Forum Index > Historical Arms Talk > Double fullered viking swords? Reply to topic
PostPosted: Fri 20 Mar, 2009 6:14 am    Post subject: Double fullered viking swords?         Quote
Oakeshott mentioned in the Records of the medieval sword that some fine viking swords had double fullers. I haven't seen one and in The swords of the viking age is also not one double fullered viking sword. Does anybody have a picture of such a weapon or have maybe seen it somewhere?
D. Bell
PostPosted: Sat 28 Mar, 2009 2:09 am    Post subject:         Quote
This is something I've wondered about too, as I'm a fan of both viking age swords and double fullers. I've seen a lot of pictures of viking age swords, but none that have double fullers, so if they did exist they certainly weren't common. If anyone does know of a double fullered viking sword I would also be quite interested to hear about it.
An armed society is a polite society.
PostPosted: Sat 28 Mar, 2009 5:41 am    Post subject:         Quote
There is one that appears to be double fullered in the photograph, although that is not really discussed in the narrative, near the back of Swords of the Viking Age. Its a type X, 10th century, JPO 2253, page 118 in my 2002 printing. It was also pattern welded with some remaining silver wire just under the pommel. It's possible that the fullers were added later, as the blade was broken and re-welded 30 cm from the tip. Given the "viking era" guard still remains, I doubt it was rehilted at much later period though.
PostPosted: Sat 28 Mar, 2009 6:27 am    Post subject:         Quote
This is the sword you are talking about. I saw that picture earlier but didn't notice that it looks like it might be double fullered. It is visible only in the lower part of the blade.
PostPosted: Sat 28 Mar, 2009 7:11 am    Post subject:         Quote
That is the one. Anyhow, the double lines jumped out at me as pretty unique for the date when I saw the photo. I wondered why they were not discussed as this is the only feature like that in the photographed examples from the era that I can recall being shown in either of the two texts it seems that we have both been studying.
I wonder if the author doubted the providence of the double lines, and chose not to comment on them on purpose. The sword strikes me as a little odd. The grip seems longer than normal for the date assigned, and the fullers are sharp only in the lower tip section of the blade. It is stated that the blade had corroded evenly. I would have expected the fullers to corrode faster near the tip if they were original and gradually tapering as the rest of the blade appears to be. (They may be more like incised lines such as on some Roman era spathas. Or, I suppose the remaining furniture and upper blade portion of an older broken blade could have been welded to a broken tip of a newer fullered blade around 11th -12th century.)
Dan Dickinson
PostPosted: Sat 28 Mar, 2009 7:55 am    Post subject:         Quote
Hmmm....it does appear to be a double fuller on first glance. However, I would imagine that Pierce would mention something
about such an apparently unusual feature. My suspicion is that rather than a double fuller we are seeing the "two central bands of pattern welding" and that the dark line is the intersection of the two bands rather than a central ridge.
Dan
Patrick Kelly
PostPosted: Sat 28 Mar, 2009 8:50 am    Post subject:         Quote
There's also the possibility that it's a much older blade that was reused in the "viking" era. There are celtic iron age blades that feature double fullers with a general profile not unlike that blade. I'm not saying this is a personal theory but rather a possibility, although I think Dans explanation is more likely.
Profile PM AIM
PostPosted: Sat 28 Mar, 2009 11:22 am    Post subject:         Quote
I doubt that there is no geometric aspect to the lines. Without X-ray type examination, pattern welding can be difficult to discern at all after corrosion occurs. (It was stated that corrosion had occurred on this one.) Even relatively new blades with pattern welding can lose visible contrast bands of pattern welding contrast within a few months if not kept oiled. (I have had to have some pocket knifes re-etched, which is not a problem since the maker is a short drive away.)
Chuck Russell
Reading list: 46 books
PostPosted: Sat 28 Mar, 2009 6:29 pm    Post subject:         Quote
M C Bishop has some 3rd c AD blades with double fullers shown in his book Roman Military Equipment
Profile PM YIM MSN
Dan Dickinson
PostPosted: Sat 28 Mar, 2009 6:55 pm    Post subject:         Quote
While it might be true that corrosion might diminish the appearance of pattern welding in a polished blade....it can also serve to show the pattern when it advances far enough (due to the iron and steel having slightly different rates of corrosion). I believe this is the case with this sword as Pierce states: "The corrosion has occurred uniformly and thus allows us to see, with some clarity, the structure of blade, its central section and both cutting edges. It does appear that
we have an excellent example of the bloditha style of pattern-welding through the central
portion of the blade."
Dan
PostPosted: Sun 29 Mar, 2009 3:39 am    Post subject:         Quote
It does sound like Ian Pierce thinks of that what we see as fullers when he writes about pattern of pattern welding. And he writes with enough detail that he would mention the possibility of double fullers if it looked that way in real.
PostPosted: Mon 24 Jan, 2011 3:39 pm    Post subject:         Quote
It's alive!!! (The topic. ;) )
Finally, a double fullered viking age sword appeared, and photos are of good quality, so I think there is not much doubt it really is double fullered.
Bottom of the page 15 and top of the page 16:
http://www.vikverir.no/ressurser/hist_mus_osl...mp;page=15
J.D. Crawford
PostPosted: Mon 24 Jan, 2011 5:15 pm    Post subject:         Quote
Good one Luka - I've often wondered about this, and those pictures are the first solid proof I've seen. -JD
Profile PM Website
PostPosted: Tue 25 Jan, 2011 6:34 am    Post subject:         Quote
I'm not really sure what type it is, Petersen type 1, D, V, what would you guys say?
Audun Refsahl
PostPosted: Tue 25 Jan, 2011 7:51 am    Post subject:         Quote
that sword is located at Kulturhistorisk museum in oslo.
I found a couple of swords that has other abnormal cross sections, allthough not double fullers.
this one is located at "Midgard historiske senter", at Borre in Norway. the sword wasn't found at borre though. look at the fuller on the one to the left:) http://www.vikverir.no/ressurser/borre_no/
the other one nils just showed me, is at Kulturhistorisk in oslo, look at picture nr 4. this single edged sword has no fuller at all..
edit: maybe I should add the link... http://www.vikverir.no/ressurser/hist_mus_osl...amp;page=5
just bacon...
Profile PM Website
Nils Anderssen
PostPosted: Tue 25 Jan, 2011 1:02 pm    Post subject:         Quote
It is also worth notising that the double fullers on the sword at the Kulturhistorisk museum in Oslo stops a little bit before half way down the blade. After that they fade out into one fuller.
PostPosted: Tue 25 Jan, 2011 3:33 pm    Post subject:         Quote
That's pattern welding on the middle blade? Looks very nice. And the one with snake inlay is very cool.
PostPosted: Tue 25 Jan, 2011 3:34 pm    Post subject:         Quote
I didn't notice that. Have you seen a full length photo maybe or you met it in person? ;)
