Forum Index > Historical Arms Talk > Arrows vs armour Reply to topic
This is a Spotlight Topic Go to page Previous  1, 2, 3 ... 18, 19, 20, 21  Next
PostPosted: Wed 28 Mar, 2012 10:27 am    Post subject:         Quote
Jojo Zerach wrote:
Matt Easton wrote:
Jojo Zerach wrote:
Since the effigy is supposed to represent a person, you'd want the face visible.
Hi Jojo, I think you misunderstood me. Any nationality example will show the face, but French and German effigies and brasses, for example, often show a raised visor or the attachment points for the visor. English examples in contrast almost never do - the two examples you found, and that of the Hastings Brass, are rare exceptions.
This leaves the question as to why - my 3 possible reasons above are responses to that question. A fair number of academics have concluded that English bascinets often were not fitted with visors at all.
Matt
It's probable that the sculptors simply didn't bother to depict the visor or it's mount. The same way they didn't show buckles, hinges and rivets. Some effigies show these elements, but a lot don't.
As you mentioned with lance rests. (I'm only aware of 1 English effigy from the 14th century showing a lance rest, but they were probably commonplace.)
Well the early Bascinets where worn under the Great Helm, and if the custom of using them under the great Helm continued longer in Britain than on the continent, it's probable that the English Bascinets would not have provisions for mounting a visor ?
Randall Moffett
PostPosted: Wed 28 Mar, 2012 12:03 pm    Post subject:         Quote
I sort of doubt it was used longer. By the 1320s and 1330s they are being largely replaced by bascinets. By mid century I have found only a few used in real war of scores and scores of accounts. My guess is this was more a consideration 1320s and earlier.
William P
PostPosted: Thu 29 Mar, 2012 2:43 am    Post subject:         Quote
well visored bascinets design, particularly the cone snouted hundskulls,
are particularly good at saving you from arrows to the face and definately one of the better designs for this purpose
the snouted visor would increase the chances of an arrow simply glancing off, and unlike great bascinets with rounder visors, would have less impact transferred from arrows flying at you and the eye holes, are , as far as i understand slightly protruding from th surface of the helm increasing the distance a arrow has to go to hit your eye,
this is contrasted with the fact the nature of the visor maybe means that you have to expose your whole face to see a lot, which, if im not mistaken, led to a LOT of arrow related deaths which boil down to people lifting the visor to see/ breathe, and having an arrow hit them in the face while doing so.
Profile PM E-mail
Timo Nieminen
PostPosted: Thu 29 Mar, 2012 12:01 pm    Post subject:         Quote
The "protrusion" of the eye slots is to stop the snout from guiding things straight into your eye slot. Nice pointy snout, arrow or sword thrust or lance thrust hits, and slides, and the point goes in the eye slot. The raised lip stops this. The cheapest Indian repros don't have these lips. If one is available, try it and see.
Some have a protruding top edge, some don't. It's interesting to see that some helmets don't have this type of feature. Some of these get similar guiding-to-the-eye-slot protection just from the shape of the front surface. Others don't. Bad design?
Profile PM Website
Benjamin H. Abbott
PostPosted: Tue 03 Apr, 2012 7:30 pm    Post subject:         Quote
I'll throw out a source that I haven't seen cited before in these debates. As part of a 1527 book of military advice, Jacopo di Porcia wrote the following: "Fotemen with bowes, whych englysh men vse: do greate seruyce in an host. For there is no breste plate, whyche is able to wythstand, and holde owte the stroke of the arrowes, suche force and vyolence is in bowes." I seriously doubt English bows could pierce decent-quality breastplates in the early sixteenth century, but I figure this text deserves a place in the mix.
PostPosted: Tue 03 Apr, 2012 8:02 pm    Post subject:         Quote
May as well include Francis Bacon's claim that Turkish arrows could pierce 2 inches of brass.
Nat Lamb
PostPosted: Tue 03 Apr, 2012 9:41 pm    Post subject:         Quote
That little tidbit of information seems like a good indicator of the resailiance of plate armour to arrows. If arrows can pierce plate willy-nilly, why the disproportionate number of facial injuries?
William P
PostPosted: Tue 03 Apr, 2012 10:29 pm    Post subject:         Quote
also at crecy in particular, what KIND of shield was used by the men at arms and how OFTEN were they used
and what kind of shields were men at arms, particularly ones dismounted to fight on foot, use around the time of agincourt?
ive also seen this suggested to me quite often,. to do a rough test of the effect of arrows on armour, get a dummy of wax or ballistics gel, stand him up, put him in a reasonable approximation ofa harness of the period or even 2 or more dummies in a variety of armours for example, a crecy armour side by side with an agincourt armour
, and have archers plug arrows at the dummy at successively closer ranges, i.e start at 200-150m, shoot a number of arrows assess the effect, then move closer by certain intervals.
