Hal Siegel
Posted: Tue 01 May, 2012 8:08 pm Post subject: Shrinkage |
No, not a man-in-cold-water problem: a leather scabbard.
I have a newly made sword stuck fast in a leather sheath. If this were an old sword I'd expect corrosion, but since it's new and the sheath is unfinished leather I expect it's a shrinkage problem.
Simply tugging it out isn't working.
Any suggestions?
Hal Siegel - TherionArms
http://www.therionarms.com
http://www.facebook.com/TherionArms
Lloyd Winter
Posted: Tue 01 May, 2012 8:20 pm Post subject: |
That happened to me once. I finally ended up cutting the scabbard open. If you're lucky the sword is stuck at the top and you only have to open part of the seam. I was not so lucky...
Ralph Grinly
Posted: Tue 01 May, 2012 10:30 pm Post subject: |
Well..you *could* try this..if you're game. Try wetting ( damp..not dripping wet) the sheath..that should soften it a bit and let it stretch so blade can be withdrawn. Clean/oil blade IMMEDIATELY you get it free. If it doesn't come free..then I'd cut the stiching, working slowly from the throat, working down until it finally comes free. You didn't mention if there were any metal fittings at the throat ? Whatever happens..clean sword asap...
Matthew Bunker
Posted: Wed 02 May, 2012 6:39 am Post subject: |
Cut the stitching. It's the quickest method and, as the scabbard is clearly too small for the sword, it's not like you need to be worried about using it again.
Gary Teuscher
Posted: Wed 02 May, 2012 7:22 am Post subject: |
Oh, I thought this was referencing a Seinfeld episode :D
Kel Rekuta
Posted: Wed 02 May, 2012 8:23 am Post subject: |
Squirt some neatsfoot oil on each side between the blade and sheath, opening with a small plastic putty knife or even a disposable picnic knife. Stand it up in somewhere and ignore it for a few hours. The leather was probably very dry.
You could also squirt hot water down the gap instead then yank that sucker free while the sheath is wet. That will take some serious followup on the blade by comparison. Depends on how patient you are.... :lol:
Posted: Wed 02 May, 2012 8:30 am Post subject: |
How about hitting the scabbard gently with a rubber or wooden mallet and hoping the vibrations un-stick the areas holding the sword in the scabbard if it's some sort of adhesion rather than just shrinkage.
Would putting the whole thing in a freezer have the steel contract enough to detach itself from any adhesions ?
Well, if the scabbard can't be salvaged cutting the sword out makes things a bit simpler.
If the scabbard and sword are separated from each other without damage to the scabbard it would be good to make sure that the scabbard can be " fixed " before risking putting the sword back in it. ;) :D
Josh Wilson
Posted: Wed 02 May, 2012 10:15 am Post subject: |
| Jean Thibodeau wrote: | | If the scabbard and sword are separated from each other without damage to the scabbard it would be good to make sure that the scabbard can be " fixed " before risking putting the sword back in it. ;) :D |
This could possibly be done with a leather skever (sp?) tool, if you end up cutting the seam.
Johan Gemvik
Posted: Wed 02 May, 2012 3:30 pm Post subject: |
Medieval swords usually had wood cores for this very reason.
If you know the basics of wood- and leatherworking you can make one yourself, maybe even line it with lambs pelt or wool. IMO it's a great way to learn more about how swords work.
Is this a welted seam? Most modern all leather sword scabbards are.
Anyway, if you prefer an all leather scabbard you can cut the stitches, and then add a leather tounge as a spacer between the seam sides all the way down and re-stitch. This'll make it less tight.
