For sale: full leg armour, 1.2mm stainless steel (NL, EU)
Brand new, never used, doesn't fit my skinny legs.
Probably fits best on a skinny guy with very thick padding, a medium sized guy with medium padding or large guy with thin padding.
Depending on actual leg length probably best suited for a guy somewhere around 175cm tall, maybe 180cm or so at the most.
Some measurements:
Calf circumference (inside of armour, so your exact calf circumference): +/-43.5cm
Ankle circumference (inside): +/-33.5cm
Greave side length: +/-34cm
Knee width (inside): 14cm
Sabaton foot length (inside): +/- 30cm
Sabaton width (inside, front): 11.5cm
Sabaton width (inside, back): 10cm
The entire set weighs almost exactly 8kg.
More specific measurements available on request of course.
The benefit of stainless is that you are able to do (repair)work and adjustments to the fit yourself, you can cut-off or re-shape certain parts fairly easily.
Also comes with a free mace!
Made by Sharukhan Market. Don't expect top quality. I paid 800 euro for the entire set, I'm asking 600 euro. Shipping is negotiable and will be discussed on a case by case basis as it depends a lot on where it has to go. I accept both bank transfer and paypal (Friends&Family or add 4% due to fees). I'm in the Netherlands (Arnhem) so if you are near you are welcome to try it on.
For more info and pictures feel free to send me a message.
