Forum Index > Off-topic Talk > The accuracy of the ARMA warhammer test/Plate vs warhammer Reply to topic
Ben P.
PostPosted: Fri 02 Apr, 2010 8:56 pm    Post subject: The accuracy of the ARMA warhammer test/Plate vs warhammer         Quote
Okay I guess the title says all, anyways I got involved in a discussion on the ARMA warhammer test against an armet, here: http://www.thearma.org/forum/viewtopic.php?p=36838#36838
So I need some info about plate (specifically Maximilian) against warhammers.
And, how accurate was the ARMA Armet against warhammer test?
The link is here: http://www.thearma.org/photos/Gathering03/testcutting.htm
Daniel Staberg
PostPosted: Fri 02 Apr, 2010 11:39 pm    Post subject:         Quote
For one thing the claim that modern steel is just about always better than period steel is just nonsense, modern steels are made in a huge range of qualities some of which are better and some of which are worse than period steels.
As far as armour is concerned the hardness rating is one of the key factors, thetesting done on armour used the Vickers test som the number given is using that scale (VPH). Hardend Italian armour had a hardness range of 300-400 VPH, hardend German armour 400-500 VPH. By comparison modern mild steel rates 100 VPH, unhardend tool steel 250 VPH and hardend tool steel 500-600 VPH. Much, indeed perhaps most reenactment armour is made using mild steel because it is easy to work. Even the armour which is made of better steel is seldom hardend because of the cost and skill that requires. So any test done without a clear description of the steel quality and it's actual hardness is worthless,
all to often this kind of back yard testing involve hitting inferior armour with fairly high quality weapons.
Artis Aboltins
PostPosted: Sat 03 Apr, 2010 12:30 am    Post subject:         Quote
Some nice stuff on the images - I am sure they had ton of fun dooing all that!
However, I noticed something strange regarding to their test pictures:
http://www.thearma.org/photos/Gathering03/tes...ting05.jpg
title on this one says "Tim Sheetz in armor with an arming sword cuts at a bascinet". IMO, the helmet at the picture does not really look like bascinet?
Sander Marechal
Reading list: 17 books
PostPosted: Sat 03 Apr, 2010 1:35 am    Post subject:         Quote
Nope, that looks very much like a burgeonet.
Profile PM E-mail Website
Allan Senefelder
PostPosted: Sat 03 Apr, 2010 3:26 am    Post subject:         Quote
Its an old Valentine 18 gauge close helmet with no visor. Mr.Valentine sent a few seconds to the event pictured to beat on.
Profile PM Website
PostPosted: Sat 03 Apr, 2010 4:19 am    Post subject:         Quote
Just for reference, this is a common type of "un-galvanized sheet metal" sold in the U.S. http://asm.matweb.com/search/SpecificMaterial.asp?bassnum=m4130r
Strength is roughly half to a third that of many tool steels. It does harden when cold worked, but I don't know what hardness cold plannished armour made of it would be.
Johan Gemvik
PostPosted: Sat 03 Apr, 2010 5:42 am    Post subject:         Quote
I wouldn't call it exactly nonense. Not being very scientifically exact for this sort of test yes, but usually it's the case today that modern steel is stronger, more resilient and with fewer imperfections than reneissance armour.
Hardness of a steel alone doesn't tell the whole story, they can be overhardened and then the'd be brittle. Look instead at Tensile strength. That factor is way up even in modern low grade plate, not to mention specialised alloys and hardening processes that weren't around back then. Also some steel may harden with age and isn't the same today as it was back then.
Steel today is made with modern electronic control of the furnace process, making every smelting and heating process perfect, that's not what it was like in medieval times, or even the early 1900s when temperature was still gauged by eye with the color of the metal. Even poor quality with modern standards would be far above average even in the high Reneissance and we can do things today in steel production they could only dream of.
Daniel Staberg
PostPosted: Sat 03 Apr, 2010 5:49 am    Post subject:         Quote
18 gauge= 1.27 mm, I can't recall I've to have read about a helmet skull that thin, closest is in the 1.4-1.5 mm range but those were all made from hardend steel. A helmet in 18 gauge mild stell would preform like low grade munitions armour but not nearly be close to the effectiveness of high quality armour.
Johan Gemvik
PostPosted: Sat 03 Apr, 2010 5:54 am    Post subject:         Quote
I could calculate some helmet thicknesses from weights of complete helments I have data on. But 1.27 does seem on the thin side. I'd have guessed most to be between 1.5-2 mm. depends on what type of helm, how exactly it was made. If a helmet is driven into complex shapes it would usually become thinner than otherwise, or thinner is certain spots and thicker in others. When you shape the steel you can control this to a certain degree if you're an accomplished armourer. Modern replicas sometimes lack that finesse and have thin spots where you'd most easily strike it.
Still, I've had similar results with warhammers or poinlty backs of axes as seen in the test, with 2 mm modern steel, even stainless steel. I think it's all just a matter of how hard you hit. I think the point won't necessarily kill a person, but hooking the head with that strike and pulling hard could break someone's neck.
