Forum Index > Off-topic Talk > Brigandine makers Reply to topic
This is a standard topic Go to page Previous  1, 2, 3, 4, 5  Next
Ben van Koert
Reading list: 14 books
PostPosted: Thu 03 Dec, 2009 11:20 pm    Post subject:         Reply with quote
Some 16th century brigandines feature a form of tassets, but I'm not aware of any 15th C. examples. Personally I use a maille fauld to cover this gap.
W. Schütz
PostPosted: Fri 04 Dec, 2009 4:31 am    Post subject:         Reply with quote
Take a look at some Burgundian tapestries, like the ones in the Bernisches Historisches museum - there are some very interesting brigandines there; brigandines with spaulders, brigandines with tassets etc..
JG Elmslie wrote:
ia! ia! Brigandine! Rise from the dead!
*shakes a few chicken bones at the thread*
sorry, could'nt resist.
just a thought, since the thread has shambled from the crypt for a breath of fresh air, anyone know of reference material about upper leg defences with brigandines? a bit of poking recently through Arms and Armor of the Medieval Knight did'nt come up with much - if it's plate, the fauld drops to the hip level, and in a longish brig, the same sort of coverage is available there... but then there's tassets in front of the cuisses on plate... anyone know if there was an equivalent on brigandines when they were worn with leg armour?
[/i]
Gentes scitote,
vicine sive remote,
quod claret Suecia
plebeque militia.
Iagoba Ferreira
PostPosted: Thu 10 Dec, 2009 3:46 pm    Post subject:         Reply with quote
Hello to all (my first post, after lurking a while). Here you have a photo of a brigantine, with tassets, covered in red velvet. it's currently in the Musèe del Armèe, but before, it was part of the Estruch collection, in Barclona. iIve been unable to find photos of it on the web Confused so I had to do the work myself...
For a bigger image click HERE
John Waller
PostPosted: Fri 11 Dec, 2009 11:33 am    Post subject:         Reply with quote
James Barker wrote:
I do not know of a single depiction or extant example or a brigandine being black or historical document referring to black leather brigandines.
Not an extant example of a black brigandine nor a historical ref to a black leather one but I have a ref to black fustian covered brigandines.
From the 2001 Royal Armouries Yearbook : A C15th Weapons Dowry by Kelly DeVries
Given by Phillip the Good of Burgandy to James II of Scotland in 1449
50 Brigandines covered in black fustian
33 garde-bras of the same colour ...
Nathan F
PostPosted: Mon 22 Feb, 2010 1:02 pm    Post subject:         Reply with quote
im starting out making armour and hope to make a brigandine for myself but dont really know much on them i have read throuhg this post and though you guys could help.
how do you make them what cloth is best to use what metal thickness i was thinking 16gauge.
also does anyone have patterns for a brig that i could use for as many periods as possible?
and roughly how many rivets will i need?
and will i need washers?
do the plates need dishing or are the flat?
also where would i get tin in the uk and how much would i need?
thanks for advance for any help.
for here starts war carrion birds sing, and grey wolves howl
Jean Henri Chandler
PostPosted: Mon 22 Feb, 2010 5:04 pm    Post subject:         Reply with quote
Mathieu Harlaut wrote:
A friend of mine, armoursmith and bladesmith makes nice brigandines : Yannick Epiard.
All plates are hand hammered and can be tinned. There is no lining like on all originals recorded. The White rose brigandines have a canvas lining which is not accurate. You can choose the outer fabric, linen, velvet, silk velvet.
Interesting point, I've never seen a lined Brigandine. Company of St. George always has very good kit.
Do the plates not pinch you? What do you wear underneath?
J
Jon Terris
PostPosted: Mon 12 Apr, 2010 2:39 am    Post subject:         Reply with quote
Hi Nathan F, lets see if I can answer these questions for you.
First, patterns.
As to using this for multiple periods, that is a little tricky. The brigandine is considered to have "evolved" from the Coat of Plates (14th century) eventually becoming the Jack of Plate (16th century) One example of a 16th century Jack was actually made from pieces of an earlier brigandine*. Essentially the plates get considerably smaller and the garment becomes more fitted to the wearer.
So while it is very possible that an earlier example may have survived a later example is obviously out.
