Forum Index > Off-topic Talk > Show us your neck protection! Reply to topic
Jim Mearkle
Reading list: 3 books
PostPosted: Sat 14 Jan, 2012 9:08 pm    Post subject: Show us your neck protection!         Reply with quote
Am I the only one that was bothered by the comment in the Swordfish injury report about the lack of standards for neck protection? Worried It seems to me that between the larynx and various major blood vessels, neck protection would be second only to eye protection in importance.
So, I thought I'd start this thread. What do you spar with, and what do you use to protect your neck during sparring?
I primarily fence rapier, with occasional longsword, and this is my gorget. Except for being once gauge lighter (18 ga sheet steel, iirc), it's a standard SCA rattan gorget. I wear it over a 4-layer hood just in case a shot comes in up under the bib of my mask. It's about 15 years old at this point.
A friend has one too, and he took a shot hard enough to "oilcan" the steel and flake off a square inch of lacquer. He suffered no ill effects. I also find that hard face hits are distributed between the brow pad and gorget.
100_0158 by rapierlynx, on Flickr
100_0159 by rapierlynx, on Flickr
Jim
Sam Gordon Campbell
PostPosted: Sun 15 Jan, 2012 3:12 am    Post subject:         Reply with quote
I use a one for pretty much everything and anything at the moment. An old video of what I use can be found here.
Host of Crash Course HEMA.
Jim Mearkle
PostPosted: Sun 15 Jan, 2012 7:23 pm    Post subject:         Reply with quote
A bit of overlap between the front and back pieces wouldn't be a bad idea, but otherwise it looks like it should be effective, especially if you replaced the thongs with straps and buckles.
Jim
Sam Gordon Campbell
PostPosted: Mon 16 Jan, 2012 6:33 pm    Post subject:         Reply with quote
I did replace them with buckles and straps. The pieces butt up against one another so there's no gap. Happy
Chuck Russell
Reading list: 46 books
PostPosted: Tue 17 Jan, 2012 3:11 am    Post subject:         Reply with quote
William P
PostPosted: Tue 17 Jan, 2012 7:47 pm    Post subject:         Reply with quote
whats the difference between a bevor and a gorget?? does one just cover more than another? or is one more laminated?
Andrew Pribor
PostPosted: Mon 06 Feb, 2012 4:26 pm    Post subject: Show us your neck protection!         Reply with quote
This is a brigadine gorget I made from a kit that came from Windrose armoury. I customized the kit quite a bit though & used only the metal plates & general pattern in the end.
The heavy 14oz. leather around the neck backed with sheep shearling is suprisingly comfortable & protective.
"The Bow brings grief and sorrow to the foeman; armed with Bow may we sudue all regions."
Chuck Russell
PostPosted: Mon 06 Feb, 2012 4:56 pm    Post subject:         Reply with quote
andrew man, i hate to tell you. but u really should get more sun. your kinda looking pale. maybe you should eat moer as well, your nothing but bone man
Mackenzie Cosens
PostPosted: Tue 07 Feb, 2012 3:21 pm    Post subject:         Reply with quote
This is an old gorget by Matt http://www.madmattsarmory.com/inv_neck.php. I have modified it rolling the top edge and heat blueing it and some other minor mods. I just started playing SCA Cut and Thrust and this lets me play.
The second one is in progress, it is a modified pattern from Talbot http://talbotsfineaccessories.com/books/metalwork.html
It will be either scale or brigandine and will not be as nicely decorated as Andrew's very similar pattern.
m
 Attachment: 73.11 KB
 Attachment: 48.75 KB
