Forum Index > Historical Arms Talk > Details from Wallace Collection/Royal Armouries Reply to topic
This is a Spotlight Topic Go to page 1, 2, 3  Next
PostPosted: Fri 14 Oct, 2011 7:55 am    Post subject: Details from Wallace Collection/Royal Armouries         Reply with quote
Just spent a great week glued to The Wallace Collection and Royal Armouries-Leeds. For this trip I was interested mainly in photographing details of design, construction, decoration and finish. That's easier said than done because both of these collections are notoriously challenging, photographically. I chose my kit for light travel and difficult shooting.
For those interested in the technical specs:
• Nikon D90
• Nikon 50mm f1.8 and 35mm f1.8 (mainly the 35mm because it gives a "normal" perspective on a cropped DSLR and has fantastic close focus). Some of the armour "landscapes" are 50mm f1.8 without the polarizer. That allowed me to stop down enough to get more elements in focus. I typically shot at sensitivity levels of between 800 and 1600.
• Circular polarizer: It cuts reflections like magic but reduces light. The fast lenses and string tripod help compensate for that.
• String tripod: Eye bolt, wing nut, steel washer and rubber gasket. Nut, washer and gasket go over the bolt. Paracord tied to eye of bolt. Knots in free end of cord. Screw bolt into camera tripod socket, step on knot(s), pull taught against body to damp vibration, compose, hold breath, squeeze release, follow through, exhale. Nobody ever questioned my use of this old stabilization trick and it often made the difference between a useable shot and nothing. Of course, it does not mar floors, obstruct other visitors, smash cases, etc. Big Grin
I won't provide captions for these photos and won't post them in any particular order. In most cases the detail of my interest will be apparent. I hope others will find them as interesting and useful. Feel free to ask questions about anything you see here! I'll tell you what I know.
 Attachment: 248.55 KB
PostPosted: Fri 14 Oct, 2011 8:24 am    Post subject:         Reply with quote
When the polarizer created funky color highlights I've converted those images to gray scale.
 Attachment: 229.42 KB
 Attachment: 234.01 KB
 Attachment: 237.82 KB
 Attachment: 239.49 KB
 Attachment: 247.94 KB
 Attachment: 244.34 KB
Craig Peters
PostPosted: Fri 14 Oct, 2011 10:49 am    Post subject:         Reply with quote
Sean,
Congratulations on taking some amazingly detailed and high quality museum photographs! These are really impressive!
Len Parker
PostPosted: Fri 14 Oct, 2011 10:55 am    Post subject:         Reply with quote
Great pictures Sean. I like that two piece sallet. Does that look like specks of red paint on the side, or the polarizer creating funky color highlights as you said?
PostPosted: Fri 14 Oct, 2011 11:28 am    Post subject:         Reply with quote
That looks to be reflected light
Paul Hansen
Likes: 5 pages
PostPosted: Fri 14 Oct, 2011 12:09 pm    Post subject: Re: Details from Wallace Collection/Royal Armouries         Reply with quote
Fantastic photo's!
But you do have to clarify this a bit:
It sounds really useful, but I have some difficulty understanding what you mean exactly.\
Maybe a picture would be useful?
PostPosted: Fri 14 Oct, 2011 12:18 pm    Post subject: Re: Details from Wallace Collection/Royal Armouries         Reply with quote
Paul Hansen wrote:
Fantastic photo's!
Google is your friend.
http://www.instructables.com/id/String-Tripod/
PostPosted: Fri 14 Oct, 2011 12:42 pm    Post subject:         Reply with quote
Yep, that's pretty much it, with a few refinements to protect the baseplate of the camera (washer/gasket) and facilitate tightening (wingnut). I'll get a shot and post here.
PostPosted: Fri 14 Oct, 2011 1:06 pm    Post subject:         Reply with quote
It's probably both. You turn the polarizer to eliminate reflections on the glass. Sometimes the optimal position of the filter created color effects in the remaining reflected highlights. There might also be a color cast to some of the WC lights. I didn't notice, but there might even be colored lights (fire exits, "on" lights of security cameras, etc.) that could tint reflections.
BTW, that's a single-piece sallet. The decorative lines suggest two-piece, which is strange from the modern perspective, which values sets a premium on single-piece raised construction.That's an interesting sallet for other reasons, too. It was retro-fitted for the Bundrennen by the addition of a strange roller contraption on the front edge. The function isn't certain, but Capwell suggests that it might have been meant to prevent the edge of the "exploding" Rennen shield from catching the edge of the sallet as it's sent aloft by a good strike.
PostPosted: Fri 14 Oct, 2011 1:35 pm    Post subject:         Reply with quote
Here's a front view of that Bundrennen sallet, showing the funky roller mechanism (and some unfortunate glass reflections). Further tips for museum photography (which I overlooked on this trip):
-Hold out for a black-ring polarizer if you can find a good one. The silver-ring version I got turns up in some glass reflections (what were they thinking???)
