Forum Index > Makers and Manufacturers Talk > Bauernwehr Reply to topic
Fabrice Cognot
PostPosted: Fri 22 Oct, 2010 12:36 am    Post subject: Bauernwehr         Quote
Hi all
I've been away for a while, I know. I've been busy, but I also had the chance to meet some of the regular folks here 'in real life'.
....and now I'm back. With this little thing available :
A Bauernwehr. Late XVth century.
This piece is based on several models, but the main inspiration is a river-found knife kept at the Musée Denon in Châlon-sur-Saône, long (mis)identified as a "hunting knife" - though features from another knife in the same collection also appear on this re-creation.
As you all know, the Bauernwehr was very common in Germany, but several archaeological finds tend to indicate that their presence was far more widespread over Western Europe - the Châlon models were indeed found in the river Saône, and elements of knives of this type have also been found in the British Isles.
Most original Mediaeval knives show a composite construction, with a steel edge welded on an iron 'core' - thus saving the precious, expensive steel for the parts it would be the most useful. As steel is cheaper nowadays, the blade here is fully made of 1075 (XC75) Carbon steel, but I still wanted to keep as close to the original properties of Mediaeval knives, and went for a differential temper. Thus the edge area would be hard while the back would remain softer. You can see the temper line on one of the pics.
The short back edge is sharp, and was ground in as was the common practice at the time.
The main element that was borrowed from knife 83.19.1 of the Denon Museum is the handle and its very specific construction : four parts of wood on each side, separated by several strips of thin brass foil that also serve as spacers between the scales and the tang itself. Or in other words : the brass foil form some kind of 'casing' around each piece of wood. For instance, on the long, horizontal wooden parts, a first strip sits between the tang and wood, and is folded 90° to also serve as a spacer betwen the upper and lower wooden parts - and the same goes for the latter (lower) part.
Studying the original examples also show the shortcuts they used at the time - so there was no reason I should be ashamed of doing the same. Therefore instead of drilling or punching individual holes in these straps for each of the rivets, thin bands were cut off where the said rivets would be.
The rivets themselves are fancier than on the original. I opted for mosaic pins with a triangular pattern very popular in the late XVth century, especially on weapons. They were made of 4 mm diameter brass tubing with steel nails inserted - but each of them had to be filed to measure, as there were no nail of the adequate diameter commercialy available to me.
I gave the Nagel a fileworked, flowery shape to echo the shape of the brass flower on the other side. On knife 83-19-1, only the latter remains, but a strong, square-section (and broken) rod is still clearly visible coming through the tang from his flower. The brass bolsters and large 'pommel' rivet are a direct copy of 83-19-1, though the end brass plate is slightly larger (yet heavily inspired by...).
A by-knife, with the uppermost rivet also given this trifoil shape, serves as a companion to this Bauernwehr. Walnut wood was used on both knives for its rich, dark brown colour.
The scabbard is vegetable, naturally-coloured, hand-tooled leather.
It's available at 590 € plus shipping.
 Attachment: 95.88 KB
 Attachment: 99.44 KB
 Attachment: 116.38 KB
PhD in medieval archeology.
HEMAC member
De Taille et d'Estoc director
Profile PM Website
Likes: 29 pages
Reading list: 327 books
Spotlight topics: 32
(12 total ▮ 100% positive)
PostPosted: Fri 22 Oct, 2010 12:41 am    Post subject:         Quote
That is extraordinarily gorgeous.
I'd also like to compliment you on your descriptive text. Thank you for taking the time to not only provide context, but also for the educational opportunity.
Well done all around.
Profile PM E-mail Website
Fabrice Cognot
PostPosted: Fri 22 Oct, 2010 2:44 am    Post subject:         Quote
Thanks Nathan. :blush:
A few precisions : overall dimensions are : 13.3" length ; blade is 8.3" long and 1.1" wide. Photographs are by Laure Bornier.
HEMAC member
Profile PM Website
Matthew Stagmer
PostPosted: Fri 22 Oct, 2010 4:56 am    Post subject:         Quote
Beautiful work Fabrice. Looks like it was taken out of a museum. Well done indeed! Thanks for sharing.
Matthew Stagmer
Youtube.com/ThatWorks
Profile PM Website
PostPosted: Fri 22 Oct, 2010 6:00 am    Post subject:         Quote
Stunning!
Profile PM Website
Julien M
Ravissant Mr Cognot!...that must be the best I've seen from you so far.
Julien
Paul Hansen
Likes: 5 pages
PostPosted: Fri 22 Oct, 2010 7:46 am    Post subject:         Quote
Really nice work Fabrice! :cool:
Leo Todeschini
(3 total ▮ 100% positive)
PostPosted: Fri 22 Oct, 2010 10:33 am    Post subject:         Quote
I will join the queue - Lovely work. A very nice piece.
Good to meet you this summer and as you say meet you in real life.
Fabrice Cognot wrote The rivets themselves are fancier than on the original. I opted for mosaic pins with a triangular pattern very popular in the late XVth century,
other than cinquedea I cannot think of a mosaic pins, were these common on knives and swords? I must have just missed them, but that is a lovely way to decorate a piece and a great choice to make on your part.
Really well done
www.todsworkshop.com
www.todcutler.com
Profile PM Website
Peter Lyon
Reading list: 39 books
PostPosted: Fri 22 Oct, 2010 10:42 am    Post subject:         Quote
Gorgeous. I look forward to seeing more of your work.
Still hammering away
Hadrian Coffin
(2 total ▮ 100% positive)
PostPosted: Fri 22 Oct, 2010 11:13 am    Post subject:         Quote
Hello,
Looks absolutely lovely!
I have a bauernwehr in my collection 15th century found in Yorkshire, England.
Best,
Hadrian
Historia magistra vitae est
Profile PM YIM
Fabrice Cognot
PostPosted: Fri 22 Oct, 2010 11:26 am    Post subject:         Quote
Oh, you are absloutely right : as you say they were more than rare - in fact apart from a few late period roundel daggers or long knife pommels, and a few concentric pins (ie a bar in a tube) these are practically unknown.
But the original plain rods would have been, well, too plain :p . And I wanted to give this knife a special feature that I could repeat on the by-knife, without going for end caps or pommels (as I quite liked the shape of the final brass plate on the original).
And thanks for the kind words - to all :)
HEMAC member
Profile PM Website
