Forum Index > Off-topic Talk > Left handed cutting practice Reply to topic
Lancelot Chan
PostPosted: Tue 22 Feb, 2011 1:31 am    Post subject: Left handed cutting practice         Reply with quote
http://www.youtube.com/watch?v=JgSy8-ihVqM
The targets were around 3.5" to 4.25" thick. I tried 3 kinds of downward diagonal cuts with some of the cuts didn't even fully reach the targets.
Ancient Combat Association http://www.acahk.org
Realistic Sparring Weapons http://www.rsw.com.hk
Nightstalkers http://www.nightstalkers.com.hk
Lancelot Chan
PostPosted: Sun 27 Feb, 2011 2:23 am    Post subject:         Reply with quote
http://www.youtube.com/watch?v=qOKf5C8az7k
I named it "Turbo cut". In the past I would have difficulty, ie. feeling high resistance, in dealing with rolls bigger than 4.5" in diameter with diagnonal cut. My horizontal cut record was 6" but diagonal cut, even with right handed, was only 4.5" barely. This time, I applied the newly learned method on my left hand and tried out a 4.6" roll. It went through so smooth!!!
Colt Reeves
PostPosted: Sun 27 Feb, 2011 1:02 pm    Post subject:         Reply with quote
One thing I noticed here is that you are very close to your target, so close that if it was an opponent I would expect to see grappling involved at some point. Is there a reason for that? I see you don't do it for all your cutting videos, and not when sparring. I would have thought it would be easier to cut further away and stepping in arms outstretched (at the end of the blow, I.E. Long Point or Langenort).
"Tears are for the craven, prayers are for the clown.
Halters for the silly neck that cannot keep a crown.
As my loss is grievous, so my hope is small.
For Iron, Cold Iron, must be master of men all..."
-Cold Iron, Rudyard Kipling
Lancelot Chan
PostPosted: Sun 27 Feb, 2011 7:14 pm    Post subject:         Reply with quote
There are different scenarios and different applications. For the very closed one where my hand was touching the targets, it was used when my opponent is closing in or thrusting at me. I practiced these close-cuts more often because from my European longsword background, I'm already familiar with cutting at extended range. So I have to get myself proficient with the closer-range cut of Chinese martial arts that involve different body mechanics.
Lancelot Chan
PostPosted: Wed 23 Mar, 2011 6:44 am    Post subject: Right handed cut this time         Reply with quote
http://www.youtube.com/watch?v=IvJ5UdrktU8
4.75" roll done with diagonal and horizontal.
Lancelot Chan
PostPosted: Tue 05 Apr, 2011 4:15 am    Post subject:         Reply with quote
http://www.youtube.com/watch?v=Vo0Oh4GqPp0
newspapers roll cored with 15cm thick nylon rod
