Forum Index > Historical Arms Talk > 12thC Norman lances - welded or butted socket? Reply to topic
Leo Todeschini
PostPosted: Tue 17 Feb, 2009 1:32 am    Post subject: 12thC Norman lances - welded or butted socket?         Reply with quote
Hi guys, just looking for a bit of guidance on whether the socket of a typical Norman lance of the 12thC would have the split welded up or left as a butted joint.
Many thanks
www.todsworkshop.com
www.todcutler.com
Fabrice Cognot
PostPosted: Tue 17 Feb, 2009 1:41 am    Post subject:         Reply with quote
Hi Todd
Hard to say as a broad rule.
My own studies would suggest 'poorly welded' as a general rule.
PhD in medieval archeology.
HEMAC member
De Taille et d'Estoc director
Leo Todeschini
PostPosted: Tue 17 Feb, 2009 7:48 am    Post subject:         Reply with quote
Thanks Fabrice,
So basically welded, not welded or anything in between would be OK?
www.todcutler.com
PostPosted: Tue 17 Feb, 2009 8:22 am    Post subject:         Reply with quote
If you're going to have to make lots of these as part of your Norman contract, you might be interested in this as a time-saver:
Not long ago I found a supply of Hanwei "Viking Throwing Spears" for $30 USD and got one to see if it could make a convincing 15th c. spear. The fake niello on the socket is simply copper-plated steel and the thin plating comes off quickly with a file (even faster with a belt sander). As purchased, the seam is open, but is easily closed with the tension of the rivet (see last photo below). Just a thought....
 Attachment: 35.91 KB
 Attachment: 43.43 KB
 Attachment: 54.29 KB
Fabrice Cognot
PostPosted: Tue 17 Feb, 2009 8:24 am    Post subject:         Reply with quote
Yep.
After drawing out the socket and rolling it, the ends overlapped a bit and were tentatively forge-welded. Sometimes it worked, sometimes it didn't.
Here's an example of what I mean :
I hope it helps.
Fab
HEMAC member
Leo Todeschini
PostPosted: Wed 18 Feb, 2009 12:50 am    Post subject:         Reply with quote
Thanks for all your help, it is appreciated and nice work Fabrice.
Darrin read that last night and posted his unwanted one to me today, so quick progress indeed.
I think that you are right Sean and this could make a good basis for a lance with a bit of reworking.
Basically I have an wide ranging contract for a number of items and some bulking out needs to occur to fill the gaps in a cost effective way which is where these come in, but combined with some higher grade examples this will work well I think.
Regards
www.todcutler.com
