Forum Index > Off-topic Talk > Helmet padding Reply to topic
David Gaál
PostPosted: Sat 07 Jan, 2012 12:52 pm    Post subject: Helmet padding         Reply with quote
Hello,
I would be interested in what you know about the padding under helmets. How thick were they? Does this change through centuries? What was the most common for padding linen or leather? How common was fixing the padding in the helmet? And what are the average diameters of the helmets through centuries?
I have seen many helmets by reenactors and on films but some seem really thin others too thick.
Waiting for your answer.
David
David Gaál
PostPosted: Thu 12 Jan, 2012 11:44 am    Post subject:         Reply with quote
Anyone some informations to share?
PostPosted: Thu 12 Jan, 2012 12:03 pm    Post subject:         Reply with quote
This should be about right. I've researched this issue, too, and the recommendation that it be about as thick as a kitchen "hot pad" after quilting seems to work well. It really couldn't be much thicker if the helmet fits properly. The first image below shows the stitched lining on top and the un-stitched lining below. In both cases, I'm using four layers of organic cotton batting.
 Attachment: 144.93 KB
 Attachment: 159.82 KB
Elling Polden
PostPosted: Thu 12 Jan, 2012 12:07 pm    Post subject:         Reply with quote
In the high middle ages at least, the standard padding is a padded linen coif. Thuis can be of a two or three piece construction. In the 12th century, a round topped coif with a thicker "roll" around the head seems to have been popular.
In some of the depictions, the padding seems to be quite thick, but then again these show people going into battle without a rigid helmet.
Early helmets seem to have been quite thin and close fitting, later ones larger and with more padding. This could be seen in relation to armour replacing shields as the primary defence, and the greater numbers of swung weapons in the battle lines. (Early infantry fighting fighting more or less exclusively with shield and spear in the line.
David Gaál
PostPosted: Thu 12 Jan, 2012 12:25 pm    Post subject:         Reply with quote
Yes but what if they didn't fit properly, for example in the viking age iron was not a cheap thing and so helmets were worn through generations, but could this include that it were a bit oversize(?).
Do you know museum helmet sizes? I guess this could serve a lot.
PostPosted: Thu 12 Jan, 2012 12:29 pm    Post subject:         Reply with quote
I don't, but they are often smaller in person than they seem in photos, and mass-produced modern reproductions tend to be VERY large.
David Gaál
PostPosted: Thu 12 Jan, 2012 12:45 pm    Post subject:         Reply with quote
Could you please write it in cm how thick is yours? Would help more imagining it.
Thanks very much for your replay.
PostPosted: Thu 12 Jan, 2012 12:48 pm    Post subject:         Reply with quote
~6.35 mm (.635 cm). That corresponds to the figure of .25" I found from a reliable source.
David Gaál
PostPosted: Thu 12 Jan, 2012 1:02 pm    Post subject:         Reply with quote
Thank you. I have a linen coif that has almost the same measure so if I make helmets for that size it could be accurate. A bit weird that I am interested for such things for a while and only now have I only the idea of what if its wrong.
But is this thickness enough against a hit by a two handed weapon?
James Barker
PostPosted: Thu 12 Jan, 2012 1:53 pm    Post subject:         Reply with quote
From what I have seen most helmet liners are linen cloth with raw cotton padding. I based my liners off of these examples which you can see here: http://www.historiclife.com/Armory.htm
Thickness varies a bit but the hot pad description is the average.
James Barker
Historic Life http://www.historiclife.com/index.html
Archer in La Belle Compagnie http://www.labelle.org/
PostPosted: Thu 12 Jan, 2012 2:02 pm    Post subject:         Reply with quote
It was good enough for guys actually getting hit with swords, maces and halberds. It helps if the liner is a suspension as well as a padded defense.
Sam Gordon Campbell
PostPosted: Thu 12 Jan, 2012 9:37 pm    Post subject:         Reply with quote
It makes me wonder how thick padding was underneath something like an armet or close helmet.
I guess in relation to people using "too thick" padding, as pointed out in period padding wasn't what (well, at least I wouldn't) one would call thick, but that's because I assume they'd move around a lot more then people do today.
I've recently made a stuffed liner for a very particular style of helmet, I'll see if I can take pictures of it and post it. I fear it may be over kill a bit.
Edit: Okay, so, I can't get a camera any time soon, so I hope this crude picture will help convey what I mean.
 Attachment: 6.73 KB
Stuffed. 2cm thickness on average. [ Download ]
 Attachment: 48.66 KB
For this style. [ Download ]
Host of Crash Course HEMA.
Last edited by Sam Gordon Campbell on Fri 13 Jan, 2012 6:14 pm; edited 1 time in total
Len Parker
PostPosted: Fri 13 Jan, 2012 6:17 am    Post subject:         Reply with quote
Here is the Leiden spangenhelm
http://www.romanarmy.com/cms/component/option...Itemid,96/ If you click Remarks there's a mention of a 6mm thick leather cap that was found inside the helmet. At 188mm deep I'm thinking this helmet must have had a liner besides the cap or the helmet would sit too low.
Felix R.
Reading list: 25 books
PostPosted: Fri 13 Jan, 2012 6:41 am    Post subject:         Reply with quote
A good idea is to have some space between the liner and the helmet itself, so the the helmet and head are only close together at brow level. Then you won´t need much padding, any hit will be spread over the head, there is actually not much contact between the hit section of the helmet and the head itself.
David Gaál
PostPosted: Fri 13 Jan, 2012 12:07 pm    Post subject:         Reply with quote
I have seen some that could have thicker padding but couldn't say how thick. Siege armours from the 17th century could have thicker padding for example: http://www.antiqueweaponstore.com/Rare%20Germ...th%20C.htm (look at the breastplate)
But I haven't seen yet more thicker than 10mm. I think the average could be as Sean Flynt wrote.
Randall Moffett
PostPosted: Sat 14 Jan, 2012 7:13 am    Post subject:         Reply with quote
I have seen padding in authentic helmets from 1/4 to near 7/8. I have seen them stuffed with anything from dried plant matter, cotton to what looks like bits of left over fabric. My Average is about 3/8 to 5/8 but depends on if this is a padded liner or a padded coif used with a leather or another liner suspension system.
The Black Sallet at the RA is actually very thick and in rather excellent condition considering its age
http://www.myArmoury.com/talk/viewtopic.php?t=5451
I had several 'siege' helmets from the 17th I took care of with padding and they do seem fairly padded. On had 3/4" of padding even down to the face which must have been rather warm and part of the padding looked to be made of weeds and hay for padding.....
