LK Chen HH Dao, SS Gladius, Windlass Shamshir For Sale
Heavenly Horse Dao: $200 USD+ Shipping
Same Dao tested by Skallagrim. Very nice pattern welded blade. The adhesive holding the brass bolster on came loose during testing, but was re-glued using adhesive provided by lk chen. No issues since. Otherwise Sword is in excellent condition. Comes with Scabbard and silk bag.
Blade
Blade only weight: 580 g (1 lb. 4oz)
Sword only weight: approx. 600 g (1 lb. 5 oz)
Blade Length: 94 cm (37")
Handle Length: 13 cm (5.1")
Ring Length: 3.8 cm (1.5")
Total Length: 110.8 cm (43.6")
Gradual tapering
Width at hand guard: 25 mm, Width at tip: 20 mm
Thickness: 7 mm - 3 mm at the tip
Point of Balance: 25 cm (10") beyond hand guard
Blade cross section profile: triangular with slight ground
Blade length wide profile: subtle inner curve at the middle of the blade and subtle upward tip.
Folded pattern steel: 1065 carbon steel + T8 tungsten-cobalt-vanadium high-speed tool steel.
Superior heat treatment:
Hardness 54-55 HRC.
Sabersmith Gladius: 250 USD + Shipping
This Sword is a Tank, Very robust sharp edge, and good for backyard cutting. Satin Polish Blade with blackened Hilt components. Sword minimally used and in excellent condition. Comes with Scabbard and Frog.
Blade Length: 22.75 in
Overall Length: 30.25 in
Blade Width: 2 in
Weight:2.6 lb
Steel Type: 1075 High Carbon
Rockwell: 56 – 58c
Pictures in google Doc
https://docs.google.com/document/d/1ROrTxV9VFOKIfa_NV8aUbw2jPA7yTz86eWWiNgybdOQ/edit?usp=sharing
Windlass scimitar: originally owned by Skallagrim. Guard is a little bit loose, and has some wear, but handle and bless are n good condition. Blade very sharp.
Overall Length 35 1/2"
Blade Length 30 1/2"
Weight 1 lb 7.8 oz
Edge: Sharp
Width 28.4 mm - 29 mm
Thickness 3.4 mm - 2.7 mm
Pommel Integrated and Pinned
P.O.B. 8 1/4"
Grip Length 3 1/2"
Blade 1065 High Carbon Steel
Asking 100 USD + shipping
https://drive.google.com/drive/folders/1G6iyBtW6xvG0Po1Z8ujJHCD1IL5X7l5D
Windlass Scimitar Pending Sale
Pending Sale for this sword, others still available.
Windlass Scimitar SOLD- others still available
Bump
Bump
Still for sale
Still available
