Forum Index > Historical Arms Talk > Shield edge Reply to topic
Stuart Thompson
PostPosted: Sun 13 Feb, 2011 2:10 am    Post subject: Shield edge         Reply with quote
My latest shield is nude around the edge-Nearly every shield i've seen has some leather, or metal around the edge to bind and make it durable.
What should I use and what tacks are best? I'm thinking of using a rough thick leather with some short nails. Problem is I have a tendency to use the shield as a weapon itself and don't want to smack someone with a loose nail. I doubt this shield will last long anyway but it's chances would be helped by having a secure rim to it.
Thanks all.
sverð er manni vargr, af bardaga er dýrð, í dauða er dýrð.
Philip Melhop
PostPosted: Sun 13 Feb, 2011 4:27 am    Post subject:         Reply with quote
use the trusty old rawhide doggy-chew and stitch it on.
Phil
Mark Routledge
PostPosted: Sun 13 Feb, 2011 5:39 am    Post subject:         Reply with quote
These people http://www.leprevo.co.uk/hides.htm do raw hide in 48 inch x 6 inch strips which works really well stitched on. More expensive than dog chew but pretty good stuff by all accounts.
Stuart Thompson
PostPosted: Sun 13 Feb, 2011 7:16 am    Post subject:         Reply with quote
Excellent, thanks guys!
Philip Melhop
PostPosted: Sun 13 Feb, 2011 10:11 am    Post subject:         Reply with quote
Just use the doggie chews, go to a pet store and buy the largest ones. Soak overnight, wrap in a damp towel for an hour or so and they will be ready to cut into strips and stitch on. Make sure to overlap the joins by a couple of inches as they shrink as they dry.
Phil
Lin Robinson
PostPosted: Sun 13 Feb, 2011 10:54 am    Post subject:         Reply with quote
You can also buy rawhide at your local Tandy Leather store or online.
Lin Robinson
Philip C. Ryan
PostPosted: Sun 13 Feb, 2011 8:03 pm    Post subject:         Reply with quote
Instead of stitching, you can also simply use nails, and clench them back over. I have used this method for sparring shields for years with no problems. Here is another thread discussing how to do this (with pics!).
http://www.myArmoury.com/talk/viewtopic.php?t=18074
Skjaldborg Viking Age Living History and Martial Combat
Stuart Thompson
PostPosted: Mon 14 Feb, 2011 6:49 am    Post subject:         Reply with quote
Thanks Philip! I'll be trying that this afternoon.