A good site is the Armour Archive which has patterns for a version from each century so you can compare them;
You will need to adjust the patterns to fit you (as you would with any pattern you don't make yourself) but this will give you a good idea to start from.
http://www.armourarchive.org/patterns/brig/
Also, Craig Nadler has made a few brigandines and his website has patterns and plenty of advice too. While this is definately a 15th century style you could use it for early 16th century if that helps.
http://www.eskimo.com/~cwn/brig_craig1.html
As for material, use a good stout fabric like canvas as a foundation and either linen, strong wool, velvet or leather as your outer layer depending on your status (velvet being the poshest, then wool, linen and leather).
Personally I would only suggest using 16 guage for the larger "lung-plates" on a brigandine, the rest can be done in 18 guage since the plates overlap so much. (Personally, I have used 18g galvainsed steel for my first brigandine- when I am completely happy with the pattern I'll look into tinning the next set.)
If however you choose to make a Coat of Plates then I might be tempted to go for 16 guage (if all of the plates are big and there is little overlap.)
Rivets, I have used copper roofing nails on my brigandine, (again, the mk2 will have nicely filed ones) Ordinary rivets tend to have too small a head (which will allow the fabric to pull away from the plate too easily) I know others have used galvanised steel clout nails to good effect (the galvanising looks a little like tinning on the nails). I used some 1400 nails on mine, this will vary depending on what you make of course. You shouldn't need washers as the nails are peened directly against the plate.
Finally, the plates I made were all shaped to curve around the body but not dished (except the lung plates which needed to fit in two directions). They were each hammered into a curve, giveing a small amount of work hardening to each piece as a bonus.
Here are a couple of pictures of my Brig, finished January 2010
Hope this helps!
Jon Terris
*"On the remains of a jack of plate excavated from Beeston Castle in Cheshire", from the Arms and Armour Journal, Vol XIII, no2, Sept 1989
PostPosted: Mon 12 Apr, 2010 11:48 am    Post subject:         Reply with quote
Just wondering about period maintenance ? How did they deal with cuts or rips in the outer fabric ?
I would imagine that a high quality repair should be invisible to the eye or would an old Brigantine acquire " character " with obviously patched up rips and tears.
Armour with the metal bits on the outside like a scale shirt would seem to avoid this problem, on the other hand I assume that scale shirts are much more vulnerable to blades slipping between the scale than with the Brigantines where the overlapping lames are much harder to slip a blade in between the lames ?
Jon Terris
PostPosted: Mon 12 Apr, 2010 1:01 pm    Post subject:         Reply with quote
It depends on how much damage one suffers Jean.
There is one at the Historisches Museum, Basel which (in my opinion) shows some signs of repair - granted this could just as easily be from re-construction.
My brigandine was sewn together from 5 panels after the plates had been riveted in, the seams are visible but not unsightly- you could easily replace a panel if it was damaged in this manner.
If the damage is too bad then I expect the brigandine would be replaced by the owner.
Armour is the medieval equivalent of Personal Protective Equipment, these days if we crash whilst wearing a crash helmet or fall whilst wearing a harness then we are supposed to replace it. I believe that the same thinking would apply with an armour designed to save your life (assuming one could afford to replace it that is).
We do know that brigandines were re-cycled into Jack of Plates (Beeston), this could have been because the brigandine had failed structurally (or possibly just because the style was out of fashion) but we can also infer that a damaged brigandine could be re-used - its plates either stripped down and re-mounted or cut into another item.
I have a friend who has been re-enactment fighting for a few seasons in a brigandine, it shows some scars but nothing really serious thus far.
I would think that having the plates on the outside would leave them more prone to damage if anything, the chances of losing plates through leverage and sliced cuts much higher although I have no real experience in scale armour so I cannot be sure of this!
Jon T
[/i]
Dustin R. Reagan
PostPosted: Tue 13 Apr, 2010 10:53 am    Post subject:         Reply with quote
I'm probably misunderstanding how brigandines are constructed, but when you say 'replace a panel', do you mean just replace the outer cloth? If so, how do you get the original covering off (since it appears it's riveted in place) and then put the new covering on without re-doing hundreds of rivets? Seems like a lot of work?
