Patrick Lawrence
Scott Woodruff
Posted: Mon 09 May, 2011 10:45 am Post subject: |
I remember seeing a picture of an early 14th century effigy of an Italian Templar knight wearing a similar coat of plates with external plates. I have no pictures or references to back this up, but it seems that while interior plates were the norm, exterior plates were at least occasionally used during the late 13th through the 14th century.
Patrick Lawrence
Posted: Mon 09 May, 2011 10:52 pm Post subject: |
Thanks Scott every instance helps. Might be something I recreat some day
Scott Woodruff
Posted: Tue 10 May, 2011 7:22 am Post subject: |
Yes! I am gearing up to make a couple of coats-of-plates. One will have internal plates of plastic for SCA, while the other I want to make with large external plates of steel for reenacting. I think I saw the Templar effigy on a thread on this site about crescent (oakeshott type N or O) pommels. His coat-of-plates even had sleeves! I know that Osprey books should be taken with a grain of salt, but "The Baltic Crusades" and "Medieval Scandinavian Warriois I and II" show some examples of external-plate coats-of-plates. It is possible that these were heavily influenced by Eastern/Steppe armours. Aside from the Hokham illustration, all the armour of this type I have seen has been from Scandinavia, Germany and Italy, regions with closer ties to the east.
Craig Shackleton
Posted: Tue 10 May, 2011 7:43 am Post subject: |
On page 74 of Arms and Armour of the Medieval Knight there is an image from the Romance of Alexander. The caption says that it depicts two knights wearing plates attached to a lining and without a cover.
However, there are several knights in the picture, and I am not certain which two are being referred to. They all look like they are wearing pretty standard Coats of Plates to me.
YMMV
Ottawa Swordplay
Patrick Lawrence
Randall Moffett
![](images/avatars/42085057945e09886ee938.jpg)
Posted: Tue 10 May, 2011 5:29 pm Post subject: |
I had thought the Kuyuks were made as a scale shirt from the ones I have looked at in the past. If you look at Nicolle's arms and armour of the crusading era he has some of the plates in a way you can see their attachment.
I'd be interested in the riveted versions like you have up in fair shape so we can see if there was any overlap.
Patrick Lawrence
Posted: Tue 10 May, 2011 6:46 pm Post subject: |
Yes I am curios how they were put together also.
