Forum Index > Historical Arms Talk > Flat ring riveted round rivets Reply to topic
Felix R.
Reading list: 25 books
PostPosted: Tue 20 Nov, 2007 10:49 am    Post subject: Flat ring riveted round rivets         Reply with quote
What do you think of this riveted maille.
 Attachment: 119.93 KB
James Barker
PostPosted: Tue 20 Nov, 2007 11:13 am    Post subject:         Reply with quote
If you are wondering did flat maille come with round rivet heads instead of wedges then the answer is yes; in fact it is more common in extant examples:
Museum of London; 14th century
Leeds Museum; 16th century:
James Barker
Historic Life http://www.historiclife.com/index.html
Archer in La Belle Compagnie http://www.labelle.org/
Jeremy V. Krause
PostPosted: Tue 20 Nov, 2007 11:47 am    Post subject:         Reply with quote
And yet the difference in appearance between historical pieces and reproductions is glaring. All attempts are really kind of sub-standard. Only Erik Schmid can produce authentic looking reproduction maille at a very, very high price.
Jeremy
James Barker
PostPosted: Tue 20 Nov, 2007 12:07 pm    Post subject:         Reply with quote
Jeremy is correct no cheap made maille really has captured the total look.
James Barker
Felix R.
PostPosted: Tue 20 Nov, 2007 12:17 pm    Post subject:         Reply with quote
Thanks for the pics. The thing is really, that this cheap maille, though riveted is far away from the original. The example of the 14th cent looks like flat punched ring mixed with round ring riveted. Is that correct?
James Barker
PostPosted: Tue 20 Nov, 2007 12:33 pm    Post subject:         Reply with quote
I think it was flat punched ring mixed with round ring riveted now that you mention it. That too is common place.
James Barker
David Drake
PostPosted: Tue 22 Jan, 2008 12:21 pm    Post subject:         Reply with quote
How about this riveted chainmail? Looks nice enough. What do you think? I believe that the inner diameter of rings is 8mm,and the diameter of wire used is 1,0mm.
 Attachment: 82.42 KB
 Attachment: 90.7 KB
 Attachment: 100.91 KB
 Attachment: 98.29 KB
 Attachment: 84.47 KB
 Attachment: 132.83 KB
 Attachment: 106.98 KB
 Attachment: 94.18 KB
Felix R.
PostPosted: Tue 22 Jan, 2008 1:35 pm    Post subject:         Reply with quote
Hello, the riveted section looks quite good to me, especially in the overlap as it is not too big. But the inner diameter to wire thickness ratio is off to me. Also I like my aventails more dense and round in appearance.
When I finish my aventail I will post a picture it is of alternated solid and flat ring wedge riveted rings.
I read in a German forum about the tinning of original maille shirts. I think with something like this it would look much better, I always wondered why the riveted section was so perfectly blending into the ring, things I didn´t see on modern reproductions. Tinning might be the answer.
PostPosted: Tue 22 Jan, 2008 2:23 pm    Post subject:         Reply with quote
I would settle for either the reproduction wedge or round rivet head versions. I take no position on the issue, but have read some articles and opinions that some of the surviving links show evidence of mixed construction (welded rings, punched rings, mixed solid and riveted, evidence of hand formed wire rather than flat links, etc.) and even speculation that rust and deterioration may be giving some surviving mail a more beautifully rounded shape at the joint area today than it originally had when it was made.
I bought a starter coif kit for wedge rivet construction almost exactly one year ago from Forth Armoury. They have since discontinued their business. Since then, I have been trying to locate rivet rings being offered as loose solid flat rounds and matching pre-punched rivet rounds in an appropriate mild carbon steel. The Ring Lord has been promising to develop and offer them for a while. If someone is offering suitable steel rings for the aspiring mail maker please identify and list the source!
PostPosted: Wed 23 Jan, 2008 4:00 am    Post subject:         Reply with quote
The riveting and overlap is no better than any of the other cheap riveted mail being imported. The inner diamter is fine for some extant examples. For others it is not. Historical mail varied greatly. You have to pick an extant example and then find someone who can replicate it. "Riveted" does not equal "historical."
The answer is using tools that actually create links that look like historical samples. None of the commercial examples I've seen except Erik's do that and tinning won't help. There are a few other mail makers who are getting close but they don't sell their work.