Thanks
Dustin
Leo Todeschini
PostPosted: Tue 13 Apr, 2010 3:53 pm    Post subject:         Reply with quote
Found another supplier fro brigs. Try ASH in the UK http://www.armour-services-historical.co.uk/
very nice work
www.todsworkshop.com
www.todcutler.com
Jon Terris
PostPosted: Wed 14 Apr, 2010 3:05 am    Post subject:         Reply with quote
Thanks
Dustin
No, you would have to re-make the panel - plates, rivets and all- and then sew it in (having removed the old one) this would be easiest on the side pieces (having only one column of 13 plates) and harder on the back or front pieces.
In theory you could replace smaller areas in this method, though I would not like to have to try!
This is still quite a job but still easier than making a whole new brig.
Smaller tears could be sewn up with some patience, it depends on how close the tear is to the rivets as this affects how easily one can get a needle through the velvet/canvas.
JonT
Thom R.
Reading list: 30 books
PostPosted: Thu 01 Jul, 2010 9:34 am    Post subject:         Reply with quote
Last year I gave a positive review to Steel Mastery on my COP. I still like it and that particular transaction was flawless. However, lately I have tried buying more from them via ebay and there are some odd things going on that are not simply language barrier issues......... I am afraid I have to withdraw my positive comments about them. tr
Bryce Felperin
PostPosted: Thu 01 Jul, 2010 10:48 am    Post subject:         Reply with quote
Had a good experience with them for a Gambeson I ordered through their website...it might be an Ebay thing.
Thom R.
PostPosted: Thu 01 Jul, 2010 12:32 pm    Post subject:         Reply with quote
Glad to hear of your positive experience but its not "an ebay thing". its a "steel mastery thing".
Bryce Felperin
PostPosted: Thu 01 Jul, 2010 3:57 pm    Post subject:         Reply with quote
Understood, however I still plan to try them on a Brig next year, spent or plan to spend too much this year to try. ;-) Sometimes you get different experiences for the same manufacturer. Have to pipe in with my experience when it occurs.
Best of luck,
Bryce
Tyler Zeck
PostPosted: Fri 15 Aug, 2014 2:36 pm    Post subject: About Brigandine         Reply with quote
Hey everyone, im a new member here.
ive been trying to learn armoring for quite some time and am very interested in making brigandine.
i was successful with a 120 plate, 680 rivet Coat of plates which i designed, but i know that Brigandine plates overlap..... any tips on making brigandine or helpful hints? ill be using the same pattern as my coat of plates for the cover and backing material since it fits me well.
thanks. Happy
oh as for the materials i use only 16 GA. milled steel, an outer layer of 1/16in sued leather, and an inner set of 3/16in leather lining plates made from tanned cow hide to absorb shock from blunt impacts then an inner layer of canvas.
a bit about me, i play in the SCA and Amtgard performing small repair work and on rare occasion taking orders as a blacksmith and armorer. i prefer the weight of historically accurate materials for the aesthetic value as well as their durability..... helps when taking those unforeseen blows from pole-arms and heavy weapons. anyways, im still rather new to this industry and i joined this site to get tips and learn as much as i can. Happy
Mark T
PostPosted: Fri 15 Aug, 2014 3:15 pm    Post subject:         Reply with quote
Hi Tyler,
Welcome!
Did you look at the patterns and guides listed in Jon Terris' post (April 12, 2010) above?
Schallern sind sehr sexy!
Tyler Zeck
PostPosted: Fri 15 Aug, 2014 3:42 pm    Post subject:         Reply with quote
Unfortunately they wouldnt come up on my computer.... and anyways, i designed my own pattern that seems to work well for the fabric portions, i was just wondering about techniques, and things that would make life a bit easier with brigandine.... like how to make my own rivets so im not using quick set rivets any more. Mostly just fine tuning, what tools are most useful and if i dont have the tools how can i make them. Just little stuff like that. Happy
Mark T
PostPosted: Fri 15 Aug, 2014 4:18 pm    Post subject:         Reply with quote
The first link is working for me ... maybe try another browser?
For Craig's brig/s and instructions, try this link: http://nadler.us/brig_craig1.html
If you do a search at The Armour Archive, you'll find leads on rivet supplies ... there's also ideas in the posts above! Big Grin
Page 4 of 5 Reply to topic
Go to page Previous  1, 2, 3, 4, 5  Next All times are GMT - 8 Hours
