Forum Index > Off-topic Talk > Windlass question... Reply to topic
Josh MacNeil
PostPosted: Thu 09 Jul, 2009 1:03 pm    Post subject: Windlass question...         Quote
Does anyone know what type of wood Windlass uses for their short polearms? I recently bought two and am debating whether I should replace the hafts with better wood. But I wanted to know if their stock hafts would hold up to use.
Profile PM Website
JE Sarge
PostPosted: Thu 09 Jul, 2009 2:32 pm    Post subject:         Quote
I think it's dry-kilned sheesham wood - which is a tropical hardwood from India. The color can vary from light to dark brown, and can be bleached or stained to look like just about any other wood. It's fairly durable, grows quickly, and is easy to work with, which is why most imported Indian / Pakistani wooden items are made of it. The downside of the wood is that it is grown in a tropical climate and it will tend to dry out, loose strength, and develop checking (cracks) over time.
I'd recommend replacing the haft with an ash one, unless you are using for display only purposes.
J.E. Sarge
www.crusadermonk.com
Chuck Russell
Reading list: 46 books
PostPosted: Thu 09 Jul, 2009 6:09 pm    Post subject:         Quote
i agree. had a friend just tap a shield with a windlass axe and the head flew off with part of the handle still in it
Profile PM YIM MSN
Josh MacNeil
PostPosted: Thu 09 Jul, 2009 7:29 pm    Post subject:         Quote
I'll definitely be replacing one of them. They're both project pieces, but one will be a birthday gift for a friend. That one probably won't see much use. At the most maybe a few whacks at some plywood or smiting some watermelons. It has wide langettes covering more than half of the haft. So I may decide to keep the haft on that one.
If I do decide to keep it, are there any treatments I could use on the stock haft to prevent it from drying out?
Profile PM Website
M. Oroszlany
PostPosted: Fri 10 Jul, 2009 12:21 am    Post subject:         Quote
Cooking oil usually works pretty well on wood in my experience. Rub the haft with a thick layer of vegetable oil, let it stand for a day or two, then remove the excess with a dry sponge or paper towel.
M. Eversberg II
Reading list: 3 books
PostPosted: Fri 10 Jul, 2009 1:10 am    Post subject:         Quote
Boiled linseed oil or tung oil is best. I've also heard mineral oil, but I've never tried that approach. I've also heard veg oil can spoil in open air, but I'm not an expert there.
M.
This space for rent or lease.
Profile PM AIM YIM MSN ICQ
