas MG wrote:
So,....Since the blade is close to final shape and I know the guard weight, I can now calculate the pommel weight. I do that by taping the guard in its future place and adding metal weights to the tang end where the pommel will sit until I like the feel and harmonics like pivot points and percussion nodes fall into place. This one needs a pommel weight of about 300g. Now comes the hard part, figuring out how big of a pear shaped pommel I need to get the needed weight. Gah, I hate math ;)
Don't forget what I always forget.... slap a little WOOD, temporarily, onto the grip portion of the tang. It's light, but with leather, will contribute to your overall POB :).
Lukas MG
PostPosted: Sat 26 Apr, 2014 2:30 pm    Post subject:         Quote
I never calculate in the handle because when I decide on the pommel size, I take the needed weight (300g) for the pommel and then later drill the hole for the tang so the pommel ends up a little lighter. In the end, it normally comes out close enough. Occasionally I will regrind the pommel a bit or insert small pieces of metal into the handle but that hasn't been necessary more than once or twice. It's also not necessary to hit exactly 300g, there's a bit of leeway.
Profile PM Website
Zach Luna
Likes: 11 pages
PostPosted: Sun 27 Apr, 2014 8:14 am    Post subject:         Quote
As I said on SBG, this is looking spectacular, Lukas.
Math at the outset: convert the 300g of steel into a known volume of steel, then find the weight of an equivalent volume of clay or wax. Then you can play around with shapes in your sculpting medium and easily add or remove material to get the right volume by checking your new 'equivalent' weight on the scale. Once you're happy with the pear shape, then you can go back in and take measurements of your sculpted model to reproduce it in steel. That way you only have to do calculations at the beginning and take measurements at the end. You don't need to be bothered with trying to calculate the volume of different sized pear shapes.
Profile PM Website
Leo Todeschini
PostPosted: Sun 27 Apr, 2014 1:28 pm    Post subject:         Quote
a ratio of steel to wax density is around 10:1
Great work so far - keep it up.
www.todsworkshop.com
www.todcutler.com
Profile PM Website
Lukas MG
PostPosted: Sun 27 Apr, 2014 1:42 pm    Post subject:         Quote
Thanks guys.
As I said on SBG ( :) ), that is way more elegant that my rough estimation followed by "I'll just make it a bit bigger and grind off material until it's right" :D
Profile PM Website
Zach Luna
Likes: 11 pages
PostPosted: Sun 27 Apr, 2014 5:39 pm    Post subject:         Quote
Lukas MG wrote:
Thanks guys.
Haha, right on, man. Looking forward to seeing this one come together!
Profile PM Website
Page 1 of 3 Reply to topic
