Forum Index > Historical Arms Talk > Determining Pommel and Guard/Grip Weights Reply to topic
This is a Spotlight Topic Go to page Previous  1, 2, 3, 4  Next
Ozsváth Árpád-István
PostPosted: Mon 28 Sep, 2009 9:14 pm    Post subject: Determining Pommel and Guard/Grip Weights         Quote
Maurizio:
Please excuse me, I didn't know the cross section and the fuller matters.
Cross section: flat lenticular (almost hexagonal)
Fuller length: 76 cm (5 cms from tip)
Fuller width at base: 14 mm
Fuller depth at base: 3 mm
I have to explain how I made the blade. I started with the fuller 3 mm deep and 14 mm wide, it gives me an excellent guideline for making the profile of the cross section and it's difficult to make it after that.
After that I started at the guard trying to keep a constant angle of 10-12 degrees for the whole length to make the cross section. This naturally gave me a linear distal tapper for this reason the fuller got narrower and became more shallow towards the tip.
The cross is made from the same material as the blade and it's 17 cm long. I considered that a longer guard will be annoying while handling the sword. It's only 7 mms thick, but I considered that's pretty strong material unlike brass or bronze or anything that could be cast. Well it's a real pain in the a.. (neck) drilling holes in spring steel, but I found out that dentists drills and routers works fine.
By the way, I couldn't find anything about authentic historical swords pommel and guard weight. Maybe it can be estimated, knowing that the density of steel is around 7.7 g/cm2....
Vincent:
Maybe it's just beginners luck, but the pivot point (corresponding to the cross) seems to be around 52 cm from the guard as I can see with the naked eye. Maybe I will try the pendulum method too.
I don't think swordsmiths were great mathematicians (I even doubt they were literate) in the dark ages, they have had some simpler practical and secret methods for doing all that.
Today we live in the computer age so why not integrate those formulas in some programs.
Best regards,
Arpad
Profile PM E-mail
Vincent Le Chevalier
Reading list: 15 books
PostPosted: Mon 28 Sep, 2009 10:00 pm    Post subject:         Quote
OK, I'll see later today what I can do with it...
Well yes, but we have to rediscover the formula first :)
It's not difficult to build a sword if you've seen several before, with a master to guide you. I think you can do it by feel at some point (which is what most smiths do today anyway). But if you don't have access to quality swords it's hard to re-invent...
Vincent
Ensis Sub Caelo
Profile PM Website
PostPosted: Mon 28 Sep, 2009 10:28 pm    Post subject: Determining Pommel and Guard/Grip Weights         Quote
Well I don't think I can find a real swordsmith nearby and museums won't let me swing their precious artifacts neither. Good replicas are expensive and my wife is not happy with my obsession for blades. I will surely wake up one morning with may bayonet collection in my back if she finds out that I spend the family's budget on such things.
People here still think that swords are just big heavy knives as seen in the movies. Swords you can find on the market here are just cheap fantasy junk that will break apart at the first impact. I have access to some authentic cavalry and infantry sabers, but they are a complete different story. That's the reason I don't know when a sword feel ok in the hand. Blacksmiths are specialized in making horseshoes, so I appreciate every advice from experienced people like you.
Profile PM E-mail
Maurizio D'Angelo
Likes: 3 pages
Reading list: 3 books
PostPosted: Tue 29 Sep, 2009 4:09 am    Post subject:         Quote
I am not an expert, but I can provide the data you ask for.
I set to work, tomorrow or the day after tomorrow I will give you the information you ask for.
Interestingly, comparisons with Vincent.
From handling, I'll see if you can give a POB between 110 and 120 mm. I hope to find the moments of inertia about three principal axes. These may explain Vincent, he is the expert. :p
I make mistakes, but the guard is a little short for the average.
The data will be averaged, then only the experts are good things.
But it can be a starting point. :)
Ciao
Maurizio
Profile PM E-mail
Maurizio D'Angelo
Likes: 3 pages
PostPosted: Tue 29 Sep, 2009 7:57 am    Post subject: Re: Determining Pommel and Guard/Grip Weights         Quote
The ancients knew nothing of inertial dynamics and harmonic balance or applied physics, but they knew that building in that way we get better swords.
