Posted: Thu 07 Jan, 2021 12:15 am Post subject: Tod lashing prod to crossbow video. |
Just watched this youtube video by Tod and he demonstrates how he lashes the prod of a crossbow to the tiller in great detail as a tutorial.
https://www.youtube.com/watch?v=wuO5sgr1wf0
I found it very interesting although the probabilities of my doing this is small as far as with making a DIY crossbow project, it does have some general principles that one could use if one needed to lash two things together very securely.
I know that Tod might occasionally post there things himself but his youtube channel has become more and more interesting and worth watching for many reasons, and I wanted to give people a heads up about this video, but also new members/readers here might not know of Tod's youtube channel and the very good medieval reproductions he does.
I've bought a few of his daggers like one of his large Baselards, and I also commissioned an Eared Dagger from him some years ago. ( Note: One of the best buying experiences as estimated times from project start to delivery where very accurate, if if I remember correctly the Eared Dagger ended up being finished and shipped earlier than promised. )
Tod's home page: https://www.youtube.com/channel/UCWnlQMQ-ACfhpD68yWRsnJw
I also had him do the bronze castings for my Eagle headed canes based on a carved wooden model I sent to him .... Ended up having 13 copies made for my DIY walking stick project.
Just for reference one pic of the bronze heads and the original wooden model.
Attachment: 136.22 KB
Duncan Hill
Posted: Thu 07 Jan, 2021 8:05 am Post subject: |
I enjoyed this video - I particularly liked his method for making the "needle" for the cord. I've been using a loop of thin wire on a stick to pull through the cordage as I bind the prod on, but I think his method is better.
I originally learned from the video below; it varies slightly from Tod's in that you don't need to double back through the bridle hole once you have finished the figure eight on one side; I think this results in a slightly neater, more efficient result (but only slightly; Tod's results are obviously consistently amazing).
https://youtu.be/V2VDpAauAZI
This guy's videos are all very informative, and the only source (other than Payne-Gallwey) I've been able to find that demonstrates a way of making a reinforced-loop crossbow string. The method he uses there varies from the one demonstrated in Ralph Payne-Gallwey, but as we know, RPG is not always totally accurate:
https://youtu.be/grLsVCY8Y0w (skip to about :50 to see the construction of the end loop)
