Forum Index > Historical Arms Talk > swine feathers/swedish feathers Reply to topic
Leo Todeschini
PostPosted: Tue 26 Oct, 2010 9:05 am    Post subject: swine feathers/swedish feathers         Reply with quote
Hi All,
I am looking for any information, particularly pictorial, on a type of musket rest/staff weapon called Swine Feathers or Swedish Feathers.
Has anyone got any leads?
Any help would be appreciated.
www.todsworkshop.com
www.todcutler.com
Stephen Wheatley
PostPosted: Tue 26 Oct, 2010 9:25 am    Post subject:         Reply with quote
Tod,
Try the Landeszeughaus website (Graz) I know they had some, otherwise the Osprey series ''Gustav Adolf Infantry 30 years war'' has an illustration (p 19) - I'd scan it for you but mine's broken. Meantime I'll see what I can find on German websites.
Stephen Wheatley
PostPosted: Tue 26 Oct, 2010 10:25 am    Post subject:         Reply with quote
Good info here:
http://books.google.com/books?id=vVFIAAAAYAAJ...mp;f=false
The mention of "Skelton's engravings" seems like a hot tip.
PostPosted: Tue 26 Oct, 2010 10:43 am    Post subject:         Reply with quote
Here's somebody's interpretation:
 Attachment: 48.46 KB
PostPosted: Tue 26 Oct, 2010 10:47 am    Post subject:         Reply with quote
More here:
http://www.myArmoury.com/talk/viewtopic.php?t...t=sackbuts
 Attachment: 30.66 KB
Daniel Staberg
PostPosted: Tue 26 Oct, 2010 11:04 am    Post subject:         Reply with quote
I'm afraid that description from google books is rather misleading since the author has confused the swinesfeather with the early plug bayonet and have mixed source material regarding the two weapons.
The Swinesfeather was basicly a shortend version of the pike which was issued to musketeers to provide additional protection from cavalry (it was used in the same manner as the Archer's stakes of the 100 Years War). The Swedes made extensive use for them when fighting the Poles & Lithuanians in the 1620's hence the "Swedish feather" name used by some authors.
The Swedish army issued swinesfeathers in addition to musket rests which gave the musketeer a lot of items to handle at the same time. Hence Sir James Turner's description.
Because of these problems there were a number of military writers who wanted to combine the musket rest and the swinesfeather. The problem was that it could only be used for one duty at the time, if used as a musket rest it was useless against cavalry but if planted firmly at the right angle to defeat a charge it was of no use as a rest for the musket.
PostPosted: Tue 26 Oct, 2010 11:07 am    Post subject:         Reply with quote
Ah...so it was meant to be a static defense rather than a Swedish Army Knife.
Reading list: 7 books
PostPosted: Sun 31 Oct, 2010 1:24 am    Post subject:         Reply with quote
Ouch. Talk about "heavily loaded." What's the provenance of that illustration, BTW? It's a bit interesting to see that the soldier seems to be wearing a helmet--and a burgonet at that--rather than a morion/cabasset or a hat, and it makes me wonder how early the depiction is. Is it from the Polish wars rather than the Thirty Years'War?
Daniel Staberg
PostPosted: Fri 05 Nov, 2010 4:13 am    Post subject:         Reply with quote
Wendelin Schildknecht was a German Engineer who fought both against and with the Swedes in the 17th Century, in 1652 he published "Harmonia in Fortalitiis..." (full title below) which contains one of the best written descriptions of the swinefeathers used by the Swedes.
The Swinefather is described as "as strong, long and thick as the shaft of a "knebelspeiss" (mostly translated as boarspear in English) with a spike 2 "Spannen" (44cm) long at the front and a iron point at the rear.
Harmonia in Fortalitiis construendis, defendensis & oppugnandis. Das ist: Eine einstimmige, gründliche und aussführliche, auch dabey lustige und anmuhtige Beschreibung Festungen zu bawen: Solche so woll in Bodenlosen und Sumpfichten, als auf festem grunde ausszuführen ... und dann auch aufs eheste zuüberwältigen. Ist also in 3 Theil verfasset: Der erste Theil handelt von einer newen, besondern und geschwinden Art: Wie man die Logarithmos, Sinus und Tangentes ... auf drey Regulen oder Messinge Linial ... auftragen soll ... Der ander Theil weiset einen artigen leichten Handgriff, wie man den Irregular- auss dem Regular Baw fügligst anlegen soll ... Der dritte Theil handelt Anfangs von der Offension, wie man eine Festung umbzingeln und belägern, untergraben, durch Minen, Sprengen ... soll. Allen Kriegsliebenden zum Vnterricht und sonderbaren Nutzen fürgeschrieben durch Wendelin Schildknecht, weiland Fürstl. Pommerisch. und noch jetzo der Stadt Alt. Stettin Ingenieur und Zeugmeister ...
Radovan Geist
Likes: 5 pages
PostPosted: Tue 17 May, 2016 1:28 am    Post subject:         Reply with quote
Little bit of necromancy, and surely too late to be of any help to Tod... but looking for something else, I´ve found this item auctioned on HH some time ago. It´s quite interesting and I actually think of re-creating something similar.
 Attachment: 125.05 KB
Mike Ruhala
PostPosted: Tue 17 May, 2016 8:50 am    Post subject:         Reply with quote
Interesting. There is a weapon called a "saufeder" which literally translated would render "pig's feather" but it's not like the implements above, it is a boar spear. I also suspect that "feder" had an alternative meaning of "blade" kind of like how in English we can have the blade of a weapon or a blade of grass.
