Forum Index > Off-topic Talk > ISO PoleArm Shaft Wood Source for DIY project Reply to topic
Chris Arrington
PostPosted: Fri 17 Dec, 2010 12:06 pm    Post subject: ISO PoleArm Shaft Wood Source for DIY project         Reply with quote
Well, I finally got around to ordering my GDFB/Hanwei PoleAxe head.
I am happy with my purchase, even though I find it much lighter and smaller than I thought it would be.
Now my problem is hafting it. In my rural area (WV) there are two sources of wood. Lowe's and Home Depot. I figured I would get 1 1/2" by 1 1/2" by 6 foot. I was looking for Ash, Hickory, or Oak.
Unfortunately, the best I can find is Red Oak 1 1/2" by 1 1/2" in 2 foot lenghts. Or Poplar in 1" by 1 1/2" in longer lengths. From my understanding, the Poplar is not a good choice for a polearm shaft.
Do you guys have any suggestions, or sources of wood shafts from the internet?
Thanks!
Scott Hrouda
Likes: 15 pages
Reading list: 87 books
PostPosted: Fri 17 Dec, 2010 12:19 pm    Post subject:         Reply with quote
Good afternoon Chris!
Go to the wheelbarrow isle and pick up an ash replacement handle. See the threads below for more information.
Pollaxe/Streithammer Project
Hafting my Poleaxe Head
Tjarand Matre
PostPosted: Fri 17 Dec, 2010 12:49 pm    Post subject:         Reply with quote
Poplar grows too fast, it will be wobbly and could snap if you swing the weapon too fast.
For good wood sources, try to tag along on any archery fora, they are usually well informed about sources for ash/yew/elm. If you could pick any wood, I'd go for elm.
PostPosted: Fri 17 Dec, 2010 1:15 pm    Post subject:         Reply with quote
You could buy hickory hafts from Purpleheart:
http://www.woodenswords.com/WMA/staffs.htm
The quality of the wood wouldn't be in doubt. Wink
If you have a local Eastern martial arts store you could buy a " BO " staff and use it for a spear but if you are looking for oversized ( Over 1 1/8" ) or octagonal hafts it might be more difficult to find.
I've mounted some spear heads on a White Oak Bo staff with good results and reasonable confidence since I have trained with a Bo staff for European quarter staff and they hardly show any signs of impacts after years of use against other staffs of lower quality wood.
Chris Arrington
PostPosted: Fri 17 Dec, 2010 3:20 pm    Post subject:         Reply with quote
Jean,
I'll check them out, but I was wanting square. Octagonal is a possibility I guess.
Scott,
I remembered you all discussing replacement handles, but when I looked, I thought they were too short. How long are they? I'll look again this weekend.
Thanks guys !
Scott Hrouda
Likes: 15 pages
PostPosted: Fri 17 Dec, 2010 4:30 pm    Post subject:         Reply with quote
The wheelbarrow handles are 5 feet (60") long. My finished poleaxe is 5' 7" (67") long. 5 1/2' to 6' is in the right neighborhood for a poleaxe. I would like to get my hands on a copy of Waldman's Hafted Weapons in Medieval and Renaissance Europe: The Evolution of European Staff Weapons between 1200 and 1650 that Chad has recommended.
Ron Reuter
PostPosted: Fri 17 Dec, 2010 4:33 pm    Post subject:         Reply with quote
Chris,
I also had a hard time finding a haft for my polearm. What I ended up doing was purchasing 2 pieces of oak that measured 1 1/2" x 3/4" (1x2), 6 ft long, and glued them together (lowes). I ended up with a piece of oak 1 1/2" x 1 1/2" inch. I then used a belt sander to quickly size the board to roughly 1 1/2" x 1" . I then used my router and carved 45 degree angle on each corner. The seam is very hard to see. I have included a couple of pictures.
Ron
www.yeoldegaffers.com
