Forum Index > Historical Arms Talk > 5 Giant early bronze age axes from Boest, Jutland, Denmark Reply to topic
This is a Spotlight Topic
Niels Just Rasmussen
Spotlight topics: 15
PostPosted: Mon 01 Jun, 2015 11:10 am    Post subject: 5 Giant early bronze age axes from Boest, Jutland, Denmark         Reply with quote
In a field at Boest in Central Jutland spectacular finds from the Early Bronze Age has recently been found. Thanks to a christmas tree producer that let his brother-in-law [an newly started amateur metal detector surveyor] search the area after he had cleared it.
The dating says from 1800-1600 BC. [so the scholars think 1600 BC most likely].
Depot 1:
5 big bronze axes. Only 5 such big "randliste-økser" [German: Randleiste Axt, English: Flanged Axe] have been found from this period in all Northern Europe and now then 5 from the same depot. They are from 25-30 cm and weighs up to 1 kg [so probably ritual axes, though use in ritual combat should not be dismissed].
Two of the axes [I guess the first two found by the metal-detector]:
Source: http://drupal-images.tv2.dk/sites/images.tv2....1-okse.jpg
Images also:
Source: http://www.tvsyd.dk/modules/xphoto/cache/41/9..._0_0_3.jpg
Source: http://videnskab.dk/sites/all/files/2_17.jpg
Depot 2: (75 meters away from the first find)
Two gold arm-rings, each 21 g, (so obviously a pair) and a gold finger-ring of 16 g.
Source: http://aoib.dk/storyimage/AO/20150528/ARTIKEL...p;MaxH=413
Weapon finds so far now shows 9 bronze flanged axes ! [the 4 minor ones are between 15-20 cm] and one bronze spear-tip.
This article shows a picture of the 3 last bigger axes, that was found right under the two first found [not the smaller axes though the article says so].
Source: http://skanderborg.lokalavisen.dk/ekstremt-sj.../705159679
The area also shows a procession road with 5 linear rows of man-height tall wooden poles, that can be followed for 100 meter. Depot 1 was found on the edge of the procession road and depot 2 was right across on the other edge of the road.
For pictures of the archaeological map and the gold finds of depot 2; see:
Source: http://www.museummidtjylland.dk/index.php/pre...boest.html
TV interview with the metal detector and digging at around 0.40 min
Source: http://www.tvsyd.dk/artikel/279301:AmatOer-me...mmel-Oekse
Apparently he made this discovery on his 4th detection attempt [lucky guy].
Last edited by Niels Just Rasmussen on Sat 06 Jun, 2015 5:45 am; edited 6 times in total
PostPosted: Tue 02 Jun, 2015 9:18 am    Post subject:         Reply with quote
An earlier find (possibly 1887?) from nearby Boest Mose (Bog) is at the National Museum.
It comprises of two bronze axes, a bronze spear tip and three gold rings.
Source: http://samlinger.natmus.dk/DO/1346
The axes looks as being from the same period.
Also from a 1943 digging a set of two fully preserved 12-spoked oak wheels and a partial axle were found at Boest Mose (couldn't find a picture). At first glance is does seem like a chariot so typical of the Bronze Ages. What I have found is that 12-spoked wheels possibly are more Hallstatt time period, which would indicate Late Bronze Age in Denmark (700-500 BC).
 Attachment: 55.57 KB
Boest Mose find:
Last edited by Niels Just Rasmussen on Sat 06 Jun, 2015 5:43 am; edited 1 time in total
Tim Lison
PostPosted: Tue 02 Jun, 2015 7:47 pm    Post subject:         Reply with quote
Very cool axes. The more I see bronze age stuff, the more I like it. How were axes like this hafted? I imagine that a handle was partially split and they were bound to it using cord or leather...?
John Hardy
Likes: 18 pages
PostPosted: Tue 02 Jun, 2015 8:42 pm    Post subject:         Reply with quote
And I think one very ancient technique (which I know that North American Indians used up into the early European colonization period) was to bind the head to the haft (or shafts for a spear or arrow) using wet rawhide or sinew. As the lacing dries, it shrinks, creating an incredibly tight binding.
PostPosted: Wed 03 Jun, 2015 8:30 am    Post subject:         Reply with quote
The early flanged axes as the ones found at Boest were perhaps a palstave set-up, which could be a continuation of the Danish Copper axes maybe done in the same way as Ötzi's copper axe.
