It’s that time of the year again and Solingen Messermachermesse is about to start. Here’s the latest long piece I have finished: a 15th century style Hungarian sabre.
The sword is modeled after an original from Hieb- und Stichwaffe, but there are some changes. The blade is two centimeters shorter than the original and the S-shaped guard is taken from an another sword. I choose to make a ”neater looking” guard on this, as the original is of such crude workmanship and looks very ill-balanced. Also, the pommel is bit more crispier than in the original.
The sword weights exactly the same as the original with the grip in place, 1,280 kg. The materials used are 0,75%C steel & iron. The grip is cord wrapped birch with doeskin surface.
The other vital stats are as follows: Oa. length: 107 cm, blade length: 85 cm, width of the blade: 3,6 cm next to hilt & 4,4 cm where the false-edge flares out. The width of the guard is 17,2 cm. Near the hilt the blade is 6,5 mm thick and tapers rather neatly towards the tip.
The point of balance is 13 cm from the guard and pivot point and forward vibration node overlap few centimeters before the false edge begins.
Personally, I kinda like the angled grip, even though it takes a little time for the eyes to get used to it. The handle is just long enough for good two-handed grip and the counter curve gives a very controlled feel to the sword.
Sadly, I’m out of tatami mats, so no test cutting was possible.
Here are some pictures of the sword, I hope you like it.
JT
