Forum Index > Historical Arms Talk > Copenhagen Sword Hilt Reply to topic
Georg Pachner
PostPosted: Wed 26 Apr, 2017 12:38 pm    Post subject: Copenhagen Sword Hilt         Reply with quote
Hello Sword-Enthusiasts!
I have a very specific Interest in Type D pommels, so the sword in Oakeshotts "Records of the medieval Sword" under Xa.13 really hit me.
If anybody here had further informations on that sword-hilt-fragments from Copenhagen, that go beyond what Oakeshott has already written about it, I would be really happy..
Especially measurements and a picture of the side of the pommel would be great!
Thanks in advance!
Niels Just Rasmussen
Spotlight topics: 15
PostPosted: Wed 26 Apr, 2017 2:51 pm    Post subject: Re: Copenhagen Sword Hilt         Reply with quote
Thanks in advance!
Nationalmuseet doesn't seem to have any high resolution pictures online or other info about this sword (D8807). [I've tried].
There is this my armory thread with a picture of the sword from the museum (on page 1), but it is a smaller picture of it, than the Oakeshott one you already have.
See: https://myArmoury.com/talk/viewtopic.php?t=20025
Georg Pachner
PostPosted: Fri 28 Apr, 2017 2:42 am    Post subject:         Reply with quote
From that Picture, in relation to the other weapons, it seems to have had a pretty long grip.
If we could find out how long it is, we could scale a photo and make a drawing of how it might have looked like with its viking age damascus blade (if it isn't an actual medieval one)... I am really fascinated by that combination of an older blade on a new style of hilt
Thanks for the Reply
PostPosted: Fri 28 Apr, 2017 3:11 am    Post subject:         Reply with quote
The Danish sword collector E.A. Christensen had this sword, which where put on auction and according to Bonhams had a hilt comparable to D8807.
So maybe it has comparable dimensions.....[?]
Blade length is 95 cm and the sword is 108 cm in overall length.
Source: https://www.bonhams.com/auctions/19796/lot/61/
Last edited by Niels Just Rasmussen on Fri 28 Apr, 2017 3:06 pm; edited 1 time in total
Georg Pachner
PostPosted: Fri 28 Apr, 2017 2:31 pm    Post subject:         Reply with quote
After putting some research into this,I came up with a hypothetical reconstrution
[img][/img]
in red the tracing of the remaining Fragment and in blue my guessed original outlines.
[img][/img]
Possible appearance when new (I have included the damascus pattern of the blade, based on the corrosion pattern)
[img]
[/img]
Direct comparison to the Hanwei Tinker Norman. The blade seems very narrow, especially for a possible dark ages blade. It may be far more gone than i estimated in my drawing.
 Attachment: 100.97 KB
 Attachment: 101.58 KB
 Attachment: 141.35 KB
PostPosted: Sun 30 Apr, 2017 9:16 am    Post subject:         Reply with quote
[img][/img]
Nice reconstruction.
It is a very interesting sword if it is true it has an older refitted (late viking age?) blade.
Hope some day someone gets a chance to look more into this blade fragment and write a paper on it.
I have also noticed a slight confusion, when it comes to the use of term "damascus pattern".
A viking sword was usually created by welding twisted rods of iron together and usually creating a "herringbone pattern", which is different from a Damascus (Damask) pattern.
As pattern welded swords seems to have been invented in Europe (Celtic Iron Age), the term "Damascene sword" should then only be used for this "new" style of pattern, that was not seen in traditionally European pattern welded swords?
Also the word only enters Europe (France as "Damas") in the 14th century, so it it first from this time, when the pattern is observed as something special.
Richard Miller
Likes: 26 pages
PostPosted: Mon 01 May, 2017 10:31 pm    Post subject:         Reply with quote
As I see it, the blade does look quite narrow, but is it possible to determine the original width of the blade by measuring (if possible) the slot in the guard?
Also, the grip looks longer than "usual" for a viking sword (as previously mentioned). Could it be more of a later hybrid?
Clearly I'm no expert, just curious.
Mark Lewis
PostPosted: Tue 02 May, 2017 5:42 am    Post subject:         Reply with quote
Richard Miller wrote:
Also, the grip looks longer than "usual" for a viking sword (as previously mentioned). Could it be more of a later hybrid?.
I do not think the hilt dates to the Viking age, the form of the pommel is exactly consistent with examples and illustrations dating towards 1200-1250 or so. The difference between these and Viking age "cocked hat" pommels (Petersen's type Y) can be subtle, but I think recognizable.
Your reconstruction looks quite good! One caveat though, I would think that the apparent taper in the middle of the arms of the cross is deliberate and not the result of corrosion, so the cross would resemble a less dramatic version of the cross on Christensen's sword (ie. a type 2 cross vs. type 1).
Georg Pachner
PostPosted: Sat 06 May, 2017 1:24 am    Post subject:         Reply with quote
I am also completely with Oakeshott, that it is an older blade (as pattern welding is very unusual for the high middle ages) refitted with new hilt furniture around 1250...
I think too that the blade is far to narrow for a viking age blade, maybe very similar to a type X
and I am completely open for the tapering in the middle of the crossguard... it would be really helpful if anyone could provide better pictures or data... i think this sword is worth a reconstruction (probably more a re-interpretation)
PostPosted: Tue 09 May, 2017 8:08 am    Post subject:         Reply with quote
I think the blade is way to fragmented to really say something definite about the original width.
Furthermore Type X blades were in use in the viking age, but perhaps you meant type Xa?.
