Forum Index > Off-topic Talk > Fighting with the scabbard on foot, Also: CF's M@A Belt Reply to topic
M. Eversberg II
Reading list: 3 books
PostPosted: Tue 25 Mar, 2008 2:29 am    Post subject: Fighting with the scabbard on foot, Also: CF's M@A Belt         Reply with quote
Looking at period artworks, it's obvious that footmen, using swords, did fight with their scabbards on them. However, in my experience, they're somewhat cumbersome. I am not a tall individual, so this likely adds to the problem. For the more experienced members here, how does one hang their scabbard in such a way as so it does not become a burden in combat?
Also, about two years back I ordered this belt. While the question is dumb, I figured it warrants asking (as I really haven't used it, as it's difficult to fit my wasters scabbard into the holder for it): Is the buckle supposed to be dead center, like modern belts, with the sword tangent to my hips, or is the buckle shifted to the right, with the sword more towards the front of me?
M.
This space for rent or lease.
Daniel Staberg
PostPosted: Tue 25 Mar, 2008 4:55 am    Post subject:         Reply with quote
My experience is that as with most military gear training is the key. By trainign with the item(s) in question you ge tused to them and learn how to adjust the way they are worn to best suit you. During my first months as a conscript in the Swedish army wearing, helmet, webbing, side arm and the other basic personal gear was a bothersome hindernace as we worked fire control equipment and the guns. 12 months later the gear had become if not a second skin something fairly close to it.
I've experienced the same with scabbards, at start they were a problem but with increased experience I got used wearing one. However all of my current scabbards are of the all-leather type. The lack of a wooden core probably makes them soemwhat less of problem.
The type of the sword plays a part as well. The scabbard for a short sword like a katzbalger woudl cause few or noen of the problems caused by the scababrd for a long sword.
My two euro-cents
Daniel
Bennison N
My Dotanuki has an iron scabbard. I use it as a second weapon.
I have always held my sword, when sheathed, by the scabbard in my left hand, and drawn with my right. I do not, however, have a lot of experience with European style hanging scabbards. Japanese saya (for Katana, Tachi are worn differently) are held differently in the belt, and do not cause much annoyance, even when kicking with the left. I do not wear Jian on my belt, and I generally draw them from atop my left arm.
All I can say, from having looked at a few pictures of belt-hung European swords, that it seems to be a matter of personal preference. Experts on that type of weapon may able to offer more assistance. I would say try out a few ways, and see what works for you...
अजयखड्गधारी
Bill Grandy
Reading list: 43 books
PostPosted: Tue 25 Mar, 2008 5:02 am    Post subject:         Reply with quote
Do you have an accurate suspension belt? It makes all the difference in the world. I used to think having the scabbard was clumsy as well, but this is because most modern-made suspension systems and "frogs" to carry the scabbard do not sit right. Most historical patterns make the scabbard very comfortable to wear.
HistoricalHandcrafts.com
M. Eversberg II
PostPosted: Tue 25 Mar, 2008 5:26 am    Post subject:         Reply with quote
I have a link in my first post regarding one of my two belts. The other is a cheap version, a Kult of Athena "Medieval Double Wrap Belt".
M.
PostPosted: Tue 25 Mar, 2008 5:27 am    Post subject:         Reply with quote
M.
The CF Man at Arms belt, while attractive in its own way, doesn't look very historical to me.
Elling Polden
PostPosted: Tue 25 Mar, 2008 5:28 am    Post subject: Re: Fighting with the scabbard on foot, Also: CF's M@A Belt         Reply with quote
M.
Basically, your problem is that the scabbard for practical purposes only has one riser.
If you simply tie a cord to the scabbard loop, you can attach it to the belt on the opposite side, and keep it in place.
In combat, you generally want the scabbard to stay put in one place. I usually thighten mine so that it sticks to the side.
For casual wear, however, you might want the scabbard to be more loose, so that it can move when bumping into things.
I use the standard issue early/high medevial three point suspension, which works quite well.
(picture from www.lutel.cz)
M. Eversberg II
PostPosted: Tue 25 Mar, 2008 6:36 am    Post subject:         Reply with quote
Thanks.
Elling: Are you talking about the CF one, or this one:
M.
Quite the pity :/
M.
EDIT: Then is when I realize that the CF belt is tied differently from mine, which explains the problem I'm having.
Elling Polden
PostPosted: Tue 25 Mar, 2008 6:47 am    Post subject:         Reply with quote
The CF.
I never used a belt like the Cult of Athena one, but my guess is that it will be quite bumpy, and tend to hit your in the leg when you run.
Again, it can be fixed by adding a third riser, from the scabbard to somewhere on the back.
Bryce Felperin
PostPosted: Tue 25 Mar, 2008 9:17 am    Post subject:         Reply with quote
I usually carry the scabbard attached to the belt with three points/straps. The back strap is further back and attached toward the rear of my back to hold the scabbard tight. The scabbard is not even with my hips, but a bit back from my side and hips. Since I turn my hips when drawing my sword this works well for me and tends to leave the scabbard to my rear if I fight with it on.
However you did touch on one important point, namely your height. I have overly long legs to a shorter torso, so most sword scabbards on me don't touch the ground. So I'm able to get away with some supensions others probably couldn't. Other people I know who are shorter don't have so easy and have to have tighter/higher suspensions to carry a sword on their hips.
In the end, you need to try out and think upon what works best for you and adjust things to work for your height and profile.
Christian Henry Tobler
PostPosted: Tue 25 Mar, 2008 9:52 am    Post subject:         Reply with quote
Some earlier suspensions used two points, rather than three. You can see this on several c.1290-1325 English effigies and brasses. However, these aren't set up like the one from Kult of Athena - the two points are staggered, so the sword must hang at a backward angle.
Best,
CHT
Order of Selohaar
