Boris Bedrosov
Posted: Wed 18 Aug, 2010 11:36 am Post subject: The Shield - Continues |
Meanwhile, there is also a progress with the shield. Recently, I riveted the leather handling straps and the loops for the caring ones; covered the front surface with the second layer of heavy linen and painted the back in blue.
The result looks like this:
Tokugawa Ieyasu
Find my works on Facebook:
Boris Bedrosov's Armoury
Boris Bedrosov
Posted: Wed 18 Aug, 2010 12:03 pm Post subject: |
Now, with handling straps permanently attached alongside the short diagonal, I am able to insist that this type of shield is one of the best for infantry combat (of course, considering my own experience - round, heater and middle-sized kite) - agile, easy for handling and offering very good protection.
Tokugawa Ieyasu
Boris Bedrosov
Posted: Thu 26 Aug, 2010 11:51 am Post subject: The Shield - Continues |
My intention was to create a relatively simple, but still quite "Islamic" design for the front part of my shield.
After discounting some ideas, my choice is this one:
where the central image is the Zulfikar (or Zulfiqar), a.k.a. Saif al-Ali - the legendary two-bladed sword, belonging to both the Prophet Muhammad and his son-in-law Ali.
The picture itself was directly taken from authentic Ottoman shield, displayed in the Metropolitan Museum.
For the outer edge I chose one of the most typical Islamic designs - the vine stem pattern
And a closer view:
Tokugawa Ieyasu
Last edited by Boris Bedrosov on Sat 04 Sep, 2010 1:05 pm; edited 2 times in total
Boris Bedrosov
Posted: Thu 26 Aug, 2010 11:56 am Post subject: The Shield - Continues |
And the painting began.
Here is the result of the first layer of the silver and golden paints, put over the outer edge
Tokugawa Ieyasu
Boris Bedrosov
Posted: Fri 27 Aug, 2010 12:01 pm Post subject: The Cuisses - Continue |
The upper sections of the cuisses somewhere in the middle of the working process
and closer view
Tokugawa Ieyasu
Samuel Bena
Posted: Sun 29 Aug, 2010 4:45 am Post subject: |
Very nice work so far Boris!
I especially look forward for the winged "deli" shield ....it sure starts to look awesome
Good luck!
Boris Bedrosov
Posted: Sun 29 Aug, 2010 10:17 am Post subject: The Cuisses - Continue |
Today the upper sections were finished. Now, they look like this:
Tokugawa Ieyasu
Boris Bedrosov
Posted: Sat 04 Sep, 2010 12:01 pm Post subject: The Cuisses - Continue |
And here the knee-cops are - polished, drilled, blackened - ready for next step:
Tokugawa Ieyasu
Boris Bedrosov
Posted: Sat 04 Sep, 2010 1:04 pm Post subject: The Cuisses - Continue |
And the next step is to rivet these two medallions:
and another (slightly different) view:
The inscription on the right means "Allah", while this on the left - "Muhammad". As far as I know, in Islamic tradition when both medallions are placed in this order (which can be seen in virtually every mosque), they bear the meaning of the phrase "There is no God but Allah, and Muhammad is His messenger".
And at the end I want to apologize to every fellow of Islamic faith for any mistake, which I may have made as a Christian who just has some interests on other religions. Every mistake is UNINTENTIONAL
Tokugawa Ieyasu
Luke Zechman
Posted: Sat 04 Sep, 2010 4:33 pm Post subject: |
Boris,
I have been following this thread eagerly. I really cannot wait to see the entire kit assembled. You do fine work, and should be proud. I think this kit is going to look top notch. Keep up the great work.
János Sibinger
Posted: Sun 05 Sep, 2010 4:09 am Post subject: |
Fantastic Job!
The brass elements, the blackened knee cops and the shield, especially the ornaments on the edge...
Simply beautiful!
Congratulations!
And just a short question if I may ask: what did you use to achieve this dark colour?
Best wishes!
John
Boris Bedrosov
Posted: Sun 05 Sep, 2010 11:53 pm Post subject: |
Janos,
To achieve this dark colour, I heat the steel plate with a propane torch until it starts to turn blue, submerge it for a while in fine engine oil and after that - allow it to cool in the air.
If someone wishes, the process could be repeated several times
Tokugawa Ieyasu
Last edited by Boris Bedrosov on Tue 07 Sep, 2010 10:26 am; edited 1 time in total
Boris Bedrosov
Posted: Tue 07 Sep, 2010 12:52 am Post subject: The Cuisses - Continue |
The medallions are riveted on the knee-cops.
Tokugawa Ieyasu
Boris Bedrosov
Posted: Tue 07 Sep, 2010 12:57 am Post subject: |
To János Sibinger:
When heating the plates, do this cautiously. Take care not to overheat the steel, because the resulting cover (when overheated) is not quite durable.
You can see this on the upper part of the right knee-cop, where the cover has gone on some spots.
Tokugawa Ieyasu
Boris Bedrosov
Posted: Tue 07 Sep, 2010 4:11 am Post subject: The Cuisses - Continue |
These
are the triangular section of mail which will be attached to the bottom contour of the knee-cops.
Tokugawa Ieyasu
Boris Bedrosov
Posted: Tue 07 Sep, 2010 4:13 am Post subject: The Cuisses - Continue |
Both knee-cops and triangular sections before
and after
the assembly.
Tokugawa Ieyasu
János Sibinger
Posted: Tue 07 Sep, 2010 10:18 am Post subject: |
Boris, thank you for the new pictures, and for the quick replies!
The knee cops look really great, and they will be even better as there will be contrast between the lower and higher areas.
Thank You again for the instructions!
John
Boris Bedrosov
Posted: Fri 10 Sep, 2010 9:50 am Post subject: The Cuisses - Continue |
The upper sections of the cuisses with straps and buckles attached
Tokugawa Ieyasu
Tibor Szebenyi
Posted: Sat 11 Sep, 2010 7:15 am Post subject: |
Great work, Boris!
I'm also working on similar cuisses, to where will be the buckle on the top of the cuisse attached? I mean where will a strap for it hang from? This question was on-topic some time ago, but we couldn't decide it. From an additional belt under the torso armour?
