Forum Index > Historical Arms Talk > Early 14th Century Armour Question Reply to topic
Craig Peters
PostPosted: Sun 12 Jun, 2016 7:05 am    Post subject: Early 14th Century Armour Question         Reply with quote
What kind of armour is this shown covering the man's arms and legs?
http://manuscriptminiatures.com/media/cache/m..._large.jpg
It's not mail armour, because elsewhere in the same manuscript the sleeping guards are shown dressed head to toe in mail: http://manuscriptminiatures.com/4080/13078/
Peter Spätling
PostPosted: Sun 12 Jun, 2016 7:16 am    Post subject:         Reply with quote
are you sure you posted the right picture? The first one looks clearly to be maille.
Btw. look at that nice kattle hat on the second picture! Also note the great helm as well as the poleyns!
Edit: Did you mean this?
Mart Shearer
PostPosted: Sun 12 Jun, 2016 7:32 am    Post subject:         Reply with quote
I presume the inquiry concerns the "panzerhose" in several other miniatures.
http://manuscriptminiatures.com/4080/13075/
http://manuscriptminiatures.com/4080/13076/
The construction seems to be like the later jacks of plate, with iron plates or perhaps baleen plaques sewn between layers of fabric in a running bond ("brick") pattern. It's also possible that this could be jazerant work, with mail and padding sewn between layers of fabric. Contemporary inventory records and regulations describe both types of construction.
Craig Peters
PostPosted: Sun 12 Jun, 2016 8:28 am    Post subject:         Reply with quote
Peter and Mart,
Yes, those are the correct images. Thanks.
Mario M.
PostPosted: Sun 12 Jun, 2016 9:46 am    Post subject:         Reply with quote
"Panzerhosen"
These examples are from a later date and apparently no longer exist because they did not survive the bombings of the second World War;
“The stream of Time, irresistible, ever moving, carries off and bears away all things that come to birth and plunges them into utter darkness...Nevertheless, the science of History is a great bulwark against this stream of Time; in a way it checks this irresistible flood, it holds in a tight grasp whatever it can seize floating on the surface and will not allow it to slip away into the depths of Oblivion." - Anna Comnena
