Thomas R.
Posted: Thu 20 Sep, 2012 8:40 am Post subject: |
HI Sean,
that's a good advice! I have such a plunge router thingy and it works very good for small pieces, like a grip. For bigger projects, like a scabbard, I find it too messy. The bit then gets hot really fast, especially if you try to do the whole depth in one go. After a third of one scabbard halve, I got back to using my chisel.
For safety use goggles and a breathing mask (and earplugs, if you like). It's really messy and loud, working with this thing.
Thomas
Tom King
Posted: Thu 20 Sep, 2012 8:48 am Post subject: |
I've actually been thinking of buying one of the dremel dry wall cutting mounts for this purpose, but this is obviously much better. Cutting out crossbows and grips without access to a CNC machine can be a pain, and routers are expensive. This is a nice middle ground in price and functionality.
Christopher Treichel
Posted: Thu 20 Sep, 2012 9:12 am Post subject: |
I have both a dremel and the router attachment... but honestly I prefer using my paring chilsels and offset paring chisels.
John Giles
Posted: Thu 20 Sep, 2012 10:49 am Post subject: |
Great advice! I'm just starting to tinker with making my own grips, so this info is very timely!! Thanks!
True Courage is about knowing not when to take a life, but when to spare one.
T.F. McCraken
Posted: Thu 20 Sep, 2012 11:53 am Post subject: |
I have it down to an art. I can mark, core, glue and shape a wood core in about 2 hours. I've tried the plunge router avenue, but, I think if I made a jig it would work better. As it stands now, it's all done with a Dremel and a drum sanding bit. Then a palm sander to smooth.
Thanks for the tip Sean!
Murphy :cool:
aka "Murphy"
See ya at Bristol Renaissance Faire!
The decisions we make, dictate the life we lead.
"I drank what?" -Socrates
www.celticfuryproduction.com
Posted: Thu 20 Sep, 2012 12:29 pm Post subject: |
That is probably the difference... I collect antique tools and use them. That includes very nice paring chisels which I keep honed with rouge. Comparing these to the ones you could buy these days at home depot is like comparing apples and oranges. A sharp chisel is well and capable of cutting through rock hard maple sideways. My dremel on the other hand starts to chatter and you have to make many passes. I also use inletting black and think a good fit should be really tight such that the peen on the end of the pommel is not the only thing holding the weight of the blade. So its all nice and snug.
Matthew Bunker
Posted: Thu 20 Sep, 2012 11:40 pm Post subject: |
I just use a proper, grown-up Bosch plunge router (which is the scariest hand held power tool known to man) for mass clearance and then finish with a shallow scorp and a cabinet scraper.
