Forum Index > Historical Arms Talk > Is this an antique Kris, or one that is relatively new? Reply to topic
M. Lanteigne
PostPosted: Fri 03 Oct, 2014 5:48 am    Post subject: Is this an antique Kris, or one that is relatively new?         Reply with quote
My spouse's mother's friend was recently given this Kris as a gift. I know nothing about them! They wanted some information on it, since they literally have none. Comes with an interesting looking scabbard too. Anyone date this or have any information? Thanks!
 Attachment: 57.97 KB
 Attachment: 91.69 KB
 Attachment: 141.05 KB
 Attachment: 94.1 KB
 Attachment: 57.36 KB
"Iron Sharpens Iron"
S. Issara
PostPosted: Fri 03 Oct, 2014 7:36 am    Post subject:         Reply with quote
It 's not new reproduction. But my knowledge on this topic is quite slim.
Beside this forum, you may also find answer on http://www.vikingsword.com/vb/forumdisplay.php?f=11 too.
Mark Moore
PostPosted: Fri 03 Oct, 2014 9:18 am    Post subject:         Reply with quote
If I had to say....I would call it a genuine antique. If it is modern-made..........it's a darn fine job of antiquing , and I give great homage to the maker. Big Grin ...........McM
Dan P
PostPosted: Fri 03 Oct, 2014 11:38 am    Post subject:         Reply with quote
My best guess from the pictures would be the blade is modern. Traditionally made kris are made with poor quality metal that must be folded repeatedly to be good enough for a blade, and is still bad quality compared to modern monosteel or the folded steel that Japanese smiths produce. Combined with the incredibly humid southeast asian climate, old kris blades kept anywhere other than highly protective environments with constant upkeep corrode and literally delaminate rapidly.
However, many craftsmen who make kris blades reuse old or antique handles and scabbards. Looking closely at the pictures, the handle itself might be made of stacked leather, which I believe is a modern technique. That doesn't rule out the possibility of the metal fittings and scabbard being older.
Co-incidentally, I was travelling in Malaysia less than a year ago, and saw places where traditional kris blades were being sold. My feeling is that local craftsmen tend not to go for "intentional aging" as an aesthetic effect or for deceptive purposes, of course that may not be true for the agents who sell them to ebay or bring them to the US as "antiques". Other than that, traditional kris are not particularly interesting to me either as practical blades or martial weapons, not being particularly good for either purpose, and I'm not a native malay so keeping one for luck doesn't make sense. And also Singapore explicitly bans transporting kris through their airport, even in checked luggage.
Finally, a word of warning. Traditional kris, and probably yours, most often have a thin, rat-tail tang that is little more than glued into the handle. Combined with low quality folded metal, this creates a weak point at the handle juncture which is prone to breakage, so it is highly inadvisable to attempt to practice cut or even swing around such a blade.
S. Issara
PostPosted: Fri 03 Oct, 2014 12:11 pm    Post subject:         Reply with quote
Keris s' hilts are generally left loose. So, the owner may rotate it around or even replace it with nicer one. Traditionally, no adhesive in the hilt, only some cloth piece or organic material around rat tail tang. So, swing her around could be dangerous.
This is thrust weapon, do not expect her to perform cut.
Tyler Jordan
PostPosted: Fri 03 Oct, 2014 11:47 pm    Post subject:         Reply with quote
The steel quality of that blade looks much, much higher than most kris I have seen. I should put up a pic of mine.
The blade of yours looks fantastic. Authentic antique or not, I think it's a keeper.
M. Lanteigne
PostPosted: Sat 04 Oct, 2014 8:35 pm    Post subject:         Reply with quote
Thanks for the information folks. I agree, that blade IS pretty nice. I'll tell the owner what I have learned about it here.
Thanks again!
Reading list: 7 books
PostPosted: Mon 06 Oct, 2014 5:00 am    Post subject:         Reply with quote
All I can say is that it doesn't look Javanese or Balinese -- or if it originally came from these regions, it must have been rehilted outside Java/Bali since the size or shape of the grip is completely unlike the knob-ended all-wood grips I'd expect to find in a Javanese/Balinese keris. The blade, however, does look Javanese, and the sheath is a gayaman variety I'd normally expect to see from Bali or far Eastern Java. My best guess is that it has been rehilted in the West.
