Forum Index > Historical Arms Talk > The landscape of spathae blades! Reply to topic
Martin Wallgren
PostPosted: Sun 20 Aug, 2006 6:56 am    Post subject: The landscape of spathae blades!         Reply with quote
I have finaly got the old digit out of you know what and started on my first own sword. It´s going to be a spathae for a impression of my Roman Auxilliary trooper from arlund the time of Trajan. Now, I am going to grind out the blade on this one. A local knifesmith and I made the rough shape of the blade and I are now in the stage of grinding out the fuller/fullers and edges and so forth. My cousetion now is that the plan I have for the sword is to have a short fuller aprox. the first quarter of the blad from the handle. It has a little distal taper and is also tapered about a total of 5 mm towards the point on each side. The blade has a with of 45 mm. But is this a plausiple shape of a spatha. On Peter Johnssons concept drawnings for Albions Next Generation there seem to be three totaly diffrent blades. I just wanna know so I don´t make a complete fantasy here.
Thanx in advance guys!
Martin
Swordsman, Archer and Dad
Matthew Amt
PostPosted: Sun 20 Aug, 2006 8:11 am    Post subject:         Reply with quote
Ave!
I certainly encourage everyone to make more Roman swords! Bearing in mind that I have *not* done a ton of research on the spatha, I think your plans are close but a little off. As I recall, the spatha of Trajans's times should have parallel edges, not tapered (though distal taper is certainly fine), and I don't think there should be a fuller at all. A width of about 35 mm is better, too. The blade you describe could be a spatha from the 3rd century, perhaps, or later, but that's going out of my area (and era) of expertise. So doing it just as you describe could be a perfectly good Roman sword, just a century or so later than Trajan, that's all.
Good luck with it!
Matthew
Mikko Kuusirati
PostPosted: Sun 20 Aug, 2006 10:39 am    Post subject:         Reply with quote
AFAIK, fullers only came about when Roman designs started mixing with the Germanic ones used by their barbarian auxiliaries; the original Roman patterns of both gladii and spathae had a flat diamond cross-section, sometimes with a reinforced point, with no fuller.
Martin Wallgren
PostPosted: Sun 20 Aug, 2006 10:51 am    Post subject:         Reply with quote
Yes, but at the time of Trajan (late part of the first century AD) The influences from nothern europe had been in Rome for at least 50 - 70 years, two or three generation of contact. Many stand up citizens of rome had a father or grandfather with a very germanic name.
And my impression is a Auxilliae soldier. If I was a Legionaire I would have opted for a Gladius.
Mattew!
I will take your word for it.
I wonder, did the gallic and germanic tribes fiddled with the fullers at middle of the first century AD.
Shane Allee
PostPosted: Mon 21 Aug, 2006 7:56 am    Post subject:         Reply with quote
Fullers start popping up on the celtic blades during the La Tene III period.
I really can't remember too many swords that have short fullers though, that seems to be a much later concept.
Shane
Robert H. Shyan-Norwalt
PostPosted: Wed 23 Aug, 2006 8:09 am    Post subject: Spatha-first try.         Reply with quote
My first go round for one. I'm doing, -not done yet, a 150 layer straight lame, to flesh out a Pictish persona.
 Attachment: 65.84 KB
Collosians 2:8
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
