Drake Dunivan
Posted: Fri 29 Jan, 2010 4:07 pm Post subject: Question about haubergeon |
I wanted to make my own haubergeon and was wondering what guage and diam. should each ring be.
Thanks,
Drake
Romulus Stoica
Location: Hunedoara, Transylvania, Romania Joined: 26 Oct 2006
Posted: Fri 29 Jan, 2010 11:02 pm Post subject: |
It depends from what period and which region you want you knight to be. Also It depends on your skills as an armorsmith... I'd say you could be reasonably accurate for a wide range period, with rings about 7-8mm (0.27 - 0.31 inches) diameter from 1,2-1,6 mm (18-16 gauge) wire. If you are skilled enough, then you should use slightly flattened and wedge-riveted rings.
If you will use riveted rings then you could use less thick wire, if you will use butted rings, then I'd say 1,4 mm (17 gauge) is the thinnest wire you should use.
Posted: Sat 30 Jan, 2010 5:30 am Post subject: |
Wedge riveting was only done in Germany during a relatively short period of itme. Round rivets were far more common.
Drake Dunivan
Posted: Sun 31 Jan, 2010 12:56 pm Post subject: |
What time period range was the wedge riveting done in Germany?
Drake Dunivan
Posted: Sun 31 Jan, 2010 2:26 pm Post subject: |
Thanks for the reply, love the pictures in your artical.
Eric Hejdström
Posted: Mon 01 Feb, 2010 2:38 am Post subject: |
Dan, if it's as good as this, sure it is!