Before Newton, it was known that an apple cut, fell to the ground, with Newton, we discovered only because it happens, the effect was and remains the same, then as now.
Ciao
Mau
Profile PM E-mail
PostPosted: Tue 29 Sep, 2009 8:24 pm    Post subject: Determining Pommel and Guard/Grip Weights         Quote
Fixing the CoG at 110-120 millimeters without modifying the blade may require a large, over 500 g pommel.
Well, the ancients who discovered the wheel were not less intelligent than those who built the first space shuttle. There are things we learn in childhood and take for granted, like gravity. In the middle ages education wasn't available for the masses just for a few people from higher social classes, or men of the church. It was based more on religion and art.
Today's modern swords are made by CNC machines and are designed with some sort of CAD software. The swords parameters are fixed before the machine starts grinding. I think it's even possible to reverse-engineer the blade, by fixing those parameters like CoG pivot points maybe even harmonic nodes, than building the sword around it.
Profile PM E-mail
PostPosted: Wed 30 Sep, 2009 1:19 am    Post subject: Re: Determining Pommel and Guard/Grip Weights         Quote
Yeah, I don't think it's reasonnable to aim for that if the properties you measured for the blade are accurate...
100g of crossguard does seem to be a bit big but I can't say I have a good idea of how much it should weight. If you do it lighter, then do it, if not leave it :)
Anyway, with the pivot point you measured on the bare blade, adding a vey small pommel (100-120g) should be enough to satisfy my theory... That will leave you with a CoG at around 17-18cm if you don't change the crossguard weight. Note that some cutting swords really have CoGs that far forward... I'm a bit surprised at the pivot point value you have measured (I was expecting something closer to the guard), but it's hard to spot a measurement error with only one value. If you measure the pivot point from another reference point we'll have a way to gauge the error. A pommel that small might not look very good, I can't really say how the blade should be modified to yield a bigger pommel...
Remember, all this advice is worth exactly what you paid for :) I stress again that any understanding I have comes from studying reproductions, not making swords...
Vincent
Ensis Sub Caelo
Profile PM Website
Maurizio D'Angelo
Likes: 3 pages
PostPosted: Wed 30 Sep, 2009 4:39 am    Post subject:         Quote
Ozsváth,
as promised:
1)
weight sword = 1.7410078e+03 GRAMMO (1.74 Kg)
Blade = 913.21587e+00 (0.913 Kg)
Guard = 98.25487e+00 (0.098 Kg)
pommel = 0.618e+00 KG. (0.618 Kg) (around 70 MM.)
if pommel is this:
POB = 110 mm from the guard
principal moments of inertia: (GRAMM * MM^2)
I1 I2 I3 5.7075690e+05 1.3891870e+08 1.3941801e+08
slewing than the main axes
R1 R2 R3 1.8106113e+01 2.8247499e+02 2.8298218e+02 MM
If you make a pommel historical (around) is this:
2)
weight sword = 1.41100e+03 GRAMMO (1.41 Kg)
pommel = 0.3308e+00 KG. (around 53 MM.)
if pommel is this:
POB = 158 mm from the guard (Vincent you are a great)
But, type Oakeshott Albion that you make, have a POB = 110 mm
I1 I2 I3 4.3436621e+05 1.1714930e+08 1.1754266e+08
(the handling is in relation to these numbers, Vincent can better explain the value of these numbers, if I do it myself with my English to risk no understood.)
Now, using the mathematical proportions, you can change these values as best you want.
nodes harmonics, and the elasticity of the blade, serves:
Heat treatment, hardness obtained, coefficient of elasticity of the material that uses, energy in Joules (understood as a constant). The point of impact better, I find myself.
To do this, it takes a little 'time, is not exactly easy, but possible.
I use these programs for my work, if you stick to these shares you get exactly those results.
But, you want to replicate a type Oakeshott Albion? I think it's a bit more difficult, they feel the blade, beyond the numbers.
I hope to have you help.
