Forum Index > Off-topic Talk > Cutting a 13-chopsticks-cored newspapers roll target Reply to topic
Lancelot Chan
PostPosted: Wed 27 Jun, 2018 8:53 am    Post subject: Cutting a 13-chopsticks-cored newspapers roll target         Reply with quote
https://youtu.be/BIsE9SA4gvU
Peter Johnsson suggested using aquatherm PPR pipe as bone and provided dimension for which size would simulate certain bones. I figured that I was using a tad bit smaller diameter than he was suggesting for the upper arm. Thus I used chopsticks to simulate the size he suggested and found that it takes 13 chopsticks to made the circumferences. Then I verified my techniques again using Longship Armoury LLC 5160H DS Dadao. In one of the cuts I even cut the PVC pipe along with the chopsticks core!
Ancient Combat Association http://www.acahk.org
Realistic Sparring Weapons http://www.rsw.com.hk
Nightstalkers http://www.nightstalkers.com.hk
Lancelot Chan
PostPosted: Thu 28 Jun, 2018 7:56 am    Post subject:         Reply with quote
https://youtu.be/jF6Vl_dC9v8
Trying the same kind of target with a light sword this time, a lung chuan katana, using the same technique set as a compare.
