Forum Index > Historical Arms Talk > How about some Iberians? Reply to topic
This is a Spotlight Topic Go to page 1, 2  Next
Peter Johnsson
PostPosted: Thu 11 Sep, 2003 2:16 pm    Post subject: How about some Iberians?         Quote
Sone more tidbits that might interest you.
Last year in Solingen I was presented to some nice old fellows. These are two of them. I was impressed. You may like them too.
The first is a falcata in rather good condition. It feels if it has some sound steel below the rust as the weight was there. Sturdy spine and a keen edge geometry.
First a complete wiew:
 Attachment: 40.58 KB
Profile PM Website
Peter Johnsson
PostPosted: Thu 11 Sep, 2003 2:19 pm    Post subject:         Quote
And so a pic of my left hand grasping the hilt to show how well it is made to fit the hand:
 Attachment: 43.81 KB
Profile PM Website
Peter Johnsson
PostPosted: Thu 11 Sep, 2003 2:27 pm    Post subject:         Quote
A well preserved antennae sword was equally impressive. The hilt was made in a all-steel construction with a hollw grip that still showed the seam on one side. Not welded shut, just made to fit very tightly. The cross, or guard, was wrapped around the base of the blade and fastened with two rivets. Some file work was added sparingly to great effect.
The spheres at the end of the antennae arms were hollow, riveted together by the protruding arms.
I think there exist some swords of this type that are slightly longer, but not much. This was not much bigger than a very large dagger, but absolutely had the feel of a sword.
 Attachment: 51.63 KB
Profile PM Website
Fredrik Hörnell
PostPosted: Thu 11 Sep, 2003 2:32 pm    Post subject:         Quote
Nice.
I have always liked the looks of a Falcata.
Seems to me that it would be a nasty weapon too.
What is the bladegeometry like?
Does the edge start from the spine so to speak, or it is more oval in shape?
(I hope you understand what i am asking for, i cant seem to put what i mean in words.)
Profile PM E-mail
Peter Johnsson
PostPosted: Thu 11 Sep, 2003 2:43 pm    Post subject:         Quote
Again, to get an idea of its size my left hand is holding the sword. As you see the girp is not very long. If you grasp it tightly your hand will be pressed between the guard and the antennae. It is no uncomfortable but makes for a very secure grip.
It does not show very clearly in the photos, but the blade had a nice and crisp cross section with a set of fullers and risers that were skillfully filed and/or ground.
 Attachment: 62.31 KB
Profile PM Website
Geoff Wood
PostPosted: Thu 11 Sep, 2003 2:52 pm    Post subject:         Quote
Mr Johnsson
In the falcatahelbild jpg, on the drawing you show some additions on the hilt. Are these just measurement lines or some speculation as to additional structure that has been lost?
Peter Johnsson
PostPosted: Thu 11 Sep, 2003 2:55 pm    Post subject:         Quote
Fredrik Hörnell wrote:
Nice.
The very sharpness of the edge was coated in rust and a bit eaten away, so we´ll have to guess a bit how it was originally. It is not a shot in the dark however. The blade had a cross section that was like a very thin triangle, some 6.5 milimeters at the thickest. The edge would have been sharpened with a slight convexity in the last three or four milimeters or so. The section of the blade was fine and well defined. The sharpness would have been formed from a thickness of a milimeter or slightly less.
The thick part of the blade was made lighter with a set of grooves that were flat in the bottom, not rounded. I got the impression they were cut with a sharp chisel. Very crisp. There was a broad sunken area that might have held a panel, perhaps of silver (perhaps with engraved designs)?
On other flacatas the cross section is more dynamic I have seen an example where the edge was more like a pointed drop and the main face of the blade had a concave dip, or wide fuller, from the thick spine to the rising thickness of the edge. This is alike some well made kukri knives you can see today.
Profile PM Website
Peter Johnsson
PostPosted: Thu 11 Sep, 2003 3:03 pm    Post subject:         Quote
Geoff Wood wrote:
Mr Johnsson
The transverse lines across the tang is a projection of the guard, seen from the nd of the grip. It is made from two filed plates of iron riveted to each side of the blade. (These rivets are invisible, I believe they are countersunk and hidden beneath the rust)
At the end of the grip there is a small hexagonal plate riveted in right angles to the tang. This gives a clear indication to what shape the grip scales were fashioned, at least toward the end of the grip.
There is a small ring integral to the blade at the spur of the guard. This indicates there was once a small chain between the end of the grip and the spur of the guard. I sketched this chain in, just as a remainder. My guess is that this could have been made from a contrasting material, perhaps bronze or silver. Or it may just have been iron and rusted away.
Profile PM Website
Peter Johnsson
PostPosted: Thu 11 Sep, 2003 3:10 pm    Post subject:         Quote
Nice.
Correction:
Sorry, the cross section was not that flat as I first said. From the grooved part it curved gently down to the edge, giving the last half of the blade toward the edge a convex shape. It still was fairly thin, though. The upper half of the section, towards the spine had a taper to it so the start of the convex part was thinner than the spine.
Profile PM Website
Darwin Todd
PostPosted: Thu 11 Sep, 2003 7:08 pm    Post subject: Distal taper?         Quote
How about distal taper on the falcata? A lot or a little? Continuous or at different rates along the blade?
Peter Johnsson
PostPosted: Thu 11 Sep, 2003 11:11 pm    Post subject: Re: Distal taper?         Quote
Taper in the tang and varied taper in the blade: mild untill the clip point, then more marked towards the point.
