Forum Index > Historical Arms Talk > Plume Holders Reply to topic
Nathan Quarantillo
PostPosted: Tue 21 Aug, 2012 9:18 pm    Post subject: Plume Holders         Reply with quote
How does a plume holder for a helmet work? Very basics, what IS it, and how would one make, attach or use one? Pictures would be greatly appreciated.
If we wanted to really narrow down a date, let's say 1350 ish, but really any will do.
-Thanks for any help. Happy
Mart Shearer
PostPosted: Wed 22 Aug, 2012 10:20 am    Post subject:         Reply with quote
For 1350, you're more likely to find this sort of ornament on a helm used in tourney.
It works by pushing the quill of the feather into a narrow hole to hold it in place. There are a few varieties, but commonly thin sheet is rolled into a cone and soldered or riveted to an attachment plate. An ancient example:
http://p2.la-img.com/482/3026/1299297_1_l.jpg
And a Ren exaple on the back of the helm:
http://www.skinnerinc.com/full/772/833772.jpg
And an Oriental version:
http://www.cowanauctions.com/itemImages/ff8279.jpg
Another method is to have a block or orb with a narrow hole in it, IIRC that's what the pomegranate does here:
http://www.bladeturner.com/picture/creampuff_salet.jpg
Here's some plumage on a bascinet from 1418, Cpg 359 Rosengarten zu Worms
http://digi.ub.uni-heidelberg.de/diglit/cpg359/0086
Sometimes, the plumes (peacock tail feather "eyes" in this c. 1260 case) seem to be simply stuffed into construction seams:
 Attachment: 60.39 KB
Nathan Quarantillo
PostPosted: Wed 22 Aug, 2012 3:09 pm    Post subject:         Reply with quote
Technical question, how does the plume holder actually hold the feathers?
BTW, thank you for the links, they're great.
Mart Shearer
PostPosted: Wed 22 Aug, 2012 5:49 pm    Post subject:         Reply with quote
Friction? Maybe combined with a little wax... Put a 4mm quill in a 3mm hole.
Raman A
PostPosted: Wed 22 Aug, 2012 11:16 pm    Post subject:         Reply with quote
You put in your plumes, then jam in two triangular wooden wedges. I'm sure there are multiple ways, but as far as I know this was the historically used method.
Mark T
PostPosted: Thu 23 Aug, 2012 6:12 pm    Post subject:         Reply with quote
One of Carlo's books also shows a helm with a plume holder as well as two small holes further up the back of the helm so that the plume could be tied on with points.
Schallern sind sehr sexy!
Nathan Quarantillo
PostPosted: Thu 23 Aug, 2012 8:14 pm    Post subject:         Reply with quote
Thank you all, this is really good stuff. Happy