–use black gaffer's tape to cover all lettering on the front of the camera body. Otherwise you'll get a NIKON-branded sallet, as I did in this case, necessitating some burning-in of that reflection.
-wear dark clothing, which will also eliminate reflection.
-get as close to the glass as possible. A soft rubber lens hood is good for this, as it keeps the hard surface of your lens off the glass but still prevents reflection of the lens or intrusion of side light.
I didn't test my idea to get a soft black craft foam sheet and cut a hole in it for my lens. In theory, that could solve some reflection problems. I finally decided it would be too ungainly and attract too much attention. Worth trying if you don't want to pay for a good polarizer.
 Attachment: 222.66 KB
PostPosted: Fri 14 Oct, 2011 1:53 pm    Post subject:         Reply with quote
A few more, for the weekend Big Grin There are two images of the messer grip. I realized the broader view lost the detail of the metal inserts.
 Attachment: 143.93 KB
 Attachment: 146.43 KB
 Attachment: 182.81 KB
 Attachment: 243.85 KB
Gregg Sobocinski
Likes: 5 pages
Reading list: 12 books
PostPosted: Fri 14 Oct, 2011 6:55 pm    Post subject:         Reply with quote
Wow! Nicely done, Sean! Those details are fantastic!
I like the tripod trick. Good ideas are always in style!
Philip Melhop
PostPosted: Sat 15 Oct, 2011 1:09 am    Post subject:         Reply with quote
Great pictures Sean Big Grin It's nice that the Wallace now allow photos to be taken, I was told to leave, after taking one picture, a couple o years ago
Paul Hansen
Likes: 5 pages
PostPosted: Sat 15 Oct, 2011 2:39 am    Post subject: Re: Details from Wallace Collection/Royal Armouries         Reply with quote
Paul Hansen wrote:
Fantastic photo's!
Aha, I didn't realise that "string tripod" was actually a type name rather than a description...
Thanks!
Michal Plezia
PostPosted: Sat 15 Oct, 2011 5:07 am    Post subject:         Reply with quote
Eek! Wow! Outstanding pictures Sean! Thanks for sharing.
www.elchon.com
Polish Guild of Knifemakers
it that is the only truth.
Eric W. Norenberg
PostPosted: Sat 15 Oct, 2011 3:05 pm    Post subject:         Reply with quote
Great work, Sean - very haptic qualities to those shots. Are you planning to post the lot in an album somewhere, or can I send you a USB to load up Big Grin ?
I'm hoping to see similarly beautiful shots (in due time, of course) of the goodies you found mudlarking - anything worth reporting there?
Johan Gemvik
PostPosted: Sun 16 Oct, 2011 12:59 pm    Post subject:         Reply with quote
Good work Sean!
These are some excellet quality photos.
When we visited almost two years ago the guards at Wallace stopped my dad from using his rubber shod monopod, even though it wasn't technically the tripod that's noted to be prohibited in the museum. Good catch using the old school string system. I'll tell Dad about that for next time we go to a museum with our cameras. Wink
Bruno Giordan
PostPosted: Mon 17 Oct, 2011 12:48 am    Post subject:         Reply with quote
This is what I call real pictures! I have a Nikon D3100 for the job, and the new nikon macro 40mm f2.8.It's an amazing lens that reaches a 1.1 reproduction ratio. However the maximum aperture of 2.8often forced me to use very high speeds, even 12800 ISO at Milan's Sforzesco castle.
PostPosted: Mon 17 Oct, 2011 7:12 am    Post subject:         Reply with quote
No mudlarking, though I'd love to do it! Permits are required to be on the Thames foreshore. Being a magpie and slouchy surface-collector, it's so tantalizing to look over the seawall at all the stuff. I actually took a photo of the shore and enjoyed enlarging it to figure out what I was looking at--some old marine joinery, a hobnailed boot, ceramics, mysterious objects...Most of it is probably rubbish to modern mudlarks but even a fragment of pipe stem is interesting to me! I applaud the relationship between the Museum of London and those who explore the Thames. There have been many important finds, all out of context I suppose, but at least documented.
Speaking of which, the knife scabbard above is from MOL's extensive collection. I hope to post more MOL stuff later today. One sword in particular caught my eye. Big Grin
PostPosted: Mon 17 Oct, 2011 7:47 am    Post subject:         Reply with quote
More from the Museum of London. It's definitely a matter of truth over beauty in this this batch. MOL is a tough venue as well. That lovely sword of ca. 1500 really caught my attention this time. It has a broad, thin blade, single edged for a bit over half of its length, with a spatulate tip and pronounced medial fuller almost its whole length. This is one I REALLY wanted to hold. I'd love to make something like this. I have a gaurd and pommel. Just need a good, thin backsword blade. Cool
 Attachment: 209.32 KB
 Attachment: 219.53 KB
 Attachment: 110.06 KB
 Attachment: 75.34 KB
 Attachment: 104.88 KB
 Attachment: 78.29 KB
 Attachment: 178.08 KB
 Attachment: 118.17 KB
Page 1 of 3 Reply to topic
