Stephen Pearson
Posted: Mon 22 Mar, 2004 2:40 pm Post subject: New Albion Sword Displays! |
I have no idea how long this has been up on their page, but I just noticed that Albion has introduced three new sword displays. They all look fantastic and are far more reasonably priced than some of their previous offerings. I'm especially drawn to the PoB stands -- very unique! Kudos to Albion to coming up with an artful and different (not to mention less expensive!) method for displaying one's swords. I’ll definitely be adding some of these to my next sword purchase!
Check out the new stands at: Albion Display Page
The only situation a commander can know fully is his own: his opponent's he can know only from unreliable intelligence.
Clausewitz, On War
Steve Fabert
Posted: Mon 22 Mar, 2004 5:51 pm Post subject: |
Just in time, too. I am running out of space to hang swords on the wall, and could use some new ideas for table displays.
Cor Böhms
Location: The Hague,The Netherlands Joined: 04 Dec 2003
Posted: Tue 23 Mar, 2004 12:35 am Post subject: |
I like the new PoB displays from Albion. Just wonder if the partial contact with the wood wont discolor the blade that way,
in time.
Audacia magia est
Tai Tam
Posted: Wed 24 Mar, 2004 2:31 pm Post subject: |
What is the name of that sword at the bottom of the picture?
Michael Sigman
Posted: Wed 24 Mar, 2004 2:50 pm Post subject: |
Thanks for all the compliments guys!! We really appreciate it!!
Tai Tam wrote: | What is the name of that sword at the bottom of the picture? |
The bottom one is actually one of Jody Samson's pieces. It is called the Curved Dagger. You can see it on http://www.jodysamson.com/news.htm about half way down the page.
Mike Sigman
Albion Swords
Cor Böhms
Posted: Fri 26 Mar, 2004 2:46 am Post subject: |
I can understand why most people like the new Albion PoB displays, but I am still a bit worried
about partial discoloration of the blade by permanent contact with the wood and being shut from the
light. and that allways on the same spot! Only time will tell the results.
Cor.
Audacia magia est
Eric McHugh
Posted: Fri 26 Mar, 2004 5:11 am Post subject: |
Cor Böhms wrote: | I can understand why most people like the new Albion PoB displays, but I am still a bit worried
Cor. |
Hi Cor,
The wood is sealed, so discoloration will not be a problem. As far as discoloration from being shut from the light, that discoloration (which would take a very long time to occur) can be fixed with a scotch-brite pad and some mineral oil. The expectation behind these PoB displays is that they not be a "permanent" display in the sense of permanently mounted. Customers are suppose to take their swords off of the display from time-to-time for dusting and cleaning. We do use high carbon steel (and not stainless steel) in our blades, so regardless of what material is used for the display, a certain amount of periodic maintenance and cleaning is required. If this periodic maintenance is observed, it should prevent possible discoloration.
Hope this helps.
Find me on Facebook, or check out my blog. Contact me at eric@crownforge.net or ericmycue374@comcast.net if you want to talk about a commission or discuss an available piece.
Steve Fabert
Posted: Fri 26 Mar, 2004 5:36 am Post subject: |
Eric McHugh wrote: | Customers are suppose to take their swords off of the display from time-to-time for dusting and cleaning. |
Mine come down off their displays a lot more often to be passed around and talked about, than just for cleaning. They get a quick rubdown whenever they are handled. Any form of display that allows easy access to the sword for such "show-and-tell" sessions is entirely welcome. POB displays are certainly superior to wall mounts, if your primary goal is to get the sword in hand and back again with the least amount of bother.
Cor Böhms
Posted: Fri 26 Mar, 2004 11:18 am Post subject: |
Thanks Eric,
Your explanation sounds convincing to me.
It's a good thing for a manufacturer to react on doubts of people on their product, and it is only fair.Also of the
myArmoury forum to give forummembers that opportunity
The PoB diasplay is a wonderful idea . It leafs all the attention to the sword. Cheers!
Best regards,
Cor
Audacia magia est
Geoff Wood
Posted: Fri 26 Mar, 2004 12:32 pm Post subject: |
Cor. |
Doesn't have to be exactly the same spot, so long as the pob falls within the length of the slot, and with symmetrical swords you could always flip it over every time you handled it. I tend to do that with all my stuff to even out any loads on the blade (probably unnecessary, but it's no problem to do).
Geoff
