I'm looking for a big, European style, two handed sword with a blade that is still as thick and wide as possible near the end of the blade at the start of the tip.
Blade length: preferably over 100cm / 39"
Total length: preferably over 130cm / 51"
Minimum blade width close to the end of the tip: 3cm / 1.2"
Minimum blade thickness close to the end of the tip: 0,45cm / 0.18"
Something like a Del Tin 15th Century Two Handed Sword or a Hanwei Lowlander would fit the bill nicely:
www.kultofathena.com/product.asp?item=PC2065&...reat+Sword
www.kultofathena.com/product.asp?item=DT2158&...nded+Sword
I am also open to other brands, custom made swords, used, bare blades, etc.
I'll very likely cut down the tang since 99% of swords have tangs that are way too thin for my taste so if you have a project blade or one were the threaded tang extension has broken off for example I'm interested as well as long as the blade is long, thick and wide enough.
Please note that I live in The Netherlands, Europe so I prefer something inside Europe due to possible shipping and import taxes.
Let me know if you have something that fits the bill.
Kind regards, Louis
I can't seem to edit my previous post any more but I forgot to mention: The blade should have no fuller near the handle and preferably no fuller at all.
