Jake Wilson
Posted: Wed 09 Sep, 2009 2:57 pm Post subject: charcoal burning temps. |
Hello,
I am preparing to build a "charcoal heat treating pit" in order to heat treat 1060-1095 carbon steel. Does anyone here know the approximate burning temperature of a sitting charcoal fire? Is this enough to get the steel to the appropriate temps for quenching? Or is forced air blowing a necessity? I know it needs to be in the neighborhood of 1500 F or thereabouts depending on the steel.
I'm curious as to the fire temp of the non forced air fire to determine about how much air will need to be used to increase the temperature. Also, when preparing the fire, how do those here determine when the fire is hot enough to place the steel in the fire to prepare it for quenching?
Thanks.
Jason Dingledine
Posted: Wed 09 Sep, 2009 7:46 pm Post subject: |
You'll need forced air of some sort or another. Either via an electric blower (even a hair-dryer will work), or a bellows.
Jason Dingledine
Arne Focke
Posted: Thu 10 Sep, 2009 4:20 am Post subject: |
Depends on the quality of the charcoal.
In most cases you will need some assistance from forced air.
Only the highest quality charcoal will work without, but its almost impossible to get.
So schön und inhaltsreich der Beruf eines Archäologen ist, so hart ist auch seine Arbeit, die keinen Achtstundentag kennt! (Wolfgang Kimmig in: Die Heuneburg an der oberen Donau, Stuttgart 1983)
R D Moore
Posted: Thu 10 Sep, 2009 7:43 am Post subject: |
A variable speed hair dryer could be taped to a length of pipe connected to your tuyere for your blower. And there are lots of ideas for simple forges on the internet so you shouldn't have too much trouble getting started.
Jeroen Zuiderwijk
