Forum Index > Off-topic Talk > charcoal burning temps. Reply to topic
Jake Wilson
PostPosted: Wed 09 Sep, 2009 1:57 pm    Post subject: charcoal burning temps.         Reply with quote
Hello,
I am preparing to build a "charcoal heat treating pit" in order to heat treat 1060-1095 carbon steel. Does anyone here know the approximate burning temperature of a sitting charcoal fire? Is this enough to get the steel to the appropriate temps for quenching? Or is forced air blowing a necessity? I know it needs to be in the neighborhood of 1500 F or thereabouts depending on the steel.
I'm curious as to the fire temp of the non forced air fire to determine about how much air will need to be used to increase the temperature. Also, when preparing the fire, how do those here determine when the fire is hot enough to place the steel in the fire to prepare it for quenching?
Thanks.
Jason Dingledine
PostPosted: Wed 09 Sep, 2009 6:46 pm    Post subject:         Reply with quote
You'll need forced air of some sort or another. Either via an electric blower (even a hair-dryer will work), or a bellows.
Jason Dingledine
Arne Focke
Reading list: 34 books
PostPosted: Thu 10 Sep, 2009 3:20 am    Post subject:         Reply with quote
Depends on the quality of the charcoal.
In most cases you will need some assistance from forced air.
Only the highest quality charcoal will work without, but its almost impossible to get.
So schön und inhaltsreich der Beruf eines Archäologen ist, so hart ist auch seine Arbeit, die keinen Achtstundentag kennt! (Wolfgang Kimmig in: Die Heuneburg an der oberen Donau, Stuttgart 1983)
R D Moore
Reading list: 11 books
PostPosted: Thu 10 Sep, 2009 6:43 am    Post subject:         Reply with quote
A variable speed hair dryer could be taped to a length of pipe connected to your tuyere for your blower. And there are lots of ideas for simple forges on the internet so you shouldn't have too much trouble getting started.
Jeroen Zuiderwijk
PostPosted: Sun 20 Sep, 2009 12:24 pm    Post subject:         Reply with quote
Depends highly on the shape and size of the charcoal, how the air can flow in, insulation etc. In principle, a free burning charcoal fire can reach 800-1000C. But if the charcoal doesn't get enough oxygen, it can cool down. At any rate, it helps if the charcoal can draw air from below, and if the charcoal is large enough in size.
Jeroen Zuiderwijk
- Barbarian metalworking
- Museum photos