Here a drawing.
Ciao
Maurizio
 Attachment: 60.23 KB
This is the design of 1 solution
Profile PM E-mail
Bruno Giordan
PostPosted: Thu 01 Oct, 2009 1:54 am    Post subject: Re: Determining Pommel and Guard/Grip Weights         Quote
You should definitely put your blade into a strict diet .. grind grind grind until you get a good distal taper. the less you have while keeping the purpose of the blade the best.
I'm doing a falchion and after much grinding the 64 cm blade is still 750 grams. Adding cross and 200 g pommel I get 1100 grams total (minus the wooden handle which should be a negligible increase). The vibration node or sweet spot now would fall where i wanted it, right where the blade widens , but still I have a 1100 grams weapon with a short 64 cm blade. A bit heavy I will put it under the care of my favourite grindstone again. My guess is that so far I spent roughly four hours slow grinding and still I'm not finished. This even if I had hammered it pretty close to shape.
PostPosted: Fri 02 Oct, 2009 9:57 am    Post subject: Determining Pommel and Guard/Grip Weights         Quote
Thanks a lot for helping me!
It's not looking good...
I realize that I know very little about swords and I have much to learn especially on good old physics that I was so happy to forget. As Bruno said, I have to put my blade to a strict diet and grind, grind carefully not to end up with a rapier. I'd be happy with a blade under 800 gram,s a pommel around 300 ending up around 1200 grams. I have to cheat on the distal tapper to bring the CoG under 150 mm. It's still won't be a lightweight one.
I don't fully understand those moment of inertia and those axes . It has to do something with mass resisting acceleration and has direct relation with handling and impact forces. It's a good idea to get those values close to swords with known good handling characteristics.
Maurizio, I don't want to replicate the Albion Oakeshott, I said it just to give YOU an idea about the shape of the blade. They are really good experts and I can't get even close to the quality of the worst sword they ever made. Don't worry about your English, mine isn't so great as well :) I see you have some sort of software to calculate these values. Is there something on the web I can download? I can write one myself if I can find or figure out some formulas, well after taking a good rest on this weekend. I had a difficult week at work and I feel that my IQ have dropped dramatically, under human values :p
Arpad
Profile PM E-mail
PostPosted: Sat 03 Oct, 2009 8:35 am    Post subject:         Quote
Hi everybody,
Yes, good old physics can have practical uses among which understanding swords :)
Moment of inertia is a measure of how hard it is to accelerate the object in rotation about an axis. Much like mass is a measure of how hard it is to accelerate the object in translation (conveniently mass does not depend on the direction you want to give to the object, but moment of inertia does depend on the axis of rotation). The classical example for moment of inertia is to take a bar with two weights attached. If the weight are at the ends, the bar will be a lot harder to rotate than if they are at the middle. Yet, the mass and center of gravity are the same in both cases.
Swords are used essentially in rotation and very little in translation, so the moment of inertia is an important property to understand. The thing to remember is that it's the square of the distance from the mass to the axis of rotation that matters.
The moment of inertia of a sword about the axis of the blade is very small, and the moment of inertia about the axis that allow to strike with the edge or with the flat are much bigger and almost equal. That is because the sword is a thin, long object. This is seen on the numbers given by Maurizio:
The interpretation of this line is that the moment of inertia is:
5.7e5 g.mm^2 about I1, which is the axis of the blade
1.39e8 g.mm^2 about I2 and I3, the other two axis.
It's that last figure that is significant. The other moment of inertia can be safely neglected.
These can be computed as Maurizio did, thanks to a CAD program that knows very precisely the geometry of the object, or they can be measured thanks to the pivot points, which is what you did on your blade.
Now what can I do with that?
I can compute an equivalent object that has exactly the same dynamic properties as your swords (it will move in the same exact way) but that has a much simpler mass distibution. This allows to compare the mass distribution in a very visual way... I did that with a stick of uniform thickness, with a point mass on it that materializes the concentration of mass you achieve through tapers and addition of hilt components. Several swords are represented like that in the image below:
The length and thickness of the rectangle represents the mass of the stick in the equivalent object, the bar that sticks out represents the point mass. The more it sticks out the biggest the point mass is relative to the stick. The red line shows the location of the cross on all swords.