See this thread with the find an even larger Danish (1,5 kg) copper axe head:
http://www.myArmoury.com/talk/viewtopic.php?t...highlight=
Source: http://www.archaeoart.co.uk/artefactspages/ha...age005.jpg
So the 1kg, 30 cm bronze axe must have taken some hefty 2-handed palstave to swing with.
I would guess they took part in ritual processions or was used in religious duals.
Tim Lison
PostPosted: Wed 03 Jun, 2015 9:29 pm    Post subject:         Reply with quote
Thanks for the follow up about hafting... The "palstave" set up seems really weird to me. Wouldn't it be really breakable at the bend?
PostPosted: Fri 05 Jun, 2015 2:31 am    Post subject:         Reply with quote
I'm guessing that all depends on the wood quality and set-up. Since palstaves were around for a long time, they must have worked, but there was probably a lot of skill involved.
As for the Boest axes being palstaves I have search for an image (Scandinavian "Helleristninger" - Petroglyphs, the examples below are from Simrislund, Scania) and I found this:
Source: http://www.sydsverige.dk/media/artikeltop/hel...islund.jpg
Top axe looks like the Boest type with what looks like a palstave set-up, the other axe is a "Spoon-shaped Flanged Axe" also with a seemingly palstave set-up, which you also find in Denmark. The ship beneath them shows clearly, that the tradition behind the Hjortspring Early Iron Age war canoe is all the way back in the Bronze Age.
For really big axes you have this well-equipped guy:
Source: http://natmus.dk/fileadmin/_migrated/pics/Simris_oeksemand_01.jpg
PostPosted: Sat 06 Jun, 2015 4:15 am    Post subject:         Reply with quote
The ship image is interesting as it can also be used for dating the petroglyphs:
Source: http://www.denstoredanske.dk/@api/deki/files/...ze=webview
Left row is images from Bronze Razors and right row from petroglyphs.
So this image is clearly from the Early Bronze Age.
Matt Corbin
Likes: 9 pages
Reading list: 12 books
PostPosted: Thu 28 Jan, 2016 12:23 pm    Post subject:         Reply with quote
I know this is a bit of a necropost, but I just stumbled across this thread while searching for something else.
Those axes are really cool...and massive Eek!
http://www.thehistoryblog.com/wp-content/uplo...th-axe.jpg
- R. Ewart Oakeshott
PostPosted: Fri 29 Jan, 2016 7:17 am    Post subject:         Reply with quote
I like the aesthetic look of them and the context in which they were found is really interesting.
So the axes were probably used in some kind of ritual procession along the road - then perhaps in some ritual combat - and finally deposited according to certain rules.
Jeroen Zuiderwijk
PostPosted: Fri 29 Jan, 2016 11:34 am    Post subject:         Reply with quote
Bronze age Denmark does seem to have had a thing for giant axes, lasting from the early bronze age up to the end of the bronze age. While you have to be really careful labeling anything ceremonial, at least for the late bronze age axes it is very obvious they were never intended to be used, such as the giant 7kg weighing axes or the later totally hollow cast blunt axes.
N.b. one of such large flanged axes made it all the way down to the Netherlands. I doubt that this one is included in the 5 known examples.
Jeroen Zuiderwijk
- Barbarian metalworking
- Museum photos
PostPosted: Fri 29 Jan, 2016 2:08 pm    Post subject:         Reply with quote
Thanks for showing the picture. 28 cm is pretty respectable. Interesting that its called a "Randbijl" in Dutch.
En bredbil in Danish (= Broad bil) is a special woodcarving axe, especially used for shipbuilding in the viking age.
Use of bredbil by Nationalmuseet when fine cutting planks on a viking ship.
Source: https://c1.staticflickr.com/5/4154/5017591846_aba415b1e8.jpg
Actually I don't know what 5 former finds they refer to.
This example you give is probably the result of a gift exchange which seems very typical of the indo-european bronze age gift-exchange network. Maybe to secure alliances across trading networks, so you had security in passage based on the sacrality of guest friendship and gift exchange.
I was also careful not to exclusively call the axes for ceremonial, but the really big ones found at Boest seems unlikely to have been used in massed battles (but then again who knows?), but I certainly find it plausible they could have been used in duels, that often takes place within a highly ritualistic framework (whether it is judicial based and connected with sacrifices).
