Kristoffer K
Posted: Tue 05 Nov, 2013 2:50 am Post subject: Searching for sources of two handed maces |
Hello guys
I am searching for sources for two handed maces being used by Eurasian Nomads in XIII-XV century..
I have seen some with long cavalry maces wielded in one hand with no shield in the other, but I would really appreciate it if anyone would share any source, where it is clear that the mace wielded is two handed..
Here is what I got already:
Attachment: 101.59 KB
Kristoffer K
Posted: Tue 05 Nov, 2013 2:53 am Post subject: |
Another one:
Best regards
Kristoffer
Attachment: 70.9 KB
Kristoffer K
Posted: Tue 05 Nov, 2013 2:57 am Post subject: |
Last one..
Attachment: 231.5 KB
Posted: Tue 05 Nov, 2013 3:56 am Post subject: |
Speculative drawings can't be used as evidence. You need physical examples. An extant mace head that weighs 2kg or more is likely to be from a two-hander (unless it is a ceremonial mace). Manouchehr's book has a Persian example that is 101cm in length and weighs 2910g.
Kristoffer K
Posted: Tue 05 Nov, 2013 7:24 am Post subject: |
I know these drawings doesn't prove anything, that is why I came here in hope of someone else having knowledge about some known documentation. Most sources on the subject is in russian, and I can't read that..
Good tip on the weight of the mace head. I will try to look that book up.. Thank you.
Eric S
Posted: Wed 06 Nov, 2013 6:13 pm Post subject: |
You would be looking at something like this Indian two handed mace.
Indian sonta (a long club like mace), a very massive and heavy solid steel weapon at 37 inches in length and 8 lbs in weight, the entire shaft is carved with a spiral twist for its length and bands at intervals originally inlaid with brass, each face of the eight faceted head carved with repeating tendril and leaf design, a loop at the opposite end for attaching a strap, weapons such as this were used in India from medieval times, showing great age, possibly 16th to 17th century or older.
