Forum Index > Historical Arms Talk > Dating splint armour Reply to topic
Tom Wolfe
PostPosted: Wed 14 Oct, 2015 8:22 am    Post subject: Dating splint armour         Reply with quote
My understanding of splint armour has always been in the context of mainly 14th century transitional armour, or a bit earlier with regard to "splinted maille". Essentially the precursor to what you might refer to as "full plate" white armour.
That being the case, I am surprised to see some pieces described as "splint armour" of lower arm, for sale from a well-known dealer in the USA, which the dealer is dating to c1480-1510. He is a dealer who knows his stuff, so I don't doubt the dating or attribution, so it appears my knowledge is badly wrong.
Measurements: 7" x 3 1/4" Picture shows interior and exterior.
How late did splint armour of this kind persist in use in Western Europe?
Thanks!
 Attachment: 40.3 KB
 Attachment: 37.8 KB
Collector of original 16th-17th century European arms and armour. Would like to collect earlier, but budget doesn't allow- yet!
Matthew Amt
PostPosted: Wed 14 Oct, 2015 11:28 am    Post subject:         Reply with quote
Part of the confusion is that early on we have "splinted armor", meaning narrow strips of (usually) metal riveted to strips or a solid piece of leather. Lots of that in the 14th century, and it shows up here and there in the Migration Era as well.
But then at least by the 16th century and possibly before (not sure!), we have "splints" or "pair of splints" which refer to arm defences made of several articulated plates. I *think* it's usually a term for munition armor, but other folks know this all a lot better.
So you might be able to differentiate "splinted armor" from "armor splints", but I suspect there still could be some confusion... In any case, if the dealer says this is a "splint" from c. 1500, that makes sense to me: it's from a munition armor for the arm. It just isn't made the same way as the modern term for "splints" meaning narrow strips, because the period usage of the term was different.
Matthew
Mark Griffin
PostPosted: Wed 14 Oct, 2015 11:53 am    Post subject:         Reply with quote
2nd Mathews answer, its a change in terminology both period and modern but basically the earlier armour is described in modern sources as splinted and munition arms late 15th to mid 16th (at least) as 'splints'.
Its a nice bit, if you don't want them let me know where they are for sale if you want :-)
Griff
T. Kew
PostPosted: Wed 14 Oct, 2015 12:02 pm    Post subject:         Reply with quote
Here's a nice reproduction set by Royal Oak. You should be able to see how the piece you showed would be the lower arm component (the slight bend at the top is where it curves towards the elbow - mostly hidden under the couter in the linked pictures).
Jeffrey Hildebrandt
PostPosted: Thu 15 Oct, 2015 10:03 am    Post subject:         Reply with quote
I agree with the dealer's date range (though I have seen some attributed to the 1520's), and it definitely looks like part of an Almain rivet's arm splints, even if it doesn't use a form of articulation I have seen on any before. I mention this because I think it makes the part interesting, not suspect.
From an articulation perspective, there is no reason that the plate could not have been a rerebrace instead of a vambrace, and it might actually make more sense viewed that way. The usual orientation of the slot cut in the vambrace of an arm splint runs down the vambrace, rather than across it, which allows the "gauntlet" plates that cover the back of the hand to adjust to wearers with a wide range of forearm lengths. The slot on the plate posted above might be better put to use just above the elbow, where provision is often made for twisting of the arm. The pivot and slot articulation at the top of the plate also look more like what one would expect between a spaulder and a rerebrace, rather than between a vambrace and a couter.
From the internal view, it looks like the armourer was originally intending to cut the perpendicular slot slightly higher on the plate. I love seeing that kind of detail! Thanks for sharing.
Royal Oak Armoury Website
Royal Oak Armoury Facebook