I've included several swords I own or have measured for comparison. The Squire is the Albion sword of type XVI. The type XI was made by Angus Trim, and is probably closer to what you want to achieve. The "G. Fabre 2" is a type XV made by a French artisan named Gaël Fabre. "Sword" indicates your sword, Ozsváth, simulated with the 100g cross and a light 120g pommel. "Sword MA 1" and "Sword MA 2" are the swords given by Maurizio.
As you can see the main property of the big hitter types is that they have a big stick part. My conjecture is that a properly balanced sword must have the point mass very near the cross, because it fits neatly into how our brain controls the weapon. I've checked that on many swords from type XI to rapier. As you can see, your blade when mounted with a very light pommel has this property and looks pretty similar to my type XI. But Maurizio's swords have their point masses far into the handle and still have very big sticks. This is the symptom of too much pommel and not enough work on the blade, I think. It makes the sword feel slower than your brains expect from the static feel. The sword by Gaël Fabre is already borderline in my opinion as far as point mass location is concerned (I've heard people around the table say that they felt a bit unresponsive, less lively compared to originals).
If you wanted to have a smaller stick like the type XVI and XV, one way is to have more taper in both blade and tang. But for a sword of this type I think the big stick is appropriate.
I hope this makes some sense,
Vincent
Ensis Sub Caelo
Profile PM Website
PostPosted: Sat 03 Oct, 2009 11:16 pm    Post subject: Determining Pommel and Guard/Grip Weights         Quote
Thanks Vincent for the highly illustrated explanation. I'm still a bit confused here. As far as I understand one can make the equivalent model for the sword, let's say a thin rod and two weights with adjustable positions to simulate the mass distribution. Concentrating mass farther from the pivot point (ex. a large pommel) will increase moment of inertia. You will end up with a sword that will hit hard but it's difficult to control. It will stick to the trajectory imposed by the laws of physics. Well that's great to display the "power of thy sword" by chopping down innocent trees, but a chainsaw is much better for this purpose. After all a sword is a weapon, not just a tool.
Now I see that the crossguards weight has something to do with mass distribution.
On the other hand a sword with too low moment of inertia will lack on power. It's hard to find a good equilibrium between these characteristics.
Profile PM E-mail
PostPosted: Sun 04 Oct, 2009 3:29 am    Post subject: Re: Determining Pommel and Guard/Grip Weights         Quote
Well that about sums it up... That's why the study of originals is irreplaceable, there isn't one best compromise but a continuity of choices according to what the sword must be able to do. I can't say I've fully explored the possibilities yet...
Vincent
Ensis Sub Caelo
Profile PM Website
PostPosted: Sun 04 Oct, 2009 8:55 am    Post subject: Determining Pommel and Guard/Grip Weights         Quote
I tried to swing the blade couple of times. It's a real wristbreaker. It doesn't feels good for a single handed sword, but if I help a little on the end of the tang with my left hand it handles quite well. This must be the consequence of a sudden violent rotation of the tang when I try to stop the blade. That could be the result of pivoting too close to the guard?
Profile PM E-mail
Maurizio D'Angelo
Likes: 3 pages
PostPosted: Sun 04 Oct, 2009 11:56 am    Post subject: Re: Determining Pommel and Guard/Grip Weights         Quote
an expert, here, told me: a sword? Is simple, a sword is a summary of balance.
I think that is true. :)
Maurizio
Profile PM E-mail
PostPosted: Sun 04 Oct, 2009 8:45 pm    Post subject: Determining Pommel and Guard/Grip         Quote
Peter Johnsson wrote:
I do not look at where the point of balance happens to end up. That is just an end result of the other two important factors: first the placing of the pivot points, and second in importance, the placing of the vibration nodes.
With higher weight of the pommel the more the forward pivot point (the one that corresponds to the place in the grip just behind the guard) will be pushed towards the point of the sword.
At the same time the vibration nodes will wander back towards the hilt and pommel.
