Forum Index > Historical Arms Talk > Costs and Weights of mail versus weight of plate... Reply to topic
Erik D. Schmid
PostPosted: Thu 25 Aug, 2005 6:15 am    Post subject:         Reply with quote
Patrick,
As for the chest square, I am firmly in the camp of those who believe it to be a ventail. There has been much work done on this and that is the conclusion that is most often arrived at. Thanks for the kind words as well.
Jonathon,
I would go with an octangonal opening. Just angle the corners of the neck opening a bit. One thing to always bearin mind is that mail had seams. So many people today trying to make mail attempt to do so without using any seams. They believe that a seamless garment is preferred. Hardly the case when you look at original pieces. Also, remember to leave enough slack so that you can turn your head.
Jared,
An accurate link size for the time period you are describing would be around 8mm ID with a thickness of around 1.5mm. The weave would be alternating row using riveted and whole/punched links. The riveted links would be closed with a round rivet. This si the information you need when making a weight assessment as various garment sizes will weigh differently depending on the amount of links used.
http://www.erikds.com
PostPosted: Thu 25 Aug, 2005 3:35 pm    Post subject:         Reply with quote
Hisham Gaballa wrote:
Thanks for the info Dan. This is the pic I was talking about. It's from Christopher Gravett's Norman Knight. It's an Osprey book.
Note that the armour on both figures are rendered differently. Some might claim that they are wearing different types of armour but it is likely that the two figures were done by different artists who had different approaches to depicting mail.
Page 2 of 2 Reply to topic