Profile PM Website
PostPosted: Fri 12 Sep, 2003 6:34 am    Post subject:         Quote
Wow. More great information! Peter, anytime you post I spend as much time looking at your fantastic technical drawings as I do looking at the weapon!
Would anybody else like to see Peter's drawings made available as prints or posters? Every time I see one I wish he had a catalog of his drawings available. I wouldn't hesitate to pay $30 plus shipping for a print describing an historic weapon of my favorite style.
Profile PM Website
Geoff Wood
PostPosted: Fri 12 Sep, 2003 8:19 am    Post subject:         Quote
This indicates there was once a small chain between the end of the grip and the spur of the guard. I sketched this chain in, just as a remainder. My guess is that this could have been made from a contrasting material, perhaps bronze or silver. Or it may just have been iron and rusted away.[/quote]
Thanks for the information. So, do you think that would have been decorative or functional, and if the latter, for what?
Chris Holzman
PostPosted: Fri 12 Sep, 2003 9:12 pm    Post subject:         Quote
Yah... I've often pondered that, and in fact considered emailing Albion the other day, before I realized Peter was frequenting this forum. It seems to me once there was a pic on SFI that has one of this drawings of a rapier, and I was just amazed..
Heck, I'd gladly pay for any sort of well done reproduction of those drawings.. especially if they are 1:1 scale drawings. That would just be too cool. I remember thinking the first time I saw one of his drawings 'wow...theres art *I* can relate to.' and well, since I can't afford one of his swords yet (3 years of law school starting in January) well... this would be cool too.
Chris
Chris Holzman
River City Fencing Club
Wichita, KS
Björn Hellqvist
myArmoury Alumni
myArmoury Alumni
PostPosted: Sat 13 Sep, 2003 12:45 am    Post subject:         Quote
I agree; Peter's drawing are amazing, and it is a real treat watching him when he makes them, commenting on the original. But I fear that he won't publish any drawings, as there will be companies less bent on research on their own that would gladly buy them as well. :(
Profile PM Website
Peter Johnsson
PostPosted: Sat 13 Sep, 2003 12:05 pm    Post subject:         Quote
Thanks!
There is a dream project I hope to realize some time. Together with Patrik Djurfeldt (whith whom I did the original research on the Svante Nilsson Sture sword) I hope to be able to publish some sort of book with information on the european sword some time in the future.
We have some thoughts at Albion to make available material of this kind as well. We just have to figure out the right form to do it.
There is the aspect that Björn puts forward: with the data available in print, you give away years of preparatory work for the price of a booklet or poster. Still, even knowing for a fact what should be included in a blade, it takes a lot of work and dedication to put it to use.
With detailed drawings showing blade geometry of swords from very early to more recent times it becomes very clear that the development of the sword was not one from crude to advanced. From the earliest times blade geometry was highly developed by craftsmen with a deep understanding of the cutting edge.
Profile PM Website
Peter Johnsson
PostPosted: Sat 13 Sep, 2003 12:25 pm    Post subject:         Quote
Geoff Wood wrote:
...there was once a small chain between the end of the grip and the spur of the guard....So, do you think that would have been decorative or functional, and if the latter, for what?
Judging from the small diameter of the ring holding the end of the chain it is difficult to say if it was mostly decorative or if it acted as protection of the fingers. 16th C hungarian (and Polish?) sabres have a chain between pommel and cross to protect the fingers of the hand, but these chains are more substantial.
There is one exapmple of an unusually large falcata (blade length 52 cm) in the Archaeological museum in Madrid (# 10475) that has the unusual feature of a solid rod between the spur of the guard and the beak of eagle head at the end of the pommel.
This shows that they were interested in the extra protection that a chain (or rod) might afford to the fingers of the hand. I think the extra protection was only a secondary need, however. The primary function of of the almost encircling grip was probably making the grip more secure.
Compare the curving end of the pommel of the falcata with the 13th C fauchards or falchions shown in the Maciejowski bible, and the chopping knives/short swords used in Italy up to at least 18th century called "storte contadine". They all share this same feature: a spur that curves around the back of the hand.
Profile PM Website
Jorge Santos
PostPosted: Sun 16 Aug, 2009 3:05 pm    Post subject:         Quote
Congratulations Peter for your article and beautiful photos ...... if you allow me to say the falcata was a very common sword here in the peninsula.... ( i´m Portuguese )..and this was used not just in war time ...but in peace times she was an agriculture tool too!!!...she was used to chop and cut ...This sword was so powerful that Romans had to reinforced their wood shields with a iron bar all along the edges.....they just shattered them in pieces!!!!!... Can´t wait to read more articles from you...... Cheers!!!! Jorge Santos
jorge santos
Profile PM MSN
Zach Gordon
PostPosted: Sun 16 Aug, 2009 7:53 pm    Post subject:         Quote
Any chance Albions gonna make a falcata? I know I'd buy one!
Thanks for posting, it's great how many famous smiths take the time to post here!
Z
PostPosted: Sun 16 Aug, 2009 8:14 pm    Post subject:         Quote
Z
No idea but I think it would take some time to get from the drawing prototype stage to having one available since Albion still has a few announced swords still not in production after a few years.
I would either get the Del Tin, Windlass versions if I wanted it now and cheap or go the custom route with either Michael Pikula or OlliN :
http://www.myArmoury.com/talk/viewtopic.php?t=16789
http://www.ollinsworddesign.com/
There are certainly other custom makers out there but these two options are currently relatively fast and inexpensive for full custom work and both very skilled and talented makers. ( Michael works more at the forge and OlliN mostly stock removal ).