After all he is one of the best swordsmiths, it would be foolish not to follow his advice.
As a beginner I'm always looking for a swords weight and CoG. Now I realize that setting correctly those pivot points will place the CoG just right. It doesn't matter how those numbers look on paper. Manufacturers tend to specify only trivial characteristics and you cannot appreciate how it will handle.
I can make an adjustable pommel, strong neodymium magnets (you can find these in hard disks) will do the job.
I find the waggling test too subjective, you will see the blade pivoting right where you expected, so I will build a rig to try the pendulum model.
Profile PM E-mail
PostPosted: Mon 05 Oct, 2009 12:12 am    Post subject: Re: Determining Pommel and Guard/Grip         Quote
I wish to congratulate you on your open mindness, Ozsváth. Many people cling on CoG and weight even after the significance of pivot points has been explained...
If your blade is a wrist breaker, adding more weight on the pommel will not change it. I guess you mean that the sword is hard to stop after a cut or that it is hard to launch into a cut... In these case it's a sign of the blade being to heavy, having a too great moment of inertia (that's shown by the size of my rectangles). You'll have to make it thinner. Adding a big pommel will change the static feel but as soon as the blade is moving you'll encounter the moment of inertia of the blade again.
I'm interested in seeing what rig you can come up with. After some time I can perform the waggle test mostly objectively but it is indeed hard when you're new to it. An easy to build rig would be an immense help for sword science...
Vincent
Ensis Sub Caelo
Profile PM Website
PostPosted: Mon 05 Oct, 2009 1:08 am    Post subject: Determining Pommel and Guard/Grip Weights         Quote
Vincent, if you read George Turner's article (http://www.thearma.org/spotlight/GTA/motions_and_impacts.htm), especially the "swords and pendulums" section, you will notice that those pivot points can be located with ease. All you have to suspend the blade at certain points on the hilt (under the index finger or at the cross for the forward pivot point) to act like a physical pendulum and get the period of oscillations. Now the theory says that the location of the corresponding pivot point will be the length of the string of the simple pendulum (ball on a string) which oscillates with the same period. Simple pendulums period are not affected by mass, only by the length of the string and the gravitational constant.
L = (T^2 * g)/(4*pi^2)
You can find all equations needed here: http://hyperphysics.phy-astr.gsu.edu/HBASE/pend.html#c1
Now you can make an adjustable mass pommel and see how it affects the pendulum's period and by consequence the location of pivot points.
I'd really like to have some spare time to do some experiments but at my age that seems to be a luxury.
Profile PM E-mail
PostPosted: Mon 05 Oct, 2009 3:14 am    Post subject: Re: Determining Pommel and Guard/Grip Weights         Quote
Oh I'm fully aware of why the pendulum method works, but I had problems finding a reliable solution to hang the sword at a given point without friction and letting it swing. During the course of my reflections I have become so familiar with the waggle test that I gave up trying to perfect the other method, but I guess the pendulum could indeed add further precision.
Another part of my reasonning is that any difference I'm not able to spot by hand and eye (i.e. the waggle test) is not a significant one, but that might be overly optimistic ;)
Vincent
Ensis Sub Caelo
Profile PM Website
PostPosted: Mon 05 Oct, 2009 8:45 pm    Post subject: Re: Determining Pommel and Guard/Grip         Quote
You're right, Vincent. My blade is definitely too heavy. Now it weighs 870 grams, but I don't have any idea how much it should be. I'd never seen sword specs like blade weight, guard weight, pommel weight. I know, it would be stupid to dismember antique swords, but this data can be estimated by volume too.
On the other hand, there are heavier swords that handles quite well. The other problem could be pivoting close to the guard. If you try to stop a rotating blade you must apply force with your wrist. This will act like an impact point on the grip and the sword will try to rotate around the corresponding pivot point on the blade. Now it acts like a first class lever. If you place the pivot point farther you will have a longer lever arm and therefore it will be easier to control. This might be the reason for so many historical swords having the pivot point very close to the tip.
Profile PM E-mail
Page 3 of 4 Reply to topic
