This is cross posted on another forum. To date this is the best handling sword I've ever held. It has a slightly longer grip than the Met museum Alexandria, and that shows in it's POB and handling. It's a finer piece than the older Jeff Helmes I had, and I didn't cut with that one either.. I just can't bring myself to do it.
I'm planning on putting funds from this towards a Brescia (which I will actually cut with), but I will also take in partial trade an Albion Reeve, Albion Vigil, or Albion Thegn. Those will take off the top of the price of this sword, which is $2500 USD with shipping in the CONUS paid by me. I will also ship internationally, but you would pay for shipping.
Measurements from Sulowski:
total length: 117cm (46.1in)
blade length: 87cm(34.25in)
Blade width: 79mm (3.11in)
Thickness of blade (at the base): 5mm (1.97in)
weight: 1725g (3.8lbs)
balance: 8,5cm (3.35in)
grip length: 23,6cm (9.3in)
hardness: 52HRC
Possibly the last Alex Sulowski will do. PM with any questions.
Pictures can be found here: https://imgur.com/a/TaE5rTk
Quick correction which those who can math will probably have already noticed... I mentioned the thickness of the blade as 5mm or 1.97 inches, but it should have been 5mm or .197 inches.
Price drop to $2400 USD.
I will also consider payment plans if that is more economical for anyone. Thank you.
Bump down to $2300.
Bump. You'd be buying basically a better balanced custom sword than Albions Principe/Alexandria with cool details like the arsenal marks, and a scabbard, for significantly less than those would cost if you bought the Albion with a custom scabbard of the same quality.
Btt. I'll probably leave this at $2300 until the end of the month and then bump it back up to $2500. It wont help it sell any faster, but it's nice enough to where I dont mind hanging on to it a while longer, and $2300 is pretty low. $1250 a pop for the scabbard and sword is already a nice price.
