Forum Index > Historical Arms Talk > What are these? Reply to topic
Ricardo S.
PostPosted: Wed 12 Feb, 2014 10:39 am    Post subject: What are these?         Reply with quote
Hi. Does anyone knows what are these pins on this ballock dagger?
 Attachment: 150.57 KB
SI VIS PACEM, PARA BELLUM
My website:
http://songsha8.wix.com/ricardoartesao
Mart Shearer
PostPosted: Wed 12 Feb, 2014 10:48 am    Post subject:         Reply with quote
Attachments for the metal plate between the blade and handle?
Ricardo S.
PostPosted: Wed 12 Feb, 2014 11:57 am    Post subject:         Reply with quote
Indeed, that is my guess, but i couldn't find any photos to make sure...
My website:
Leo Todeschini
PostPosted: Wed 12 Feb, 2014 12:11 pm    Post subject:         Reply with quote
In fact that is a Dudgeon dagger and was a late 16th/early to mid 17th development of the bollock dagger favoured in Northern England and particularly Southern Scotland.
The pins were used from the 15thC onward, though rare, and became common during the early to mid 16thC. They were used to hold the guard plate in place. When I make these daggers I use the pins to keep the parts aligned as I work and assemble them rather than to hold the knife together as such.
I hope that helps
www.todsworkshop.com
www.todcutler.com
PostPosted: Wed 12 Feb, 2014 12:27 pm    Post subject:         Reply with quote
The decorative rivet heads on the bulbous ends of the ballocks are an attractive feature on a lot of ballock and dudgeon daggers.
You can't see it in this angle, but if you were to look under the curved plate at the end of the grip, you'd likely be able to see the mushroomed ends of the pins.
Ricardo S.
PostPosted: Wed 12 Feb, 2014 1:58 pm    Post subject:         Reply with quote
Nice. Thank you very very much for your help guys. That's quite a bit of good information. Thank's a lot!!!
My website:
Ricardo S.
PostPosted: Thu 27 Feb, 2014 10:17 am    Post subject:         Reply with quote
Nice, thank you very much Sir. By the way, do you know how did they take measures so that pins are aligned?
My website:
Jeffrey Faulk
PostPosted: Thu 27 Feb, 2014 1:43 pm    Post subject:         Reply with quote
Simply drill through both the plate and the wood. The rivet holes would probably have been punched in the metal plate before putting it on the grip, so they would have just held it on there and then used a 'birdcage' awl or similar tool to bore the hole for the rivet pins.
Ricardo S.
PostPosted: Fri 28 Feb, 2014 6:03 am    Post subject:         Reply with quote
I see. That makes sense and is a good idea punch the pins in the plate before. Thank you a lot!
My website:
