Forum Index > myArmoury.com Features Talk > Suggestions, Requests and Support > Dubth of especification of Conan Sword Reply to topic
Maximiliano Mastrandrea
PostPosted: Thu 26 Apr, 2007 2:47 pm    Post subject: Dubth of especification of Conan Sword         Reply with quote
Somebory help me for this especification :
Profile taper: 3 inches to 2.1 inches at final curve to point
Distal taper: .24 inch at base; 50% taper to point
No understend this
No idea of Profile or Distal taper
Thanks and good bye
PostPosted: Thu 26 Apr, 2007 3:00 pm    Post subject: Re: Dubth of especification of Conan Sword         Reply with quote
No understend this
Thanks and good bye
Maximiliano,
Please have a look at this article: http://www.myArmoury.com/feature_properties.html
Profile taper is the taper in width of the blade. Distal taper is taper in blade thickness from hilt to tip. So the Conan blade is 3 inches wide and narrows to 2.1 inches wide before the final curve to the blade point.
The blade is .21 inches thick and gets thinner by 50% between base and tip. In the case of this review and some other older ones, the term "Distal taper" followed by measurements should really be "Blade thickness" followed by the measurements.