this primarily would be to test the agreed phenomenon of the fact that a large number of arrows fired at a host, increases the chance of hits sliding into armpits through vision slits etc.
one guy shooting at reletively close range at a target doesnt give much of an idea of the group mechanics of a cloud of arrows striking a target
or of arrows raining down onto a target in terms of parabolic arc fire,it would also assess the grouping of arrows at longer ranges, although that factor isnt as hard to quantify
the only issue with adummy in a harness, is that a dummy lacks certain normal movements which might suddenly expose elements like the face, the armpit, the throat etc. i.e the normal movement that rocks the arms back and forth during walking, the sudden raising of the visor.
in australia, the greco roman society the sydney ancients conducts a similar experiment during their battle of marathon reenactments every couple of years inviting people to bring along a bow and safety arrows, (though due to safety regulations, of combat archery, the bows could only have a maximum poundage of 30lb's and arrows were rubber combat archery blunts) and shoot at a column of hoplites as they advanced, to assess the frequency that arrows would hit vital areas i.e legs arms, heads etc. iin 2011's reenactment, there was about 16-20 archers and 16 hoplites
the archers made VERY few direct hits on any part of the hoplites legs were hard to hit, shots to the helmets often just glanced off, andthe rest of the body was protected by shields.
Profile PM E-mail
Aleksei Sosnovski
PostPosted: Wed 04 Apr, 2012 11:40 pm    Post subject:         Quote
Actually a dummy might be easier to hit in a "vital" area. People who know about weaknesses of their armor tend to protect these weaker areas. Like keeping their heads down and their hands close to their bodies, maybe even protecting their armpits with their vambraces.
Profile PM E-mail
Benjamin H. Abbott
PostPosted: Thu 05 Apr, 2012 6:54 am    Post subject:         Quote
Sounds good. Does that also come from a military manual?
Ben P.
PostPosted: Thu 05 Apr, 2012 7:09 am    Post subject:         Quote
That's a good point and what about the wearer's goussets?
William P
PostPosted: Thu 05 Apr, 2012 7:16 am    Post subject:         Quote
the dummy would, as a matter of course, be wearing the appropriate underarmour garmets i.e aketon with maile underneath, althouhg at both crecy and agincourt, maile shirts i understand were wonr under plate
Profile PM E-mail
PostPosted: Thu 05 Apr, 2012 1:02 pm    Post subject:         Quote
Francis Bacon never set foot on a battlefield and likely never laid eyes on a Turkish archer.
http://en.wikipedia.org/wiki/Francis_Bacon
The point of including him was to show that not all sources should be treated equally. Quite clearly it is impossible for any bow to shoot through 2 inches of brass.
Matt Easton
PostPosted: Thu 05 Apr, 2012 2:23 pm    Post subject:         Quote
If it is in a molten state.... :p
Schola Gladiatoria - www.swordfightinglondon.com
YouTube: www.youtube.com/user/scholagladiatoria
Antique Swords: www.antique-swords.co.uk/
Profile PM Website MSN
Glen A Cleeton
PostPosted: Thu 05 Apr, 2012 2:41 pm    Post subject:         Quote
Oh my, aren't we all a bit better than offering up a Wikipedia page to outline a historical figure?
GC
Jojo Zerach
PostPosted: Thu 05 Apr, 2012 3:49 pm    Post subject:         Quote
GC
On some subjects, I notice most websites are simply copied from Wikipedia.
Benjamin H. Abbott
PostPosted: Thu 05 Apr, 2012 7:09 pm    Post subject:         Quote
Indeed. But the quotation I posted comes from a military manual and isn't nearly as outlandish as Bacon's claim. I still think it's wrong, but I'm curious why a seemingly serious author had this impression of English bows. Jacopo di Porcia had military experience in Italy during the War of the League of Cambrai in the early sixteenth century. It's unlikely he'd seen any English archers in action in Italy during this period, so it's possible he based his opinion on literary sources or hearsay.
Well, any bow drawn by hand.
PostPosted: Thu 05 Apr, 2012 7:17 pm    Post subject:         Quote
It covers the essential points well enough for this thread. IIRC the Turkish arrrow passage comes from his Historia Naturalis
Bartek Strojek
Likes: 23 pages
PostPosted: Fri 06 Apr, 2012 1:51 am    Post subject:         Quote
I would actually guess that at least with any arrow with a lot of wooden parts, one would probably need way more solid projectile to have a chance to put it trough something as substantial as 2 inches of brass...
Even solid point would probably get stuck real quick if energy got wasted for splitting the shaft into small bits.
William P
PostPosted: Fri 06 Apr, 2012 3:13 am    Post subject:         Quote
i get the feeling a .50 calibre armour piercing sniper round would maybe even have trouble penetrating that much brass.
Profile PM E-mail
Page 19 of 21 Reply to topic
Go to page Previous  1, 2, 3 ... 18, 19, 20, 21  Next All times are GMT - 8 Hours
